Question about Casio Parts Cash Register PC Desktop
What is E001 and how do you clear it? - Casio Parts Cash Register PC Desktop
  • Casio Master
  • 1,648 Answers
Hi Tina. It has different meanings depending upon the machine you have.
Which make and model are you using?
Posted on Oct 23, 2013
How can i fix the error code 000001-00002
Assuming you have a copier or laser printer, this site:
Thread Canon IR 2200 error E000001 002
suggests:
Some errors can just come up and you can just clear them and if everything works fine you don't need to worry about calling a tech. However if clearing it doesn't make the error message go away or you have problems emerge with the copier then you do have a problem.
E001 is an Overheating detection error.
E001-002 - The sub thermistor detects about 295 degrees celsius or higher. You would have got E001-000 for a temperature above 250 degrees.
Jan 11, 2016 | Canon Office Equipment & Supplies
Canom imagerunner 2520 error e000001
the e001 is error for the temperature rise detection in fixing unit. There are more sub codes that I need to know for precise troubleshooting. i.e. E001-000 or E001-001 or E001-002
But if there is no fault in components, you can try to reset it in service mode.
Procedure:
additional function, then press 2 and 8 then go in clear by pressing scrolling, then go in engine, then choose ERRCLR and then turn off and on the copier.
If these doesn't helps you need to replace fixing film unit.
Aug 29, 2011 | Canon 0000A011BA Copier
My canon iR2016 has a system error E001
the e001 is error for temperature rise by main thermistor. If the termistor OK and doesn't need to be replaced you can clear the error in service mode. If clear doesnt helps, you need to change the fixing film assy.
Clearing error:
Press the User mode key, 2key, 8key,
User mode key sequentially
now you are in service mode, by arrow right, select #CLEAR, press OK, choose ERR and OK.
Also you can try with same procedure but instead ERR choose ALL. NOTE: under clear ALL, you delete all user data and restors the copier on factory settings.
Hope that helps!
Aug 25, 2011 | Canon Office Equipment & Supplies
ERROAR E001 AND E808
u can clear E001 in the service mode Press * 28 * go to clear press OK then err press OK . and the E808 is the cooling fan malfunction .it can be because of the erratic power fluctuations or damaged fan.
and the if E001 happens during copying then u have to check the fusing unit as sometimes the pressure roller bush gets misplaced from original position causing jam and code
Aug 03, 2011 | Canon iR 2016i Black and White Copier
E00001-002 Error cod?
Thanks for using Fixya.
Go into service mode, go to COPIER > FUNCTION > CLEAR > ERR.
Select ERR to highlight, and press OK key.
Turn off the copier using the main power switch (on the right side of copier).
Wait at least 10 seconds and then turn the copier back on using the main power switch.
If the error is still there then you will need to take your printer to a canon service center.
Good luck and have a nice day.
Nov 08, 2010 | Canon (6981A002AA) for imagerunner 2200,...
I have canon ir6570.its shows e001-001,e001-0010 repeatly
try to clesr the err. from service mode ( * 2,8 * ) function - clear- err- press ok
if not ok
you have a problem in the fixing unit
Apr 01, 2010 | Canon IMAGERUNNER 6570 Copier
I am using a SE-S300 and can not clear a E001 error code!! Any ideas??
E001 = Wrong Mode, which means u had did something in another key mode but not yet done.
Solution 1 :
1. Turn the key to another position where the screen do not show E001
2. Press [Subtotal]
3. O.K
Solution 2: Flag Clear the Machine
1. Key turn to OFF
2. Keep Press [FEED]
3. Key turn to PGM
4. Release [FEED]
5. U will see "INIT 0000000000"
6. Press [Subtotal]
7. U will see "FFFFFFFFFF"
8. Wait for 10 seconds, the machine will print
9. OK
Nov 15, 2009 | Casio Parts Cash Register PC Desktop
E001 switch off the machine and on again
E001 is a fixing assy fault you have to clear the error in service mode after correcting the fault of course. I would try clearing the error code in service mode 1st. press *28* function tab clear tab error ok then restart copier
Sep 09, 2009 | Canon imageRUNNER 400S Copier
Error E001 of casio ce-6100
e001 error tryed ur solution and it still does not clear help please
Aug 20, 2009 | Casio Parts Cash Register PC Desktop
Casio Parts Cash Register PC Desktop Logo
Top Casio Retail Supplies Experts
Electroboy
Electroboy
tomferryman
Level 1 Expert
Are you a Casio Retail Supply Expert? Answer questions, earn points and help others
