Question about Konica Minolta bizhub C250 All-In-One Laser Printer
Finisher is makes lots of noise after printing paper
    Novelist:
  • 140 Answers
Noise is a relative thing. If it's bumping, clanking and sounds like it's tearing itself apart...That's a bad thing!
If however it's resetting itself with the shuttle mogating back to its home position and the feed arms returning inside for the next page...That's normal.
Posted on Oct 23, 2013
What could the Grinding noise be that is coming from Ricoh Aficio MP C2550 for each page copied/printed?
Check for:
-broken plastic gear on right side of copier
-paper or foreign object in paper path
-paper or foreign object near fuser
Oct 15, 2014 | Ricoh Aficio Mp C2550 Copier With Feed,...
How do I clear error message that says to close the finisher output guide?
The finisher output guide is usually a small plastic piece about as long as the paper feed that can be opened to see the rollers, make sure that is put back down before you print.
Aug 27, 2014 | Canon iR 2016i Black and White Copier
Why can I print a test page out but with regular printing it jams and gives c-1182 error
Finisher motor issue, remove the finisher/and unplug does it work?
what are you printing are you using staple or hole punch try printing single sheet of paper.
Jul 08, 2014 | Konica Minolta bizhub C250 All-In-One...
Why is Printer displaying "PLS change to printer screen", "Offline"
Could be the paper full tab is "stuck up" at the exit, or at least unplug the finisher from the unit and cycle power, pull away and see if it prints. -Carl
Apr 30, 2014 | Kyocera Mita KM-5035 Printer
Paper misfeed
828120c7-b2c6-4ef1-86da-8d12eb17847a.jpgkonica minolta c451 printing this type
Jun 03, 2013 | Konica Minolta Bizhub C451...
Hello, when it prints it makes a noise and bottom of page is smeared
Smeared output can result when you re-feed a printed page into the printer to make a double-sided page. This happens because the rubber rollers that grip the paper to pull it into the printer can pick up toner from the first side’s printing and smear it. So before replacing parts, this is an easy thing to check. Printing multiple pages consecutively will make the pages print progressively cleaner or you can clean the rollers with rubbing alcohol.
Smeared toner also happens because the nonstick coating on the fusing roller is scratched or has baked-on debris. This can happen if the printer is in a dirty environment especially. If you are comfortable removing the fuser, you can try to clean it with a soft cloth and alcohol, but make sure you let it cool down first!
Finally, if this does not resolve your issue then make sure the fuser is heating; toner that is not heated properly will fall from the page and smear. If the thermostat is bad or the fuser not working properly, you will most likely need to replace the entire fuser assembly. This will be pretty expensive to repair so hopefully it's one of those other issues.
As for the noise, there are several complex gear and roller segments that drive the paper between the paper tray, the scanner, the fuser, and the finisher. If these are not perfectly aligned or dirty the printer can make a grinding noise. It's even possible that if the paper is not being fed correctly, that the shift might leave segments of it less accessible to the fuser and prevent the toner from adhering to the page.
But I would try using WD-40 to lubricate some of these components and assume the noise and the smearing are separate issues.
Nov 18, 2009 | HP LaserJet 3330 All-In-One Printer
Paper jam and message C570 - Call for service
The C570 is a communication error between the finisher and the main unit. Check to make sure the connector from the finisher to the copier is plugged in properly.
You could try re-seating connectors on the finisher board - it may help.
Make sure the power supply to the copier is not being shared with some other piece of equipment (like on a power strip) that could be causing interference/noise to the power supply for the copier.
If problem persists..could be bad IPC board(finisher) or CPU board (copier).
Hope this helps
Apr 17, 2009 | Toshiba E-STUDIO 850 Copier
Paper jams at finisher when making multiple copies. Using 20 lb. paper. Any suggestions? Copier is Panasonic Workio DP-4510 with detached finisher.
first try to eliminate the finisher. turn off main power switch and unplug from the power outlet. Now unplug the finisher cable from the rear of the copier, then slide the finisher out of the way. Check to see if you still are having jamming issues. if not then yes the issue is with the exit of the paper or the finisher.
Many possibilities try to narrow it down.
Good Luck
Sep 27, 2008 | Panasonic Workio DP-4530 Copier
The printer is indicating that the finisher tray is full and to remove all paper. But there is no paper on the finisher tray.This is causing the printer not to print.
I wish you told the model number. But when that happens, what has happened is this.
In the finisher tray there would be a flag type actuator that sticks out into the paper path after the paper enters the tray. It has fallen off or has become stuck deactuating the sensor, ( turning it off).
Although there is no paper in the finisher tray, with that sensor flag out of position and the sensor off,it thinks there is paper there.
Jul 12, 2008 | Xerox Office Equipment & Supplies
Konica 7155 Main Error Code : 74 ,printer stops for no reason
There are a few code 74's, and Konica has a bulletins on them.
DESCRIPTION: Code 74-0 from the E-mail alert system. SOLUTION ID: 154045
SOLUTION: CAUSE: Paper remains at finisher main tray paper exit opening.
DESCRIPTION: Code 74-1 from the E-mail alert system. SOLUTION ID: 154055
SOLUTION: CAUSE: Booklet tray is full.
SOLUTION: Remove the paper from bottom exit of the finisher.
DESCRIPTION: Code 74-4 from the E-mail alert system. SOLUTION ID: 154058
SOLUTION: CAUSE: Paper remains inside finisher.
SOLUTION: Please remove copies from the finisher.
DESCRIPTION: Code 74-5 from the E-mail alert system. SOLUTION ID: 154059
SOLUTION: CAUSE: Punch trash box is full.
SOLUTION: Trash basket of punching unit is full. Please empty trash basket.
DESCRIPTION: Code 74-6 from the E-mail alert system. SOLUTION ID: 154066
SOLUTION: CAUSE: Sub-tray (first tray) is full.
SOLUTION: Sub tray is full. Please remove paper.
I'm guessing it just means the finisher thinks it's full, and wants you to take the copies / prints out.
Apr 23, 2008 | Office Equipment & Supplies
Konica Minolta bizhub C250 All-In-One Laser Printer Logo
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
