Question about Panasonic Lands Phones
My phone is not working. when I turn it on, it sounds with bip bip noise, and apears on screen. "no enlace to base , reconect adapt base print". I re-conected the line and the ac power and nothing happened
    Problem Solver:
  • 13 Answers
I had something similar happen to my phone. It ended up being a bad battery. Hope this helps!
Posted on Oct 22, 2013
Cidco
SOURCE: no dial tone on handsets
Hey.. Did you check to see if the phone is registered correctly ???
Posted on Jun 07, 2007
SOURCE: I have a philips CD
Presumably you have 'registered' the handset to the base station - a bit fiddly, but easy enough! If you haven't a handbook, there is one here
http://www.p4c.philips.com/files/c/cd2454b_05/cd2454b_05_dfu_eng.pdf
Good luck
Jim
Posted on Oct 14, 2008
  • 49 Answers
SOURCE: it sounds like rotary dialing
I have a similar Panasonic phone (KX_TGA101S).  Someone must have inadvertently changed the dial mode on you.  Here is how you change it on mine, which should be similar to yours.  Hit the Menu button.  Scroll down to "Set tel line" and hit the Menu Button (OK). If it isn't displayed, scroll to "Set Dial Mode" and hit the Menu Button. Select Tone instead of Pulse and hit the Menu Button.  That should do it.
Posted on Jan 25, 2009
  • 40 Answers
SOURCE: Phone won't work
try unplugging the base and plugging it back in. Or try a different outlet for the base.
Posted on Jun 11, 2010
perkoo
  • 17 Answers
SOURCE: I need a power adapter
9V - 780mA
Posted on Jan 05, 2011
My wireless phone is about seven years old. There is a loud static sound in the dial tone and a loud buzzing sound when I am talking, which can also be heard by the person I am talking to. I just put new...
Try disconnecting the cordless phone base unit from the phone jack where it's connected and plug in a basic corded phone. If you still have the noise, the trouble is in the phone line itself and you'll need to contact your telephone service provider.
If the phone line isn't at fault, the trouble is in the base unit. Most likely, the power supply filtering isn't working, and you're hearing hum in the audio as a result. If the base unit uses an external plug-in adapter (a "wall-wart") with a DC output, you can try replacing it with a new one. Radio Shack sells replacements. Just be sure to get one with the same voltage rating, the same or higher current rating, and the right polarity plug. It may be that the old adapter isn't filtering any more because of its age.
If the adapter is an AC output type, or the base has a built-in power supply with a regular AC power cord, you should probably shop for a new phone. The trouble is in the unit itself, and you'll spend more trying to have it fixed than it's worth.
Dec 26, 2010 | Uniden Lands Phones
When I try to switch it on you can hear the processor go on but nothing happens, the screen stays black and then a very loud bip.....bip...bip occurs; and then..nothing else
  1. Check your power cord & adapter.
  2. If its working then check the battery, reseat the battery & check.
  3. If available then check with another battery
  4. If no, then remove the battery & switch on the PC in AC mode.
  5. Check if battery charging indication or AC power on indication is glowing. if not then need to change ur motherboard.
  6. If indication is OK, but could not power ON then check ur RAM for any loose connection or dust. clean & reinstall.
Aug 20, 2010 | HP Compaq Presario V2000 Notebook
When turn on, it stays with white screen
unfortunately your phone is broken. its a compression fracture in the screen itself, if you look from an angle you will likely see it. sorry, but if you have the insurance this is covered.
Aug 24, 2009 | Nokia 7373 Cellular Phone
Ok.. MY PROBLEM IS THAT I TURN ON MY PS3 AND IT MAKES THE SOUND BIP..THEN WITH NO VIDEO ON THE TV OR SOUNFD COMING ITS DOES 2 BIPS AND IT TURN OFF AGAIN,,I HAVE TRY TO LEAVE IT ON A COUPLE OF...
lets try a few things bronx,
lets start by going over the beeps and lights. when you power the unit on. it should go Blue and stay blue. this means the unit is so far functioning correctly.
if your unit turns on lights up blue, then yellow , then red and stays red you have an issue
if you are experiencing the first scenario, press the power button till it goes red. which is standby mode.
then press button again till you hear two beeps, let go. make sure you have all your cables plugged in. this will send you to the diagnostic screen on the ps3 to select anyone of your options. since you are not getting a video display select the display settings and reset yours according to your type tv. if you are using a standard old school tellie, then its 480i, if you are on a plasma or lcd it would be 720p,1080i or 1080p. then you should be good from there
okay, if you are experiencing the second scenario its a much more severe issue. the GPU on the motherboard has gone bad, which is common on ps3s. if it is under warranty contact sony and they will send you out a refurb'd unit. if it is not under warranty there are a few good companies out on ebay that reflow or reball gpu chips on ps3s to repair this known issue.
since you are getting beeps and lights this is one of your scenarios. if you get no lights,no beeps then you got a bad Power Supply.
Good Luck!
Ruben
Jul 19, 2009 | Sony Playstation 3 (PS3) Console
I have no sound with any movies on my blu-ray player
go to sound settings and make sure you got the settings correctly there is a lot of different settings if somebody move the settings accidentally then they have to be reset how well here is how turn the main power switch off now put your finger in the on/off switch in front of the console now turn the main power switch on keep your finger in the on switch you will heard a bip this bip is when the system turns on keep your finger there until you heard a second bip then take your finger off now your video and audio settings have been reset
Apr 24, 2009 | Sony Playstation 3 (PS3) Console
Toshiba qosmio E-10 noises keyboard and start up
Sound like you have a stuck key and the bip noise is the keyboard buffer pverloading.
If you can't unstick this key, you need a new keyboard.
Apr 13, 2009 | Toshiba QOSMIO E15-AV101 Notebook
Cordless phone 25881
Sounds like a power problem.
This model of phone will work as a regular corded phone when no ac power is available.
IE the cordless function is only available when you have electricity.
- is the ac adapter plugged into a working outlet.
- is the ac adapter working.
- is the ac adapter pluged into the base.
hope this helps
Nov 30, 2007 | GE 25881EE3 Phone
Phones won't work
A) Ok first try to disconnect everything and connect all the batteries and cable back. Charge your batteries to full. Then if it still Out of range, do this with all your handsets.
- Disconnect the battery
- Hold the * and # key on the Handset and put the battery back without releasing the buttons. (now your in test mode)
- press the 2 softkey below the screen ( it's a factory reset, erase everything)
- You will see RAM/EEprom erase on the screen
-After the bip press end
B) OK! Now disconnect the power adapter from your base unit .
-Hold the memory button on your base and plug the power adapter at the same time. Then the base will bip to let you know that you done it correctly.
-after the bip press No.1 ( that's mean the handset 1 is de-registrer.
- Now De-register all the other handset by doing the part B again. But only changer the No.1 for 2 then 3 then 4.
C) Disconnect and reconnect everything and use your manual to register your handsets with the base and your done! Everything should be ok !
Nov 21, 2007 | Uniden DCT648-3 Cordless Phone
Lands Phones Logo
Top Panasonic Lands Phones Experts
guyvstewart
john milligan
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
