Question about Necvox RE8269 Car DVD Player
No disc message and no motor sound - Necvox RE8269 Car DVD Player
How do I repair so I don't get "no disc" message?
Could be dirty or faulty laser, faulty decoder board or motor not spinning the disc.
Sep 06, 2014 | Pioneer Elite DV-46AV DVD Player
Get no disc found when loading any disc. Someone suggested lubercating the disc drive motor.
Hi, A suggested tip may help, but please observe the sound on disc drive motor. If there no sound, your motor is not work. If there is very loud sound, you may need lubricated it by special motor grease ( don't use a common grease as it can short circuited the motor). If the motor works, but it is not load any disc, the problem is on your lens and is not on motor. Please clean your lens and retry. If still problem, you need to replace the lens with new one.
Regards, vote please, Jay
Jan 23, 2011 | RCA RC6001P DVD Player
"No Disc" error message
A no disc error on any electronics device indicates one of three problems. 1. The disc reading lens in the cd/dvd/brd drive has gone out or is dirty. 2. The drive has a "stabilizing" screw that must be tweaked. 3. The disc is not spinning due to a bad motor on the drive or something is blocking it. If you can hear the disc spinning *whizzing sound* its not a motor issue. You can try running a cd lens cleaning disc but if its not registering it probably wont spin, thus wont clean the lens. You can attempt to clean a lens with a cotton Q tip and rubbing alcohol but be warned, touching the lens can scratch it and destroy it. If your object is not under warranty you can have a professional look at the drive to check the tension on screws, this is usually a huge problem found in XBOX 360's. Make sure its not the disc by trying other working games/movies/etc. If all else fails you can always purchase a new dvd/cd/blu ray drive and have it professionally installed. Xbox 360 $20-$40, PS3 $100-$150 Although its not common, another solution is that cables on the drive might be loose, but usually you cannot open the device; the two cables are power approx. 1-1.5 inches long and the output plug which is usually half the size.
Jan 09, 2011 | Video Game Consoles & Games
Disc loads from carousel and carriage engages disc but will not spin up with a no disc message on screen
sounds like the laser is dirty or has gone bad also could be the the little electric motor has gone bad better off getting a new one
Dec 13, 2010 | JVC XL-MC222
I have put in a dvd into the slot, it will not play, the message saying self check keeps displaying
Hi
Assuming that the machine accepts the disc in and begins to spin the disc, you will hear a spinning sound, and goes no further than this point, it would suggest the optical pick up is unable to read any data on the disc or the spindle motor is unable to spin the disc to its correct velocity, it is more than likely the laser has failed, either way the machine needs to be serviced.
Regards
TechSupp12
Dec 12, 2010 | Panasonic Televison & Video
Getting "can not play disc" message from sony DVP-NS725P dvd player.
Have you tried taking off the cover to see if the disc is spinning inside when you get this message? The motor that spins the disc could be shot.
Sep 04, 2010 | Sony DVP-NS725P DVD Player
DVD spinning slow and get a 'No Disc' message
The problem sounds like the spindle motor is about to go out completely. If a disc does not spin or does not spin at it's proper speed the optical lens reading laser can not read the disc and you get a "no disc", or "disc not recognized" error message. On average a dvd will spin 3 times faster than a regular cd will. The following pictures will show you what these components look like.
Check around your local area to find what a service technician will charge to replace the part. On average it will usually cost between $60-90 dollars most of which is labor.
I hope this gives you some idea of what the problem is and how to solve it.
If you would not mind, please rate my help. I would greatly appreciate it. Thank you
Feb 07, 2010 | Televison & Video
Always gives the message bad disc
either the disc motor is not running up the disc speed fast enough,or the laser is burnt out.run it with the cover off and look at the disc speed.it should be about 500rpm
Jan 10, 2010 | Cyberhome CH-DVD 300 DVD Player
Disc loads, makes click click sound then message no disc
that click click is the laser trying to focus and it is hitting the disc.
the biggest failure is the disc motors.they are very tiny motors and if they do not spin fast enough,the laser can not get the info it needs.
sometimes banging on it lightly while it is focusing will get the disc to spin.
with the price of new ones,it is not worth repair.
that is why i got out of the repair biz in 1995
May 09, 2009 | Polaroid TDA-03211C 32 in. LCD HDTV
Discs will not play.
Could be some dirt on laser lenses. Try to clean it.
Sep 25, 2007 | NAD C541 CD Player
Necvox RE8269 Car DVD Player Logo
Top Necvox Car Audio & Video Experts
xxxxxx xxx
Are you a Necvox Car Audio and Video Expert? Answer questions, earn points and help others
