Question about MSI Laptop Lcd Screen Cr630-228us 15.6 Led Hd
After around 10-15 minutes of using the laptop the screen goes blank and the only way to get it going again it to turn it off then on again
    Problem Solver:
  • 41 Answers
You need to go in your settings and change screen settings they are set to shut down screen in that time
Posted on Oct 22, 2013
I have acer aspire 4520. Whenever i turned on the laptop, the screen will go blank. The power button is still on which means that it wasn't the motherboard problem. Sometimes, the screen turn on but after...
before you change the screen, try to plug the laptop into a monitor or any flat screen tv. are you able to view the image on the tv? if so, your screen is broken.if not, there is something wrong with your laptop and you may want to consider a system restore.
Feb 28, 2011 | Acer Aspire 4520-5582 Notebook
Dell Latitude D620 Screen Goes Black
disable the screen saver mode and check.
Jan 13, 2010 | Dell Latitude D620 Notebook
Screen goes blank during use
Go to your settings menu and adjust the bar that says to turn your screen off after a minute.  If that don't work then have IT open this puppy up and replace the bulbs or inverter.
Oct 31, 2009 | Dell Inspiron 1000 Notebook
Blank Laptop Screen
unplug everything from your laptop unplug the power from the laptop close it and turn it over remover the battery open and hold the on button(battery is still removed) for a 10 count, replace the battery
turn on you can plug the power cord if needed the prob. should be fixed
Dec 26, 2008 | Gateway MX6956 Notebook
Blank screen
Hard to tell from your posting but it sounds like the hardrive my had too much shock or a battery issue, can you hold the IBM key down and get it to load the IBM recovery screen?
Oct 28, 2008 | IBM ThinkPad T23 2647 Notebook
Blank screen
Hi
Its inverter or mother board problem power which passes to backlight is cutting off because of over heart (over heart of some IC).
Thanks
Sep 16, 2008 | HP Compaq Presario V2000 Notebook
TV screen goes blank but power stays on
Sounds like the CRTs are going into protective blanking due to the vertical output ic needing to be resolderd. Try resoldering the vertical IC that may possibly fix the issue.
Jun 15, 2008 | Mitsubishi WS-73713 73" Rear Projection...
Open Questions:
Cervical Cushion- Pillows for Neck Pain Are you a very sedentary person? Do you have a classic office job and are 8 hours or more sitting in front of a computer? Then you most likely suffer from cervical pain. Cervical pain means having severe pain in the neck area because of an incorrect position of our cervix for quite some time. The cervical block or its numbness is due to the unnatural compression of the vertebrae. In this guide you will find all information about cervical pain, how to prevent them and how to cure them, but above all you will learn how to choose your cervical cushion that will help you lessen the pain or make it disappear completely. In the following table you will find some models of cervical pillows that can be found on the market, along with some of the major features that distinguish them. How to Choose a Cervical Cushion Since on the market you can find a great multitude of cervical pillow models, choose the most suitable one and certainly not a small business. First of all, choosing the most appropriate one is to understand what pathology you are suffering from. Although we often call it neck pain, cervical is not always the same in all cases. In this regard, it is understood that not everyone can use the same cushion. There are cases where the patient needs a more flexible pillow, others where there is a need for stiffer material, so before buying your new cervical cushion it would be interesting to consult your trusted physician, who can visit you and decide for you what is best suited to your pathology. Another factor could concern the price, but being in the medical field I recommend closing an eye on this item, ten euros more or less are nothing when it comes to health. Moreover, the price is directly proportional to the quality of the material used and of course there are materials that cost more than others. So as you see there are several factors to consider. Take care of all the advice you'll find on these pages and you too will be able to make the right choice. What is cervical pain and remedies? The area of ??the cervical vertebrae is that portion of our body that accuses so-called cervical pain when our neck or our head is in an incorrect position for several hours. This area is very important for our health and our well-being. In practice it connects our body and especially the spine to the head, with all the nerve endings that pass right in this particular area and very sensitive. When this area is subjected to a continuous stress, we do not only pain neck pain, but we also compromise the proper functioning of the head movement. Very often the pain becomes so strong that besides affecting the neck, it moves to the upper shoulders and joints, causing the famous head turns and also nausea. In the most severe cases a capatina is recommended by your doctor. Among the various factors that can trigger these severe pains are incorrect posture or an improper pillow. At the origin of this evil, however, there are also muscle contractions, trauma and stress. For this reason, the cervical pillow was born, which relieves the pain and allows the neck to be in the correct position. Structure, shape and material are designed to fit perfectly to the shape of the neck, sustaining it and giving it relief.
Oct 23, 2017 | Major Computers & Internet
See all MSI Laptop Lcd Screen Cr630-228us 15.6 Led Hd Questions
MSI Laptop Lcd Screen Cr630-228us 15.6 Led Hd Logo
32 people viewed this question
Top MSI Computers & Internet Experts
vsri9
David
David
Matthew Spark
Matthew Spark
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
