Question about Westinghouse Washing Machines
Have someone come out and check the micro process boards they are known to go out after a while
Posted on Oct 22, 2013
SOURCE: washer continues to drip into tub after cycle in complete.
contstant water dripping into tub sounds like a bad water valve, no repairing valve just replace it
Posted on Feb 25, 2008
SOURCE: I have a Westinghouse Stackable
I would gently suggest as a first step that you clean the drain motor lint tray/filter. So many 'faults' are caused by blocked filters and many machines will not even go to spin or release the door lock if there is any water still left inside.
Here are my complete guidance notes for checking both the drain motor filter and the drain motor ;-0)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!) and most are held in by a round cover/knob. Sometimes the filter will not come out with the cover and you will have to persuade it to come out to play!
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT!
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. If it doesn't work then the motor is malfunctioning!
Hope the filter is the problem and good luck!
John C
Posted on Apr 04, 2011
SOURCE: I select a wash cycle
I would gently suggest as a first step that you clean the drain motor/pump lint tray/filter. So many 'faults' are caused by blocked filters and many machines will not even go to spin or release the door lock if there is any water still left inside.
Here are my complete and general guidance notes for checking both the drain motor filter and the drain motor ;-0)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!) and most are held in by a round cover/knob. Sometimes the filter will not come out with the cover and you will have to persuade it to come out to play.
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT.
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. Using something suitable like a glove see if it is easy to briefly slow the motor down. If it is easy then the motor is malfunctioning.
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
Posted on May 12, 2011
SOURCE: Washer won't complete cycle. F02 flashing
F02 = long drain
try this
If the drain time exceeds eight minutes, the water valves are turned off and "F02" is flashed.
Press PAUSE/CANCEL two times to clear the display.
NOTE: After four minutes the "Sud" error will be displayed, then four minutes later the "F02" error code will be displayed..
Possible Causes / Procedure
1. Check the drain hose and make sure it is not plugged or kinked.
2. Unplug washer or disconnect power.
3. Check the electrical connections at the pump and make sure the pump is running.
4. Check the drain pump filterfor foreign objects.
5. Plug in washer or reconnect power.
6. If the above does not correct the problem, go to step 7.
7. Unplug washer or disconnect power.
8. Replace the pump.
Posted on Oct 23, 2012
What water temp do you wash on and what water temp for rinse?
Posted on Nov 01, 2012
Jul 27, 2015 | Westinghouse Washing Machines
Sep 11, 2014 | Kenmore 387780 series 80 Washer Motor
Dec 05, 2012 | Washing Machines
Nov 22, 2012 | Maytag Washing Machines
Oct 31, 2012 | Maytag Washing Machines
Oct 05, 2012 | Kenmore Elite 45986 Front Load Washer
Sep 27, 2012 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Hi
Error code FH appears when No water is detected
entering machine or Pressure switch trip is not detected. If after 30 seconds
the control does not detect water entering machine and then valves will be
turned off and the error code will be displayed. Press PAUSE/CANCEL twice to
clear the display. If there is no water entering the unit then make sure that
the inlet valves are working fine. You may need to check the continuity at the
inlet valves. If the valves are fine then check whether inlet water hoses as
they might be plugged. Also check for inlet water screen at the valve. However,
if the water is entering into the washer then the Drain pump might not be
working. Also inspect the Pressure Switch hose whether it is in good condition
and properly connected to Tub and Pressure switch. Also check hoses for leak
and inspect the flow meter. Hope this helps...
Daniel
Aug 31, 2011 | Kenmore HE2 Plus Front Load Washer
Jun 23, 2017 | Whirlpool Duet GHW9150P Front Load Washer
Dec 30, 2009 | Westinghouse WWS833ES Super Capacity Top...
19 people viewed this question
