Question about Maytag Washing Machines
An "LF" comes up on my display. what could be causing this. I have a Maytag series 2000
    Genius:
  • Maytag Master
  • 2,382 Answers
-Read its manual.
Mai
Posted on Oct 22, 2013
2 Suggested Answers
stewbison
  • 577 Answers
SOURCE: maytag front loader 2000 series
Hi, is this a new washing machine? If not, then these Maytag front loading washing machines use a paraffin locking switch in the front panel to lock the door during operation. Now, if the switch has gone south and trip the the lock switch without locking the door. Then the washing machine want turn on.
What is a parfin locking switch work is a small container with paraffin (wax) in it with a heater. When the washing machine is turn on. The control board indicate that the machine is in operation and a small amount of current is applied to the paraffin switch to the heating element. This make the parfin to expand trip the locking mechanism and locking door during operation. Keep the door lock from accidental openings. It will take about 4 minute after the washing machine has quite it running operation to open the front loader door. The paraffin needs to cool down to release the locking mechanism. stewbison
Posted on Aug 20, 2011
What does the error LF on my Maytag 2000 mean
Long fill check the drain hose make sure it's only about 6 inches down drain pipe if ok check pressure hose for a hole of ok problem with pressure switch or board
Apr 29, 2016 | Maytag Washing Machines
Maytag 2000 Error LF what does this mean
The LF error code indicates a long fill condition.
What you need to do is check the filter screens where the hoses connect to the unit. Remove the hoses at the back of the unit. The screens are hust inside of the connections. Make sure they are free from any debris.
or
https://www.youtube.com/watch?v=1M-XgRT3obc
or
http://ths.gardenweb.com/discussions/2441868/maytag-bravos-lf-error-code-solved
What does error code LF on my Maytag 2000 series front load washer mean?
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Dec 03, 2014 | Maytag Washing Machines
I have a maytag 2000 series washer. I keep getting an "LF" on the display. What is causing this. I hope you can help
LF means long fill. Firstly, check the screen on the water inlet if there is any debris, clean it out, reset the unit and try to hear if there is any humming sound. Sometime the inlet valve causes this issue.
Oct 22, 2013 | Maytag Washing Machines
Maytag Neptune FAV6800AW Top Load Washer, service manual
I have the letters "LF" on display, wsher does not work.. What does "LF" mean?
Thank you
Aug 09, 2012 | Maytag Neptune FAV6800AW Top Load Washer
What does LF mean on the washer? When I start my load it pops up as LF and stops washing. What do I need to do or what is wrong?
LF (F30)
LF flashes when the control don't sense any water coming in like it is supposed to do. Things to check:
Hoses connected; water turned wide open.
Is water siphoning out due to having the drain hose too low? (30 inches above the floor)
Pressure hose from tub to control loose, pinched, hole, Sediment in tub? themobilian_1135.jpgthemobilian_1136.jpgBlow that tubing out and re-secure; retry with water OUT of tub so the pressure can properly build in that tubing. themobilian_1137.jpg
Bravos codes and service manual HERE
Jan 29, 2011 | Maytag Bravos 3.8 Cu. Ft. Washer
Maytag Bravos top load gives LF code..not working ... any idea?
Have same problem. Service tech said LF code is caused by low water pressure coming into machine. Tech verified water flow looked fine, getting new controller installed tomorrow.
Jul 18, 2009 | Maytag Bravos MTW6600T Top Load Washer
My maytag bravo top loader washer is displaying a code of LF and
it meant "low flow" check water connecting lines. mine has the same problem.
Dec 02, 2008 | Primera Technology Bravo (Refurbished)...
Washing Machines Logo
77 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
