Question about Samsung DV218AEW Electric Dryer
My dryer just quit heating - Samsung DV218AEW Electric Dryer
    New Friend:
  • 41 Answers
This usually means your heating element has burnt out
Posted on Oct 22, 2013
The dryer wont stay on the heating mode
how long does it run before quit heating . unhook dryer vent hose and try with vent discounected
Nov 29, 2013 | Haier GDZ5-1 Electric Dryer
My dryer quit heating and doesn't quit. It keeps tumbling non stop but with no heat.
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101[[]
Apr 20, 2011 | Crosley CDE6000 Electric Dryer
I have a Kenmore Dryer model #110.66732500 that just quit heating. Everything else is working fine, tumbles but no heat. It is 4.5 years old. When it quit it tripped the circuit breaker, we reset the...
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
bn
Sep 28, 2010 | Kenmore Dryers
Replaced heating element for dryer.Dryer started heating for one load. Then quit heating,found wire disconnected-reattatched wire and dryer was working.Now one small load later , dryer quit drying-no hot...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
heatman101
Sep 09, 2010 | Fisher and Paykel DEGX1 Electric Dryer
MY ROPER DRYER QUIT HEATING STILLS WORKS NO HEAT
The thermal cut-off , which is the small t-stat looking piece located at the top of the element housing ( on vertical mount elements ) or the far front of the element housing ( on horizontal mount elements ) , is usually the cause for no heat .
Aug 02, 2010 | Roper REX4634KQ Electric Dryer
Dryer quit heating runs fine it is a gas dryer
Is the pilot light or "stricker" working when you start the unit.. Is it getting good supply of gas?
Mar 12, 2010 | Whirlpool Gold Duet GHW9400P 3.8 Cu. Ft....
My Maytag Clothes Dryer quit heating?
unplug the unit and take the back off.
Apr 13, 2009 | Dryers
Dryer wont heat up already replaced thermal fuse
You gas coils are probably old and weak. check this out
Gas dryer works and quits
Apr 11, 2009 | Whirlpool Dryers
Dryer heats but quit spinning
Your belt has come off or has broken. Do you hear the motor running? If so, then the belt is broke or off.
Feb 03, 2009 | Whirlpool LER5636P Electric Dryer
Gas Dryer quit heating today
Just click below;
If your dryer doesn't heat, check these:
Igniter
Gas valve coils
Thermal fuse
Hope it may help you;
Regards;
VOTIT
Jan 28, 2009 | Whirlpool LGR8648 Gas Dryer
Samsung DV218AEW Electric Dryer Logo
61 people viewed this question
Top Samsung Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Samsung Dryer Expert? Answer questions, earn points and help others
