Question about Splendide 2100 Vented Washer-Dryer
Machine started making belt noise. when cycle ended bed sheet had burn hole and some burned spots.
  • 41 Answers
I believe your belt isnt turning drum with heavy load but your heater element working .change belt.
Posted on Oct 22, 2013
It made a loud noise during spin cycle and started smoking
Doesn't sound good does it?
Smoke could be a burned and shredded belt. Worse, the motor is burned out.
Loud noise? Depends on what it sounded like. Could be the concrete balance weight hitting the cabinet. Could be the belt hitting the cabinet when it snapped.
You need a repair man to diagnose.
Aug 24, 2015 | Washing Machines
Loud boom and burning smell in microwave
Is there any holes burnt into the liner inside the micro wave.? Or burn spots showing.? If there is thow it out. It is not safe to be useing it.It could start on fire. That problem is from when they are not clean out once in a while. End food is burn,t onto the interior liner end grease end oil,
Oct 22, 2012 | Sharp KB6001NS 24 Inch Microwave Drawer...
Old Maytag Dependable care washer - LAT8506
Need to replace the belt going to the transmisssion powered by the motor. these act like a clutch for the unit. It is worn out and needs replaced.
Jan 26, 2010 | Maytag Dependable Care LAT9206
Washer has been making an unusual amount of noise / burning smell
remove the door and screws on opposite side and the front comes off. Then the top will flip up.
Eric
Nov 22, 2009 | Maytag Neptune MAH5500B Front Load Washer
My washer makes a loud noise during a normal wash cycle.
If it is a belt driven machine, then there's the smell. Lean it back a little, enough to fit a paint can under 1 corner and you can feel the belt right on the bottom. Feel for cracks, flat spots or a lot of black dust. Remove belt and make sure everything that it goes around spins free.
Mar 17, 2009 | Maytag PAV2300 Top Load Washer
Loud noise, then not so loud, but now electrical burning smell and little draining
the smell is your clutch and the lack of draining is a clogged washer drain protector. see these at www.repairclinic.com drain protector is part 541811 and clutch is 2670. go there enter model number and scroll down to the red 100 click it and look for these part numbers.
Mar 02, 2009 | Whirlpool LSR5132PQ Top Load Washer
Washing machine started making noise in spin cycle and then there were fumes
The belt is loose and slipping. They were probably, black and smell like burning tires!
Just in case it was a wire burning!!
Call service this time!
A&E Factory Service is nation wide!
1800-905-9505
They are open 7 days 24 hours to make appointments
Neil
Aug 09, 2008 | Maytag Performa PAV2200
The basket drive and the drive block will need replacing. The nut that holds the basket to the drive block may have come loose causing the drive block to 'jump' over and damage the tabs on the basket drive that causes the thumping as the spin cycle ends. To repair, you will need to purchase a basket drive and drive block. The agitator, balance ring, basket and transmission, will have to be removed in order to replace the basket drive. If less than 3ys old, consider contacting whirlpool for possible warranty concession.
May 26, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
Burning smell/noise with my Maytag Ensignia MAV7657EWQ Washer
it could be [motor] or 'condensur' for motor, starting to burn out or over heat, check drive belt as well for ware
Dec 08, 2007 | Maytag Ensignia 3.3 cu. ft. Top Load...
"howling" noise during spin cycle (still there after changing burned off belt)
Travioso, there was two service flashes out on this model concerning the seal and bearing which means they had an issue with this washer. The howling noise you are hearing is the bearing and will need the new designed triple seal and bearing kit. This should be covered under your warranty, I believe it is 5 years. The numbers for the service flashes are TDL-0048A-B. Call Maytag and inquire about these service flashes, these should be covered. Catriver.
Jul 25, 2006 | Maytag SAV5701A Top Load Washer
Splendide 2100 Vented Washer-Dryer Logo
26 people viewed this question
Top Splendide Washing Machines Experts
Doug Adams
Doug Adams
Are you a Splendide Washing Machine Expert? Answer questions, earn points and help others
