Question about Technics Audio Players & Recorders
Technics FG ServQ SL-BD22 needle doesn't make contact with record
    Guru:
  • 417 Answers
ARM LIFT NEEDS DROPPED, NEXT TO TONE ARM BASE....LITTLE LEAVER.
Posted on Nov 03, 2013
SOURCE: Technics SL-23 belt driven turntable (NOT SL-1210 but I had to enter something)
Howdy Ivy:
An Adobe PDF format service manual for the Technics SL-23 turntable can be downloaded from
http://www.servicemanuals.net/
for about $16.
Paul H.
Posted on May 21, 2008
SOURCE: How to put a drive belt on Technics SL-BD22 Turntable ?
check this link it will deffo help
http://www.archive.org/details/Turntable_Belt_Installation
Posted on Mar 10, 2009
  • 256 Answers
SOURCE: How do I remove the platter on a sl-bd22 Technics
You will have to lift off the cloth on the platter section to expose two rather large holes in the plattr. Insert your thumb and forefinger, and pull up.
Posted on Jul 13, 2010
  • 135 Answers
SOURCE: I just purchased a Technics SL-BD22 turntable and
The genuine Technics ground wire with correct connector is available here :-
http://cgi.ebay.co.uk/TECHNICS-GROUND-WIRE-SL-BD20-SL-BD22-BD22-NEW-PART-/300419439062?cmd=ViewItem&pt=Turntable_Parts_Accessories&hash=item45f264d9d6
http://stores.ebay.co.uk/methleykev
Posted on Jul 20, 2010
SOURCE: Technics SL-BD22 ground wire does not reduce hum. Any solutions?
I have found out that the female phono plugs on the turntable are sensative and have to have a solid connection and often adjusted from time to time to eliminate the 60 cycle hum.
Posted on Nov 04, 2010
Needle doesn't make contact with album-can I adjust it myself?
The weight at the end of the arm should be adjusted so that it applies pressure to the stylus. However sometimes the cueing leaver can get stuck or break, not allowing the stylus to come down on to the record. If the weight has numbers trying setting it to around 2 or 3. If it does come down, adjust it till that it neither rumbles or slips across the record. It's a question of trial and error doing this.
Oct 22, 2013 | Technics SL-BD22 Turntable
Lp starts off sounding good..shortly after sounds like a warped record.
It would sound like the speed control is not functioning and changing speed up and down. That might sound like a warped record as you describe it. You can try moving the controls and cleaning them with a commercial contact cleaner.
Nov 09, 2010 | Technics SL-BD22 Turntable
I had not used my turntable for about five years due to no needle. Found a needle and played two LPs, then on the third one, it just did not move or work at all. It lit up but just acted like it had no...
The low grinding noise could be the motor spinning with "no load" i.e the belt has snapped or fallen off due to being perished.
Lift the platter to refit the belt and or replace it if required.
Jul 23, 2010 | Technics SL-BD22 Turntable
I just purchased a Technics SL-BD22 turntable and it came without the ground wire. Is there anywhere I can purchase this proprietary part?
just get any small speaker wire and use that as your ground , attach that to the reciever you are using
Jan 16, 2010 | Technics SL-BD22 Turntable
Tone arm cueing problem on Technics SL-BD27.
the auto stop mechanism needs adjusting
Apr 07, 2009 | Technics SL-BD22 Turntable
Turntable wont spin
If everything seems ok with the power , there is usally a small microswitch that sends power to the motor when the tone arm is moved to the start of the record.
The switch might be bad or the lever that actuates it (connected to the tone arm) might be sticking. You may have to take the bottom cover off or remove the platter to see it.
Also make sure the belt is looped over the motor shaft. If the motor runs but the belt still doesnt turn, belt might be bad.
Mar 10, 2009 | Technics SL-BD22 Turntable
Cartridge
"at3482p-de" <--do a search for this at yahoo. the resulting cartridge is correct for your model. it comes with the needle as all cartridges do. There are better ones you can get but this one is aprox. equal to the original supplied with the unit. In short any pmount type cartridge will fit/work in your player.
Jan 29, 2009 | Technics SL-BD22 Turntable
120 people viewed this question
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
Ben Armstrong
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
