Question about E-Machines Computers & Internet
Emachine el1352g 41w
I need assistance in reinstalling the hard drive. (where to plug everything in properly)
  • 221 Answers
If this is the boot drive, connect to the SATA 0 connector at the back of the motherboard. It is a one way connector about 1/2 inch long.
The power is a wider connector that will be loose and comes from the power supply (the cubical metal box).
Both will connect to the back edge of the drive.
Note that they will only go on in one position, so if it doesn't go on fairly easily,flip it over and try again.
Posted on Oct 23, 2013
  • 7 Answers
SOURCE: I have an emachine el1352g-41w, and I cannot get
Try installing from the cd, then run it from the shortcut on the desk top or in windows go to start/run and type in aol.exe
Posted on Mar 13, 2011
ftw1952
  • 10319 Answers
SOURCE: Is the eMachines Black EL1352G-41w is a good
there is not one E machine worth buying since they do not install fuses on the motherboard of any model made
Posted on Mar 15, 2011
  • 103 Answers
SOURCE: does my emachine el1352g-41w have
this specific model touts itself as being "multimedia" and as such does have an onboard audio{1 x headphone-out jack, 3 x audio }
it would be a small round green colored plug for the speakers red/pink for the mic in the back and there is a plug at the bottom in the front for the headset and mic.
GL
hope this helps
Don't forget to vote for me
Thank You
Jammer
Posted on Aug 24, 2011
joecoolvette
  • 5660 Answers
SOURCE: open emachines el1352g-41w
Open the eMachines EL1352G-41W computer case?
Unplug the computer from power. Unplug all cables. Turn the computer tower around so the back faces you.
Look at the Left side. This Side Panel removes.
There is a handle for your fingers, formed out of the Side Panel's sheet metal.
Above the handle along the edge, and towards the Top, there is a Philips head screw. Loosen this screw. (It isn't supposed to come all the way out)
Down below the handle, and towards the bottom, is another Philips head screw. Loosen this screw.
Use the handle in the Side Panel, to pull back on it. Pull towards the back of the computer tower.
The Side Panel may only pull back so far. There may be tabs which stick out of the Side Panel, and go into slots in the computer tower's case.
For this style the Side Panel will only pull back approximately 1 inch, or so.
Then the Side Panel is brought straight out away from the computer tower, and laid aside.
[ NOTE*
Do NOT forget to observe Anti-Static Precautions BEFORE reaching inside your computer, and working on it.
Computer on a table, computer unplugged from power, computer case open.
TOUCH an unpainted surface, of the metal frame of the open computer case.
This action will relieve your body of Static.
Should you leave your computer in the middle of working on it, be SURE to Touch the metal frame again upon your return.
For additional questions please post in a Comment.
Regards,
joecoolvette
Posted on Dec 04, 2011
SD Tech
  • 14553 Answers
SOURCE: my emachine EL1352G-41W wont turn on?
Power supply is most likely your problem--many desktops with this issue have before it happens an issue where it has to be turned on several times and will finally come on and stay on.
The power supply in most cases is a unit that can be removed and tested (most shops charge little or nothing for this.)
If you are able to get it out look for bad filter caps on that board--some examples:
If puffy caps are found you have two choices---replace them all or if possible buy a generic power supply replacement............
Posted on Jun 11, 2012
Testimonial: "thank you for the help. now i know what wrong with it i going to buy a new one to see if it work. if it don't turn on then i think is the mother board. thank for the help."
Emachines EL1352G won't boot up
If you Have the DVD with Windows on it, Re install Windows.....
Sep 02, 2013 | Acer eMachines Black EL1352G-41w Desktop...
Emachines EL1352 motherboard
It\'s an Acer MA061L-3D (part number) according to this,
http://www.ebay.com/itm/Emachines-EL1352-01e-EL1352-23e-EL1352-43-EL1352G-41w-Motherboard-DA061L-3D-8120-/350653705586?pt=Motherboards&hash=item51a496ed72
I\'m guessing made by Foxconn
Regards,
joecoolvette
Apr 18, 2013 | Computers & Internet
My driver for my dvd player is disabled, were do i go to enable the right one?
Right click and enable it.
DVD drives will work with generic drivers from the OS.
Mar 08, 2013 | eMachines EL1352G-41w -23248
My emachine EL1352G-41W wont turn on?
Jun 11, 2012 | Computers & Internet
Does my emachine el1352g-41w have a sound card? If not, where can I get one? Thanks Ron
GL
hope this helps
Thank You
Jammer
Aug 24, 2011 | Acer eMachines Black EL1352G-41w Desktop...
Computers & Internet Logo
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
