Question about Health & Beauty
Need to replace brake on Rascal electric mobility handicspped scooter have new brake need inst how to replace
  • 1,263 Answers
Hi , Pelase could I have the model no ?
Regards
www.gewizrepairs.co.uk
Posted on Nov 16, 2013
gewiz
  • 1263 Answers
SOURCE: electric mobility Rascal 265 LE scooter won't run
Are you sure the batteries are charged ? Is the Battery charger charging ok ? Are the batteries connected ? take off seat and cover to check battery leads, does the key fit in the lock okay ?
Posted on Jun 13, 2009
  • 61 Answers
SOURCE: Rascal mobility scooter will now only go backwards
On some scooters it is possible to change the polarity of the motor. If its a two brush motor (most are) you can just swap the red and black wires around in the connector plug for the motor. Make sure you get the right wires if you do this but I have to point out that there is obviously a problem with the scooter and I would strongly advise you to get it looked at by your local dealer as the problem is potentially serious and may cause other problems aswell. I cant really understand why it would only go backwards. May be a throttle pot problem or main controller fault. Either way, as I said, best get it looked at as even if you do swap the wires, it is most likely that the scooter will only travel forward at the usual speed for reverse, normally 2mph! Hope this helps...
Posted on Mar 19, 2010
SOURCE: I NEED A USER MANUAL FOR A RASCAL 388XL MOBILITY
Send me your email contact details, and bI will send you what I've got.
aidee
Posted on Sep 26, 2010
  • 2418 Answers
SOURCE: I HAVE A RASCAL MOBILITY
I do not know of a Scooter graveyard, but I will look for one. I found a site that sells many different types of 24volt battery chargers. If you have a special port on the scooter and you still have your old charger you can cut off the end of the bad charger and wire it onto a new battery charger. Now as with most lead/acid battery's any charger with a built in volt/amp regulator will work.Your old charger spect's are for a 4amp max rating, Any constant 2.5amp or better should recharge your battery's overnight. I am sending you a link to a site called Battery Stuff.com where you can find a 24volt charger for as low as $89.oo, Now I understand this may be a bit out of your range, but a new battery charger for a laptop computer will run about $115.oo. So for a Heavy Duty scooter that is not to bad. Plus it may out last 2 sets of battery's. Now use this site as a reference and maybe you can find one you like local. Hope this helps Fixya up.
Posted on Apr 12, 2011
gewiz
  • 1263 Answers
SOURCE: rascal mobility scooter 329 le/ brake keeps snapping on on downhill run
Deos the brake click when this happens ? now if that's the case that is the controller not supply a voltage to the break otherwords it being released, now discoonect the brake and measure the resistance , it should be about 50ohms , ifit's too low that could cause a problem,
Posted on Dec 09, 2012
Electric Mobility: Replacement scooter charger
Rob, If need be, possible you can adapt you old chargers connector onto new charger if not the same plug. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
24 Volt 4 0 Amp On Board Battery Charger for Rascal Scooters and Power...
RASCAL 600 600t HANDICAP MOBILITY SCOOTER PRISM 24V BATTERY CHARGER...
Aug 17, 2016 | Electric Health & Beauty
Where can I get repair on a Rascal Little Rascal made by Electric Mobility
  • Mobility Scooters - Parts and Repair - US Medical Supplies www.usmedicalsupplies.com > Parts and Repair - Table of Contents Learn more about the parts and components of your electric mobility scooter, and get troubleshooting tips and maintenance guidelines for getting the most out of your ...
  • Wheelchair and Scooter Repair - Nationwide In-Home Repairs wsrsolutions.com In-Home Wheelchair and Scooter Repair. Wheelchair and Scooter Repair™ (WSR) is a nationally accredited repair company with an A+ rating from the Better Business Bureau.
  • Mobility Products - Electric Scooters Power Chairs and ... www.electricmobility.co.uk A bit about us... Welcome to Electric Mobility Euro Limited. If you are thinking of buying, or already own an electric scooter, power chair or riser-recliner, then ...
  • Mobility Scooter Repairs, Servicing & Maintenance mobilityrepairsuk.com Mobility scooter repairs Nationwide. We are the U.Kb s most trusted servicing, repair and maintenance provider also offering insurance, warranty and mobility scooter ...
  • Power Chair Repairs & Electric Mobility Chair Repairs www.mobilityrepairsuk.com/power-chair-repairs.html We provide nationwide power chair repair. Our onsite mobility chair repairs and electric wheel chair repairs are guaranteed.
  • Electric Wheelchair Repairs - In Motion Services www.inmotionservices.ca/#!electric-wheelchair-repairs/cmmz We will happily repair mobility scooters, powered and non powered wheelchairs, and any other home healthcare equipment that needs servicing.
  • Sales, Servicing and Repairs of Mobility Scooters ... www.mobility-services.co.uk Servicing and repairs of mobility scooters, wheelchairs and stairlifts from RB Mobility. Friendly, fully guaranteed, door to door service call 01923 710055
  • Service Repair Shop Technician for Mobility Scooter, Power ... www.easymedonline.com/service-power-wheelchairs-and-scooters Service and Repair for Mobility Scooters, Electric Wheelchairs, Recliner Lift Chairs ... If you need to locate a repair shop / technician near you click here...
  • Sidney Scooters, Scooter Rentals, Scooter Repairs, Sidney BC sidneyscooters.ca Sidney Scooters is a specialized dealer of electric mobility products. Our purpose is to help customers achieve greater freedom and independence.
  • Mar 04, 2016 | Electric Mobility Health & Beauty
    Does the owners manual have a wiring diagram in it for the rascal 230 electric scootetr
    Hi marilyn, Sadly no mobility scooter manual will give you such information, i willing to help , what do you want to know ? faulty lights , thinking of fitting a new controller ?
    Regards
    Rob
    Feb 15, 2016 | Electric Health & Beauty
    Who make chauffer mobility power wheelchair
    The Chauffeur Scooter Company bought up by Electric Mobility Corp(Rascal). So some consider it a Rascal. Some of Chairs were also made by Merits
    Feb 28, 2015 | Electric Mobility Mobility Electric Power...
    Rascal 230 wiring diagram
    Check the multi pin connector on tiller and where it connects under the seat between the batteries. Most common problem.
    Oct 09, 2014 | Electric Mobility Rascal Scooter...
    Does anyone have arepair manual for a rascal 300 I need to fix the electromagnetic brake
    It is the same as a Rascal 600 only the 300 has smaller wheels.
    The manual is not much help on the brake, it does not go into repairing the bake, except for checking voltages and replacing the microswitch, some tips are a little oil on the detent balls help to keep it free and movable, but don't get oil on the brake pad.
    Scooter Doctor App
    Aug 27, 2014 | Rascal 300 Electric Scooter - Used...
    Wiring schematic rascal 600 24v electric
    hi, firstly what controller is fitted (curtis) ? then i can give you a ideal controller wiring schematic but you won't get hold of a Rascal one..
    Regards
    Rob
    Aug 16, 2014 | Rascal 600 T Electric Scooter w Seat Lift...
    Rascal 600T Scooter FIX IT Manual
    There is an owners manual available which has a troubleshooting guide at the following: http://manuals.monsterscooterparts.com/mobility/Rascal/manual-rascal-600-t.pdf
    If you have a good relationship with a local dealer they may be able to copy and provide you with one.
    Electric Mobility, the manufacturer, in my experience will not provide one to you.
    Mar 02, 2014 | Electric Mobility 3 Wheel Motorized...
    Rascal 600
    Neil wood, the Rascal 600 DOES use an on board charger. What signal is the white wire looking for to make the scooter move is the question. 28v?
    Apr 20, 2012 | Electric Mobility Power Electric Scooter...
    Health & Beauty Logo
    Top Health & Beauty Experts
    Robin Hill
    Robin Hill
    wcdoc1953
    wcdoc1953
    Are you a Health and Beauty Expert? Answer questions, earn points and help others
