Question about Toshiba 42HL196 42 in. LCD HDTV
LN40C630K1F WILL NOT TURN ON..LIGHT BLINKS THREE TIMES THEN GOES DEAD..HOW DO I FIX IT?
2 Suggested Answers
jdvillanueva
  • 2098 Answers
SOURCE: 42HL196 WON'T TURN ON INTERMITTENT LIGHT FLASHING
Hi kelner1950,
This is an indication of out-of-regulation in the power supply section. The very common caused of this fault is the dried-up/leaky electrolytic capacitor in that section. It will drop the supply from normal voltage and will disable the unit and blinking error appear. Sometimes it has a bulged/dome at the top but not all, it is better that you have a capacitor checker/tester to determine its condition. Also, bad solder joints can produce the same symptom, it is hard to spot, you should use table lamp/portable lamp for finding the cold solder. Secondary reason of fault is the open fuse/fusible resistor in series with the output of regulator IC/transistor, shorted/openRegulator IC/transistor, shorted zener diode(all are in the power supply section) and the microcontroller. Best that you check the output voltage of each regulator to determine where the fault came from and narrow the job.
If you don't have necessary tools and test instruments, and can't do the job yourself, I would advice you to look for a professional to troubleshoot the problem. Don't attempt to work in the power supply if you don't know the safety precaution of handling it, there some stored electricity enough to hurt you with a little mistake only.
Also check if your unit is under warranty /extended warranty, avail it because the manufacturer of your unit will fix it for free. Don't open the back panel, this will void the warranty.
Hope I helped you.
Have a nice day!
Thanks for using Fixya.
Posted on Feb 27, 2011
MD2614U will not turn on. red light blinks three times
The first thing to do is check that the charger is putting out the correct voltage, which should be ~19 volt. Then try to start it without the battery.If your voltage is OK and the battery out makes no difference, then I would suspect that you have a motherboard problem that must be fixed. If the computer starts up if you wiggle the DC plug where it goes into the computer, then it's the DC jack that is looks and must be re-soldered.
The dead laptop charger may be another cause. Try a new and correct one:
Intocircuit Gateway MD2614u AC Adapter 65Watt 19V 3.42A
Oct 30, 2012 | Gateway Computers & Internet
My lg tv when i turn it on the picture blinks three times n then turns off
If the set goes dead after 3 times then suspect power supply, if a light stays on then main logic board.
Dec 14, 2010 | LG 47LC7DF 47 in. LCD HDTV
55' sony grand wega will not turn on. The green light blinks 5 times and then red light blinks 6 times. red light cycles 6 times again. What is the problem? Can I fix it myself?
power supply board is dead, u know basic electronics' and soldering? Most of the times, the power supply board just have dead leakages gases capacitors.These capacitors always bulges up on it top,or puff up on it top.Replaced these gases leakages capacitors will get your TV power stable,and work again.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
Take care.....
Dec 07, 2010 | Sony Grand WEGA KDF-55XS955 55" Rear...
Tv does not stay on red light blinks 9 times
Power supply board it dead,replaced this board will get ur power back.Tries Websites Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Apr 09, 2010 | Sony QUALIA 005 46 in. LCD Television
I have the same problem blue power light blinks 3 times
Ur power board inverter is dead.
U need a new board.
Jul 17, 2009 | Hitachi P50H401 50 in. Plasma HDTV
Sony kde37xs955 green light blinks 9 and red light blinks 6
hi..
It's in standby mode.
Do a reset and see what happens
While holding down the reset button on the remote
Press the power button on the tv
(The tv will turn itself off the back on)
Now release the reset button
It sounds like the lamp needs replaced....
thank u!!
rate me!!!
Apr 10, 2009 | Sony WEGA KDE-42XBR950 42 in. HDTV Plasma...
My RCA HD50LPW175yx7 is blinling five(5) times and then shuts off
i have the same t.v. the owners manual says "if the light blinks 5 times, pauses, and blinks again 5 times, the lamp is trying to turn on.If the t.v. does'nt turn on after 5 minutes and the light blinks steadily for 1 minute , one of the following is possible: lamp door is open , lamp is dead , or the power supply within the t.v. needs service.
Nov 29, 2008 | RCA HD50LPW175 50" HDTV
Panasonic PT-53TW53G
If the front power light is blinking three times then your TV has a problem with the convergence. You can get the correct replacement parts and full step by step photo instructions from www.TvRepairKits.com
Aug 17, 2008 | Panasonic PT-53TW53 53" Rear Projection...
Toshiba 42HL196 42 in. LCD HDTV Logo
20 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
