Question about HP Pavilion Computers & Internet
HP Pavilion HPE h8-1214 It won't boot after installing a new bios verison and it beeps 8 times?
  • 5 more comments
  • Travis Tellefson
    Travis Tellefson Oct 22, 2013
    Also there's no display =(
  • Brian Sullivan
    Brian Sullivan Oct 22, 2013
    you should also Check your RAM. The RAM is located in the middle of the motherboard. There are tabs that you can push to release the RAM. Remove it and put it back in place until the tabs pop out. Loose RAM can cause your computer not to start properly where you want to see a video signal. Remove the memory modules from their slots. Take the opportunity to clean the slots on the motherboards and the memory module connectors. Use compressed air to blow dust away and clean contacts with a soft cloth. Do not use a metallic vacuum cleaner if it touches any component it may create a short and cause damage to the motherboard or other components. Do not use solvent that may attract dust and never poke things like cotton buds in to slots. lightly rub an alcohol (Methylated Spirits) on a cloth not to hard let the alcohol do the work on the copper gold or silver tabs and r Allow the pins to dry. They will air dry in a matter of minutes.
  • Travis Tellefson
    ok ill give it a try.. also i made add when i was installing this new bios maybe within a min of installling this the cpu froze for about 30 secs and i saw an error pop up. i didnt quite see it all before the cpu restarted it's self but it was like hp_bar something stopped working. im hopeing i didnt ruin anything.
  • Travis Tellefson
    now that you mentioned it i did try cottons swabs earlier before this problem started. i see some of the fibers from the cotton on the memory and the radeon 7450??
  • Travis Tellefson
    Travis Tellefson Oct 24, 2013
    General Spec
    BrandHPSeriesPavilionModelh8-1214 (QW701AA)TypeStudent/Home officeProcessorAMD FX-6100 3.3GHzProcessor Main Features64 bit Six-Core ProcessorCache Per Processor6MB L2 CacheMemory10GB DDR3 1333Hard Drive1.5TB SATA 3.0Gb/s 5400RPMOptical Drive 1SuperMulti DVD Burner driveGraphicsAMD Radeon HD 7450EthernetGigabit EthernetPower Supply300WOperating SystemWindows 7 Home Premium 64-Bit
  • Travis Tellefson
    I have no display.. just 8 beeps 8 blinks and then it like turns on, i mean the LED goes blue but no display?
  • Travis Tellefson
    Travis Tellefson Nov 06, 2013
    http://www.quepublishing.com/articles/ar... this is my exacte problem.. but i have no floppy drive. Is it possible to use a disk drive? A USB San Disk?
  • HP Master
  • 27,725 Answers
8 Short BeepsYour video card isn't working. Make sure it is seated well in the bus. If it still beeps, either the whole card is bad or the memory on it is. Best bet is to install another video card.
Posted on Oct 22, 2013
Testimonial: "when i was searching for solutions i saw that maybe you could do bios recovery? with moving the jumper i tried it and the beeps stopped? but there's still no display."
  • 13433 Answers
SOURCE: bios error beep code HP
Hey ByteGuy, Saw your solution to a premium where you asked the customer to contact you with ask me, I have to admit that was a good way to communicate before but now, if you go ahead and click ask me on my profile, you will find that it takes you to a 9.99 and 19.99 usd page instead of a free request.
Just a heads up.
Thanks,
Ekse
Posted on Mar 04, 2009
tomsat69
  • 214 Answers
SOURCE: bios password on hp pavilion n3295 notebook
You can by removing battery for 15min then install fire up should work good luck:)
Posted on May 07, 2009
MUKHTAR
  • 2017 Answers
SOURCE: cleaned cooling fans on hp pavilion desktop now is
This may be your bios setting also like case is removed so go to bios setting and disable the alert or you can try with fixing the ram make sure while you was cleaning you not touch to ram .may be you troche them .do 1 thing remove the ram and clean it and install it again.
Posted on Nov 10, 2009
Testimonial: "gonna try it"
  • 366 Answers
SOURCE: hp pavilion a1540n does not boot
Sounds like a memory fault, try removing 1 memory at a time, and restart. might help, try each memory by its self to indentify the bad card.
Posted on Dec 01, 2009
  • 5 Answers
SOURCE: I have a hp pavilion a635w that will not boot up not even to bios
check if the ram if is compatible with the board
check if the battary power the bios
Posted on Dec 22, 2009
Where on the motherboard hp aos-d 620887-001 to plug in the power reset & hdd led
try looking here ..you need to look for pw which the power switch that need attaching to
Jun 13, 2017 | HP Computers & Internet
Installed a new bios update and the PC froze half way thur the install, Now when i turn it on its beeps 8 times and the LED light flashes 8 times then it acts like its starting up but theres no displa
You can usually reset the CMOS if you remove its battery from the motherboard, and maybe short across the leads to remove all residual voltage from its capacitors. I say "maybe" because removing the battery for 20 minutes might do the trick, and there can be a couple of leads in the same area of the motherboard expressly for the purpose of resetting the CMOS. Unplug the power cord before trying this, and touch the case before trying this to remove any static charge.
Dec 14, 2013 | NA HP Pavilion HPE H8-1220 Desktop PC with...
Laptop beeps 32 times on boot up
http://www.bioscentral.com/beepcodes/awardbeep.htm
maybe will help ,but try to lessen how are grouped (the beeps) thing like 1short +3 long +2short.
like if there are problems with the ram will be 3 normal beeps .
try to group the 32 beeps .
Jun 22, 2013 | HP Pavilion Dv3-1075us Notebook
Hp pavilion dv9000 takes a long time to get past the bios screen. It won't boot of dvd either??
Check BIOS boot options and assign local hard drive as first for faster boot. This is also where you set CD\DVD as first to boot from disc. Look for F Key press on start up. It will be shown on screen. These can vary.
Many HP machines also have a boot menu option during boot. Again an F key and may vary.
Sep 22, 2012 | HP Pavilion dv9000z Notebook
What's youComputer won't boot with 16 gig of memory Problemsr problem?
see:
http://support.hp.com/us-en/document/c02155464
Go down to where it says "Memory upgrade information"
be sure you are using the correct memory. The machine should also give you beep codes or flashing light codes if it doesn't get into the BIOS screen.
If you're using the proper memory, try to install it one stick at a time to see if it works at all
Oct 08, 2011 | HEWLETT-PACKARD Pavilion p6540f PC Desktop
Lights come on, fan comes on, no monitor, no HD activity, no bios beeps, all hardware removed from the under compartment. Still nothing.
Boot laptop with no memory installed should give seris of beeps to clear memory,next remove battery install mem if it boots ok battery hanging up laptop if not plug in mem one at a time to see if one is bad.
Jan 11, 2011 | HP 417035-001 - HP Pavilion dv2000 Series...
HP DV6110us: 4 beeps, no boot
besides the beeps which indicate a motherboard timing issue. There should be LED blinking codes given on the front LEDs. I will include the blink codes below, but lets try to at least get the system up and running. First, I would like you to remove the RAM sticks from the laptop and just reseat one stick back in the machine. Try to boot with that one stick, if it does not, try the other alone. There have been issues when reseating the ram or re-installing it have temp. fixed the issue. If it does reboot, go to the HP support site, put in your model number of your laptop and download and install an updated BIOS. Below are the blink codes that may narrow down the problem.....
HP DV6000 LED Blink Codes
LED Component Error Condition
Blinking battery power LED Battery Insufficient charge on the battery
Blink: 1 - Caps Lock/Num Lock CPU CPU not functional
Blink: 2 - Caps Lock/Num Lock BIOS BIOS corruption failure
Blink: 3 - Caps Lock/Num Lock Memory Module error not functional
Blink: 4 - Caps Lock/Num Lock Graphics Graphics controller not functional
Blink: 5 - Caps Lock/Num Lock System board General system board failure
Blink: 6 - Caps Lock/Num Lock BIOS BIOS authentication failure
Oct 22, 2009 | HP Compaq Pavilion dv6110us Notebook
New HDD inserted into Pavilion ZD7000 - will not boot from XP CD
Try your old HDD in it and see if that works. If it does work then nothing is damaged except your DVD drive/Controller. Try putting the new HDD in another computer, installing windows then putting it back in the HP. If all else fails then flash the bios with an updated image and see if that rectifies the problem.
Feb 01, 2009 | HP Pavilion zd7000 Notebook
Computers & Internet Logo
171 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
