Question about Ovens
Chipper champ plus repair manual
I need the belt size for a Euroline 160 Kwikchip chipper
Maytag gas oven takes a long time heat and smells of gas.
Important---if you smell gas--I'd be very very careful---could be your control valve or lines to it are malfunctioning or leaking. You might have to call in an expert repair person. How old is the oven? Some preliminary checks you might make are: Do you have a pilot lite or preheaters on the unit? If a pilot lite, make sure it is lit. An unlit pilot lite could sometimes give the smell of gas if malfunctioning. If so, there is is a procedure for lighting the pilot lite--check your user or installation manual. If you have pre-heaters make sure they are lighting up. Normally you have one for the top broiler burner, and one for the bottom oven burner. Check your preheater(s) by selecting either broiler or oven and visually checking to see if they are warming up. After 15 seconds or so, they should be turning bright red. You will see some light coming from them. Check one pre-burner at a time. If they do not come on quickly, shut off the associated valve. Again, be very, very careful with any buildup of gas. It could cause an explosion. At the least it could make you sick.
Sep 12, 2012 | Maytag Ovens
WHAT IS THE SIZE OF THE CUT OUT HOLE
Thank you for asking me directly to help you with your problem. However, either the question you are asking is not within my area of expertise (I am an automotive repair technician), or the question is incomplete and does not contain enough information for me to help you.
Jan 09, 2012 | Thermador Ovens
Smeg Wall Oven SCA504X Repair Manual
minimum repair is the clearance side wall of at least 110 mm. but never attempt to repair the appliances by your self. it has so many things which need skilled person but proper cleaning and lil bit maintenance for small damages is quite safe.
Dec 12, 2011 | Ovens
Ran self clean now oven will not heat up
Turn the breaker off for 5 minutes then turn it back on see if this helps if not let me know.
Sep 27, 2011 | Whirlpool RBS305PRS Stainless Steel Oven
How do i reset my hotpoint cooker to manual mode? it will not let me do anything when i press the manual button.
Hello, J_russell
I was trying to help you out here. Maybe this will help some? I was going back to some customers that asked questions in the recent past and even farther back. It appeared that no one answered some of them, So, I thought I would take some of my personal time to see if I can help. Even though this Informational site may not have your exact model or brand, this site will help you a lot. Here is a site link about everything you want to know about ovens and possibly yours, from
repair to trouble shooting it. Now go easy on me, I am just trying to help. If it does great if not, I am sorry.
http://home.howstuffworks.com/how-to-repair-an-oven.htm
Please if this helped you at all, if you can find the time and in your heart to rate my help and some kind words written would be appreciated for my free help , I would appreciate it.
Here is also my direct link to my own pages of other areas of my expertise for other problems you might have in Automotive, Appliance, and Electronics. Drop In anytime for my help.
Thanks, Mike
http://beta.fixya.com/users/mc1bean
Jun 05, 2011 | Hotpoint SY36 Style Line Stainless Steel...
OVEN DOOR WILL NOT UNLOCK PUT ON THE SELF CLEANER AND THE DOOR LOCKED AND WILL NOW NOT UNLOCK IT IS A KITCHEN AID AND A CODE KEEPS SHOWING UP
Hi, well i have seen this many many times, and what happens is that when the auto clean function is invoked, well it heats up the inside to a very very high temperature, in excess of 700'C. Often this destroys the temperature, thermistor that controls the oven, unless that is repair the doors stay locked.
http://www.retrevo.com/support/KitchenAid-KEBC107K-Ovens-manual/id/6716bh531/t/2/
Above is your user manual, below is your service and repair manuals, about 1.2 way down the page of posts.. there are two of them. Use the manuals to troubleshoot and repair your unit.
http://appliancejunk.com/forums/index.php?topic=417.0
Jul 21, 2010 | KitchenAid KEBC107 Electric Single Oven
I am havine a problem getting the self cleaning working on my O'keefe & Merritt electric oven. I don't know the model, but I do know that it was purchased in 1978. I've used the self cleaning setting...
Keefe Merritt 12 6267 Manual Book
O & M was merged with what has become Frigidaire/Electrolux Home Products.
You can get parts from them.
The serial number for a built in wall oven from that era would be something like this : 11-6361-30/123
Electrolux's parts number is 800 599 7569. (Phone number)
If the oven needs replacing, Sears, Magic Chef, and Whirlpool offer something in this size range. (You need to measure the dimensions.)
You may need to "google" "O'Keefe & Merritt electric oven repair" plus your location. Electrolux's service department might provide a contact.
Nov 24, 2017 | Ovens
Hi I have a Tappan oven model TGF357CCSF. The clock display andtemperature display is working but it is very dim. I have been told the I need a control panel 316028350 which is no longer available is this...
Hey - That part is available thru AppliancePartsPros online listing is clock/timer.  Part # AP2125110     $203.75   These timers are old-timers anymore. Can be hard to find, and at 200 bucks, make ya think twice. Gas model is probably worth it though.  Either way- it's an electronic clock that has had 120v running through it for 20 yrs or so. Time to replace for sure. Let me know if this info helps-  have more if needed-  Thanks--Ed
Mar 16, 2010 | Ovens
I have a F0 on the display of my double oven JTP45 model
Giggles01: I wish I had an answer other than calling GE. We are about to install a used oven of the same model/same vintage. I've been unable to locate a manual and need some information from it. Would you be willing to tell me the cut-out size the manual calls for regarding the installation of the oven? Most 30" ovens require a 28.5" cut-out, and I need to confirm that for the JTP45. Thank you!
Mar 09, 2009 | GE JTP45 Electric Double Oven
STOVES 720ef Oven Programme won't go off automatic
This is a solution - of sorts - but probably not the one that you were hoping for.
My Stoves 720EF oven developed the same fault.
I tried pressing the buttons in various combinations and I tried switching the power off and on, restting the timer and the clock, no joy.
I then tried getting hold of a copy of the manual and trying to fix it, no joy. Called up Stoves and booked a visit from a specialist service engineer, costing £75 +VAT for the call out, and was advised that the engineer would attempt to repair it but it might need a replacement circuit board, costing a further £110 plus VAT.
engineer arrived on the appointed day and was straight onto swapping out the circuit board - not much scope for "attempt to repair" - so that was about £190 plus VAT to fix it. job took about 25 mins and didnt seem to need anything beyond what any electrician (or electrically-expert DIYer) could do.
comes with a 12 month warranty - hopefully it will work without any issues !
If you have a regular electrician you might prefer to buy the board and get your electrician to do the job - or do it yourself, assuming that you are suitably skilled and qualified.
hope this helps
cheers
David
Nov 07, 2008 | Stoves 720EF Electric Double Oven
Ovens Logo
49 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
