Question about Pool & Spa
Water leak at manifold - Pool & Spa
    Scholar:
  • 94 Answers
I do not have enough information to give you an educated answer to your problem. A water leak on the manifold of what? what type of spa, pool, or jetted tub is it, and on the manifold of the pump? It could be a cracked wet end in which case you'll have to remove and replace. It's important to provide as much information about the product as well as a detailed description of the problem to ensure you get the best assistance. I hope this helps..
Posted on Nov 09, 2013
Water leaking where hoses join engine block
The water hose connects to a plastic section that slots into the inlet manifold. This then relies on a rectangular shaped rubber gasket to seal against the engine block but can easily leak so a good idea is to add some silicone gasket sealant before tightening the inlet manifold nuts and the 2 bolts that hold the water section of the manifold
Jun 16, 2014 | 2005 Fiat Punto
Tip
Intake Manifold gasket replacement and/or leaking= Ford
Intake Manifold gasket~
Replacing intake manifold gasket:
Replacing the intake manifold gasket, I used the tube kind, it's a make it youself for about $6 (it's blue and the consistancy of toothpaste) follow directions carefully! You can get a tube at Autozone or any car parts store. Has been working great. Just ask the cashier for the make it yourself kind of intake manifold gasket. Sorry, I don't remember the name of it, it's been that long...lol...
As for the Intake Manifold leaking coolant....It could, but shouldn't. One of the largest problems I've seen for coolant to leak out the Intake Manifold has been due to pressure in the system somewhere... Check the classic area:
Water pump- look for either water seapage and/or coolant. You'll know if it is because you will see real water either coming out of the water pump leak hole or under the thermostat. Most of the time coolant will pool where your heater hose runs in the intake manifold.
Mentioning heater hose. Check for leaks, holes, and/or cracked heater hoses. In-addition to the water pump, heater hoses...Check the transmission system, exhaust system, fuel system, radiator system, A/C system, secondary fan (located above the water pump housing), and thermostat.Also, check all electrical connections....Hummm....This is almost the entire workings of the vehicle.
NOTE: "It seems to be an infinity kinda thing... Once one thing starts to fail and is ignored, you are bound to be fixing a chain of event failures. Therefore, Do not ignore even the smallest problem or you'll be bound for life in repairs...."
on Jun 25, 2010 | Ford Expedition Cars & Trucks
Stop leak for hottub
If you have a leak around the manifold you will likely need to replace it.
Is this an air manifold or a water manifold?
Manifold come in two types. One is for PVC pipe and the tubes are glued into the little sockets and the other type have barbs and the tubes are glued and clamped on.
Rod
US Parts Center
888-521-6183
Jun 05, 2012 | Jacuzzi Pool & Spa
Water leak under the manifold cover, above the thermostat
I'd say your heater hose is leaking. The hose for your water pump probably runs out the back of the water pump right under your manifold. If thats the case then your in for a job.
Sep 19, 2010 | 2001 Ford Windstar
1999 chev malibu leaks water from under exhaust manifold but not from block.
it may be a bad head gasket if it is leaking coolant. check to find the source of the leak. or if its leaking coolant from intake manifold gasket. also check water pump and all hoses.
May 15, 2010 | 2000 Chevrolet S-10
My 1999 chevy tahoe is leaking antifreeze. I
it could but- check passenger side front where heater core line go into manifold right behind alternator the hose line is connected by a press clip into an alloy fitting this fitting gets eaten away by anti freeze and hose angle pulls back on fitting the part is $18 at dealer and is screwed into manifold use caution if ur r going to replace at very edge of aluminum manifold---and check ur water pump bolts the 2 longer ones should have a lock sealant on them they bolt in thru a water jacket
Oct 24, 2009 | Chevrolet Tahoe Cars & Trucks
I have a leak somewhere under the intake manifold on my 2001 chevy venture van is there a hose or something under there
Hi I'm litoshop yes under the manifolds you water seals on the block of the engine when you use a lot of water in your radiator the freeze out plugs rust out and you get these leaks to replace you have to remove the manifold you can use some kind of block sealer but I recommend to replace the seal good luck. if this information has been useful please let us know thank you
Jul 29, 2009 | 2001 Chevrolet Venture
Water leaking from intake manifold
the chev are fames for intake manifold seeping. it will have to be replaced soon good luck
Mar 24, 2009 | Chevrolet 3500 Cars & Trucks
Water is leaking out of the washing powder drawer
the spray holes in the soap manifold are partially blocked and spraying at an angle. try to reduce the water flow pressure at the feed tap and clean the water holes in the soap tray manifold (above the tray).
Feb 16, 2008 | Whirlpool AWM8143 Front Load Washer
Pool & Spa Logo
51 people viewed this question
Top Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
