Question about Measuring Tools & Sensors
How do i test for electric current with a commercial electric ms8902h voltage detector or mb1015b multimeter? Need to tie in wire for an additional line for a light
    Master:
  • 683 Answers
You have to test current by putting multimeter on Amps setting in series with the load - very dangerous and since you are asking question like this I would suggest to get someone experienced to do it for you (not worth risking your life)
If you insist on doing it yourself get someone to supervise (someone with knowledge)
Posted on Oct 22, 2013
2 Suggested Answers
  • 2841 Answers
SOURCE: what is this used for,
It is used to detect live circuits through shielded wire or conduit. It will make an audible sound and light up when current is present. It will check from 12 to 600 volts. Here is the owner's manual. http://www.professionalequipment.com/images/pdf/e1200_manual.pdf
Posted on Oct 30, 2010
Does anyone repair multimeters?
junk it as the parts would not be available
new ones are now better equipped to handle what you did and the cost of a good unit from places like Jaycar start around $40.00 up
these measure capacitance, resistance , voltage ac/dc, show polarity of the current, test diodes ,measure up to 10 amps current, and a host of other functions including range settings for all readings all of which come in handy for a shade tree mechanic
Oct 14, 2015 | Measuring Tools & Sensors
Can you wire up the heating element in a hot water heater wrong
you can indeed here are the steps to check you eliment
Turn off the breaker inside your main electric panel providing power to the water heater. Most electric water heaters use a 30-amp double-pole circuit breaker.
2 Look for the panels attached with screws to the side of the water heater. Depending on the size of the water heater, you will have one or two panels. Remove the screws from the panels to release them.
3 Remove the insulation you exposed when removing the side panels. Depending on the age of the water heater, the insulation is fiberglass or closed-cell extruded polystyrene foam. Wear safety goggles and gloves when removing fiberglass insulation.
4 Pull the plastic safety cover from the element face. This cover snaps on and off the element and thermostat.
5 Hold a noncontact voltage detector next to the wires connected to the element face, and next to each wire connected to the thermostat. If electricity still is present in the water heater, the voltage detector emits an audible alarm and its light flashes.
6 Loosen the two element screws. Remove the wires from beneath the screws. Make a note of the element wattage printed on the side of the element face.
7 Turn the dial on a multimeter to Rx1k (resistance times 1,000 ohms). Touch one of the screws on the face of the element with one of the multimeter probes; place the remaining probe on the remaining screw. A 3,500-watt element should register 16 ohms, a 4,500-watt element should register between 12 and 13 ohms, and a 5,500-watt element should register between 10 and 11 ohms. Replace the element if it does not register on the multimeter.
8 Leave one of the probes touching one of the screws on the element face. Touch the other probe to any metal part of the water heater. If the multimeter needle moves, the heater element is grounded, and it must be replaced. Make sure you test both screws on the face of the element.
9 Touch each screw with one of the multimeter probes. Place the remaining probe against the metal base attached to the element where it enters the water heater. The element is bad and must be replaced if the needle on the face of the multimeter moves.
10 Attach the wires back to the face of the water heater element. Snap the plastic cover back over the thermostat and the element. Reinstall the insulation and attach the panels to the side of the water tank. Turn the breaker on to the water heater.
Things You Will Need
  • Screwdriver
  • Safety goggles
  • Gloves
  • Noncontact voltage detector
Mar 06, 2015 | Water Water Heaters
How to use commercial electric ms8902h
it detect if circuit is live (you should always check first on known live circuit to make sure it's working)
In my opinion it is very unreliable and should not be used for definite confirmation that circuit is not live (check it with multimeter also)
Oct 22, 2013 | Measuring Tools & Sensors
Landice L8, tread won't turn.
Dear Neil:
Thank you by your request, I hope you are very well.
I am sorry for my delay.
You must proceed with this:
1) Check C. Breaker from your home if tripped, resset , and try again.
2) Check the power cord, for some cable loose or broker, repair or replace the power cord.
3) Now turn on the treadmill, if it does is o.k if doesnot proceed with C.BREAKER of the Treadmill, reset, and try it again.
Of course you must have some DVOM(digital voltmeter) for to Test this.
How to Check AC Volts with a Multimeter
The multimeter is an essential tool for electrical troubleshooting.
A multimeter is a versatile tool for measuring voltage and current. Electricians use multimeters to measure alternating current, or AC, and direct current, or DC, voltages and currents. Many multimeters also measure resistance, capacitance and temperature. For example, an electrician uses the multimeter's AC voltage setting to determine if a wall outlet has power or if a power supply is functioning. This knowledge helps the electrician pinpoint the cause of an electrical problem and select the appropriate repair.
Instructions
1.
    • 1
Plug the black voltage probe into the voltmeter jack marked "COM."
    • 2
Plug the red voltage probe into the voltmeter jack marked "V."
    • 3
Rotate the range selector knob to the highest range setting, which is marked "VAC."
    • 4
Turn the voltmeter on. Slide the power switch to the "ON" position.
    • 5
Touch the probes to the device for which you measure the AC voltage. Use extreme caution. Ensure that the probes do not come into contact with anything but the surface you are measuring.
    • 6
Read the voltmeter's display. Turn the range selector knob to a lower range if voltage is less than the currently selected range
* Additional Help
http://www.youtube.com/watch?v=yX_0vRPdMfU&feature=related
Finally i gave you , indication that you must chekc in you tube for to help you.
Thank you in advance, sincerely.
God bless you.
If you need further assistance, please reach me
E.CUADRA
MANAGUA, NICARAGUA C.A.
Oct 04, 2011 | Exercise & Fitness
I want to change a plug socket, and know that I need to turn of the elictricity at the mains, and check the wires with a volt checker to check for live current. I bought a Rapitest digital mini electrical...
Yes you can use this instrument to measure. It needs to be put on the AC voltage and to be on the highest value. Voltage is measured with a fuse included (be careful). It is better to use a screwdriver tester to find a phase (hot wire). Wires are measured ohmic and should not be turned voltage on(or it may burn the instrument). If you measure current it can short circuit if the installation is under voltage (because of this reason the current is measured in series connection).
Sep 01, 2011 | Measuring Tools & Sensors
My headlights are flickering and there is a clicking sound. I found a relay that is clicking in the fuse box on the left end of the dash beside the door. when I pull that relay the clicking stops and...
replace the relay and see if it stops, the relay can go like this sometimes and needs replacing. also check the earthing strips from the battery and the shell if it still keeps doing this remove one headlight bulb connection at a time and see if it stop as it could be a faulty bulb.
Jul 10, 2017 | Dodge Dakota Cars & Trucks
Got a 62600 dryer and the power wont come on got power to the unit
Working with live electrical current can be very hazardous. Testing voltage output requires working with electrical current. Do not attempt this measurement without the proper tools and safeguards
To measure the voltage at an electrical outlet requires the use of a multimeter. Always test your test equipment for proper operation before use.
Set the multimeter to AC voltage. The markings may appear as VAC, AC V, or a V beneath a wavy line. Choose the AC voltage closest to the voltage you will measure. Standard current in home and businesses in the USA is in the range of 110 to 120 volts. Some circuits used for equipment such as dryers, air conditioners, electric stoves, ovens and other large equipment may use voltage in the range of 220 to 240 volts. These heavy-duty circuits can be identified by their non-standard outlet plugs.
While grasping the insulated portion of the probes (never touch the metal conductor during testing) place one probe into each of the two terminals. The multimeter will display the voltage.
Carefully remove the probes, being careful not to touch the metal part of the probes to anything or each other.
The voltage should typically test in the range of 108 to 121 volts for most circuits. If voltage is higher or lower, professional electrical service may be required.
Good luck;
Regards:
VOTIT
Dont forget to rate;
Jul 05, 2009 | Kenmore Dryers
2005 Hartford HD-125S electrics not working
Hi, Ratbag1488 before testing any electrical component in the Charging System it is "IMPERATIVE" that you have a fully charged battery of 12.5 volts or more and be able to pass a proper "LOAD" test because your battery may have 12.5 volts or more but little or zero amperage and must be replaced AGM types more so than lead acid batteries.
1. Battery Test:
The battery needs to be a fully charged and load tested to ensure proper readings, connections need to be clean and tight. If you are not working with a fully charged and functional battery, all other voltage tests will be incorrect. Standing battery Voltage should be 12.5-13.2 DCV.
2. Charging System Voltage Test:
Start motorcycle, measure DC volts across the battery terminals you should have a reading of approximately 13.2-15 DC Volts.
3. Connections and wires:
Inspect the regulator stator plug, and check the battery terminals for connection corrosion. If everything seems to be in order, move on to number 4 below to determine if there's a failed component.
4. Stator Checks/Rotor Check: Each of the following tests isolates the Stator & Rotor. If AC output and resistance test fail and stator test passes then the rotor is at fault (Pull Primary covers and inspect rotor for damage).
5. AC Output Check:
Unplug the regulator plug from the stator start motorcycle and change Voltmeter to AC volts. Probe both stator wires with your meter lead. The motorcycle should be putting out approximately 18-20 ACV per 1,000 rpm. Reading will vary depending on system, check service manual specification
Generic Specs:
22 amp system produces about 19-26 VAC per 1,000 rpm
32 amp system produces about 16-20 VAC per 1,000 rpm
45 amp system produces about 19-26 VAC per 1,000 rpm
Stator Resistance Check:
Switch your multimeter to Ohm x 1 scale. Probe each stator wires with meter leads and check resistance on the meter.
Resistance should be in the range of 0.1-0.5 Ohms. Reading will vary depending on the system, check the service manual for specifications.
Generic Specs:
22 amp system produces about 0.2 to 0.4 ohms
32 amp system produces about 0.1 to 0.2 ohms
45 amp system produces about 0.1 to 0.2 ohms
Stator Ground Check:
Probe each stator wire with your positive lead on the multimeter and the negative to ground.
There should be no continuity to ground on either wire.
If there is continuity your stator is shorted to ground and must be replaced.
5. Regulator Test:
Each of the following tests isolates the regulator only, so if any of these tests fail, the regulator is at fault.
Identifying Wires:
Battery Charge Lead- Wire going from regulator to battery positive.
AC output leads- Wires coming from the Stator to the regulator.
Ground- Wire from Regulator to ground or regulator may be grounded via the physical bolting to chassis.
Regulator Ground Test: Ensure the regulator body is grounded or grounding wire is fastened tightly to a good ground (you should verify this by checking continuity from regulator body to chassis ground).
Fwd/Reverse Bias Test/Diode Test:
This check is testing the Diode function to ensure it is regulating the AC current for the stator into DC Current.
Switch multimeter to Diode Scale.
Place your Multimeter positive lead on each AC output wire.
Place your multimeter negative lead on the battery Charge wire.
The meter should read voltage typically around .5 volts.
Next, switch your multimeter leads putting the negative lead on the AC output wires and the Positive lead on the Battery Charge Wire. The reading should be Infinite. With your meter on the same setting, place your multimeter positive lead on the regulator ground wire or to the regulator directly, and then place your meter negative lead on the AC output leads.
Next, switch your multimeter leads putting the negative lead on the regulator ground and the Positive lead on the AC output wires. The reading should be Infinite.
Note: Below is a table to show the readings:
Positive Lead Negative Lead Reading
AC output 1 Battery charge lead Voltage
AC output 2 Battery Charge Lead Voltage
Battery charge lead AC output 1 ?
Battery charge lead AC output 2 ?
Ground AC output 1 Voltage
Ground AC output 2 Voltage
AC output 1 Ground ?
AC output 2 Ground ?
For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
Hartford HD 125S
http://racetechelectric.com/files/pdf/rte_troubleshooting_flow_chart.pdf
Reading Hartford Hd 125 Super 2009 Manuals
CHINESE SC HARTFORD HD 125 LEGION 2005 2009 Spares Parts Accessories
Hartford HD 125S 2007
Jul 11, 2017 | 2005 Hartford HD-125S
Power Supplies Question
Usually, It can measure AC and DC voltage, DC current, and resistance. It also checks diodes, verifies continuity, and tests 1.5 V and 9 V batteries
Aug 27, 2008 | GB Electrical GET-202A Low Voltage Tester
Usage How To
To measure the voltage at an electrical outlet requires the use of a multimeter. Always test your test equipment for proper operation before use. Set the multimeter to AC voltage. The markings may appear as VAC, AC V, or a V beneath a wavy line. Choose the AC voltage closest to the voltage you will measure. Standard current in home and businesses in the USA is in the range of 110 to 120 volts. Some circuits used for equipment such as dryers, air conditioners, electric stoves, ovens and other large equipment may use voltage in the range of 220 to 240 volts. These heavy-duty circuits can be identified by their non-standard outlet plugs. While grasping the insulated portion of the probes (never touch the metal conductor during testing) place one probe into each of the two terminals. The multimeter will display the voltage. Carefully remove the probes, being careful not to touch the metal part of the probes to anything or each other. The voltage should typically test in the range of 108 to 121 volts for most circuits. If voltage is higher or lower, professional electrical service may be required.
Aug 27, 2008 | IDEAL Powr-Glo Audible Voltage Tester
Measuring Tools & Sensors Logo
221 people viewed this question
Top Measuring Tools & Sensors Experts
Vuk B
Tom Chichester
Are you a Measuring Tool and Sensor Expert? Answer questions, earn points and help others
