Question about Acer AL1916 A (Black, Silver) 19 inch LCD Monitor
How to change monitor aspect ratio for acer AL1916
    Problem Solver:
  • 10 Answers
The aspect ratio is expressed as two numbers separated by a colon (x:y). and they actually represent the relation between width and height of (in your case) your monitor.
Did you mean to change the resolution of your monitor? Could you please explain your problem in more detail? What is it exactly you want to achieve?
Posted on Oct 27, 2013
  • 5 Answers
SOURCE: Problems with monitor Acer AL1916w
I'm using the Al1916W and it looks great at 1440 x 990. Make sure you have the latest Screen card drivers installed.
Posted on Apr 23, 2008
skotkolr
  • 558 Answers
SOURCE: aspect ratio
display setting
from the desk top right click and select properties, then select the settings tab then change your screen resolution display setting
Posted on May 08, 2008
  • 3 Answers
SOURCE: Repairing the MB for the (Acer) AL1916 monitor
You can find information in the Acer Al1916v and the AL1916p service guides. These are PDF's and can be found by Google. I cannot find the 1916w service guide either but these two PDF's gave me enough information on how to disasemble the 1916w monitor. Please note that the electronics shown are not for the 1916w. My 1916w monitor has a Delta A190E2 power supply that the Delta site cannot find any reference to. I replaced two blown (domed) CapXon 1000 microfarad 25v dc electrolytic capacitors with better quality caps since this brand is known to be a source of problems. My monitor hissed when it came on and stopped when the screen went dark and the orange light came on. This kind of noise is generally a sign that the power supply is failing and caps that are not domed could also be leaking and about to fail. Replacing the caps solved the problem.
It should be noted that eBay is selling this same power supply for ShopJimmy for about $90.
Posted on Dec 24, 2008
skotkolr
  • 558 Answers
SOURCE: My monitor displays images in stetched full screen format
the description you gave was the long way right click on my computer, select properties then device manager, you will be in the same place but lots faster, plug and play does not identify the monitor or its compatible display resolutions, right click on the desktop select properties then display settings, go into advanced tab and look at the monitor, and the adapter, you can play with the setting until you find one that works, 1400 x 900 may not be supported by the video card(adapter) so that may be why your loosing the video settings.
hope this helps.
Posted on Apr 05, 2009
  • 112 Answers
SOURCE: Acer 22 aspect circle, not elipse
You'll need to change your resolution to one of the below to get the correct aspect ratio for a wide-screen display.
1440 x 900
1600 x 900
1600 x 1024
1680 x 1050
You will find these settings in Control Panel / Display / Advanced. If none of the above are options you will need to obtain newer display drivers.
Please let me know if this helps or if I can be of further assistance. Thank you.
Posted on Sep 19, 2009
Connect my Acer monitor to my digital cable box.
Not sure what your cable box outputs but connect your cable box to a tv and try changing the resolution of your cable box to 1600x900 or less if there is such a setting; the monitor will not display resolutions higher than 1600x900
May 08, 2014 | Acer X203H bd Monitor
I accidently hit recall on my monitor settings. I now have a smaller veiwing screen with black edges
You didn't say which OS you're using but it sounds like you've changed the aspect ratio of your video signal. Different screen resolutions have somewhat different aspect ratios. The aspect ratio indicates the ratio of the number of pixels of width to those of height. For example: my video driver offers a resolution of 1280 x 960 or 1280 x 720 which would give screen aspect ratios of 1280/960 = 1.33 :1 and 1280/720 = 1.77 : 1. The latter would produce a narrower image. You can compensate somewhat by increasing your horizontal sweep voltage with your monitor menu. A better solution would be to select a resolution that more closely matches your monitor's screen size.
Aug 10, 2011 | Dell D1028L 17" CRT Monitor
How can I adjust the aspect ratio on an acer monitor x203h,so a circle looks like a circle and not an ellipse ? qtom@bellsouth.net
Usually under the menu function there is an aspect ratio adjustment. At that point you're going to end up with an 18.5" monitor with black letter box on each side.
May 22, 2010 | Acer AL2016W 20" LCD Monitor
What is the recomended resolution display setting for my Acer X193w monitor
A computer monitor is made of pixels (short for "picture element").
Monitor resolution is measured in pixels, width by height. 640 x 480 resolution means that the screen is 640 pixels wide by 480 tall, an aspect ratio of 4:3. With the exception of one resolution combination (1280 x 1024 uses a ratio of 5:4), all aspect ratios are the same.
Hope this initial information helps. Let me hear from you again for any clarifications.
Thank you for using fixya.com
Feb 23, 2010 | Acer X193W LCD Monitor
Acer al1916 monitor, yellow picture
If your menu button is not working then you cant to do anything. I adviced to you pls check it from service center.
Oct 15, 2009 | Acer AL1916W 19" LCD Monitor
1440 x 900
1600 x 900
1600 x 1024
1680 x 1050
Sep 19, 2009 | Acer 22" X223w LCD Monitor
Icons and screen not sized properly-too big and out of proportion
Right click on your desktop
Click Properties
Click on the Settings Tab
It will say resolution with a sliding bar, you can move that around untill you find the right aspect ratio. Try 1024x768..
Hope that helps let me know :)
Jan 05, 2009 | Acer AL1916W 19" LCD Monitor
How can I change aspect ratio on acer 19"monitor. The picture is not real ..it is stretched Thank You
In the display properties you can adjust your resolution (aspect ratio).
1. Right click in an open area on your desktop and go to properties.
2. The display properties window will appear. Click on the "SETTINGS" tab.
3. You can adjust the resolution one notch at a time to find the aspect you're looking for. NOTE: by clicking on "APPLY" instead of "OK" you can see the affects of your change without closing the window down. This will allow you to easily change it again without having to reopen the display properties windows over and over again.
Hope this helps.
MO
Jul 13, 2008 | Acer Computers & Internet
Screen resizing
hi, try changing the aspect ratio of the player to your suitable needs, commonly used ratio is 4:3.let me know
Jan 02, 2008 | Acer AL1916W 19" LCD Monitor
Aspect ratio
display setting
Sep 16, 2007 | Acer AL2016W 20" LCD Monitor
Acer AL1916 A (Black, Silver) 19 inch LCD Monitor Logo
151 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
