Question about Canon imageCLASS D760 All-In-One Laser Printer
Canon D660 Error Code E805 I read it was a bad fan, but how in the world do you remove the fan from this unit?
    Novelist:
  • 140 Answers
Which fan? There usually is one for the Fuser and one for the power supply. As for disassembly, you really need the Service Manual to take it apart correctly.
Posted on Oct 23, 2013
  • 199 Answers
SOURCE: error code e805
The fan wiring is faulty (short circuit, open circuit). The heat dischargefan is fautly.
check wiring of heatdischarge fan
The machine is equipped with a single fan for discharge of heat from inside it.
Posted on Mar 04, 2009
  • 153 Answers
SOURCE: SYSTEM ERROR E805
you have a fan that is not working
Posted on Jun 08, 2009
  • 149 Answers
SOURCE: MY CANON COPIER IR2016 HAS FUNCTIONAL ERROR E805...
there could be a problem with the main fan and or the dc controller could be bad.
Posted on Jun 09, 2010
canontech
  • 1219 Answers
SOURCE: I have a Canon Image Class 6550 and keep getting
the e805 means that you have bad fan. The fan is located under back cover.
There are two possibilites:
1) Reconnect the fans connector, and connectors on dc controller - main pcb. If that doesnt help, on electronics hardware store or in computer shop find the fan of same dimensions and replace it.
2) the dc controller is bad, and you need to replace it with new one.
Posted on Jul 08, 2010
Cogz
  • 1326 Answers
SOURCE: sir; i have a canon imagerunner6570 model
A E805 is a exhust fan error code. That means that a fan is not working correctly. I believe you may have one of the fans is blocked or a wire is broken. It is either the fan in the cover of the primary charge unit, there is a connector that may have been caught by the fuser unit. It may also, be the sucktion fan in the transfer unit
Posted on Aug 02, 2010
The canon Copier Brand iR2018 on the screen indicates a System Error E805, when machine is switched on.
Canon iR2018 Error Codes
This weblink states:
Code
E805-0000
Description
Fan failure
The fan is faulty.
Remedy
- Check the fan connector. - Replace the fan. - Replace the DC controller PCB.
Feb 16, 2018 | Canon Office Equipment & Supplies
Canon gp 335 erorr code e805 what is the problem
Canon GP 405 error E805 E805 (The fan rotation is faulty.)
suspect is feeder fan (FM1) or reversing guide cooling fan (FM9).
try Check
Mar 25, 2012 | Office Equipment & Supplies
Sir; i have a canon imagerunner6570 model
Aug 02, 2010 | Canon IMAGERUNNER 6570 Copier
I have a Canon Image Class 6550 and keep getting error code E805 Please help me find a solution.
Jun 30, 2010 | Canon imageCLASS MF6550 All-In-One Laser...
My canon copier IR2016 has functional error E805
May 19, 2010 | Canon imageRUNNER 2000 Copier
ImageRUNNER 400S Copier: what is e805 error & how to clear...
Its a fan related error, basicaly you should check all the fans in copier, clean the filters, reconect the connectors, try to find a bad fan,... When you find the bad fan you can also replace it with new matching PC fan
Pls. rate
May 03, 2010 | Canon Office Equipment & Supplies
System Error E805 in Canon iR2018
E805 is Fan failure
The fan is faulty. - Check the fan connector.
- Replace the fan.
Jan 08, 2010 | Office Equipment & Supplies
E805 error in canon ir 400
E805 error code means failure of one of the many fans inside the copier. If there is not a dash with four numbers after the 805 code on the display, it is one of two fans - FM1 the transport bed fan or FM9 - the reversing fan just below the fuser assy. There are several checks that can be done but a too lengthy to be described. A tech maybe the best answer depending on your mechanical ability.
Jul 21, 2009 | Canon imageRUNNER 400S Copier
Canon ir 400 photocopier
i have ir400 in my machine. first e805 code has been displayed and after that it shows that to load paper. then after e803 code is displayed. please help
Jun 03, 2009 | Canon imageRUNNER 400S Copier
Error code e805
Mar 04, 2009 | Canon imageRUNNER 2000 Copier
Canon imageCLASS D760 All-In-One Laser Printer Logo
52 people viewed this question
old marine
old marine
