Question about Turtle Beach Ear Force PX21 Gaming Headset
Can't hear out of my speakers or headset - Turtle Beach Ear Force PX21 Gaming Headset
How do i fix the volume because i do not have sound? my tv has no volume/sound. tried turning the tv up and down but still no sound
1 - hi
2 - check the jack for headset
- if you heard any sound with headset = your speakers are burned
3 - if you always use this jack for head set its maybe got problem = when push or pull the headset jack if you hear any sound from speakers your headset socket should change
4 - if you didnt hear any sound from both (speaker and headset) it means your ampilifire should repair
May 23, 2010 | Emerson CR202EM9 TV
My headset is grounded
pushing the jack hard may result in some connections pushed way off, and there is no contact to the speaker. Please see the nearest technician.
Jun 12, 2009 | Cell Phones
Headset & speaker both are playing at same time
Most probably headphone socket in the laptop is dirty. Spray some WD 40 or replace it.
May 20, 2009 | Logitech 250 Headset
Simultaneous audio through headset and regular speakers?
This is not possible with Windows. You would need to purchase a mixer program of some sort. The USB headset is seen by the Operating System as a stand alone sound card. Windows will not mix two sound cards.
Mar 07, 2009 | Logitech ClearChat Pro USB Headset
Computer headset problems
It sounds like something in the control panel on your computer, Go into the sound settings and pick your device.
Below is the link for Explorer 300 Series User's Guide.
Plantronics Explorer 300 Series User's Guide
Good luck from Headsets Direct!
Jan 17, 2009 | Plantronics Explorer 330 Headset
Skype does not recognize my Microphone
not all headsets are compatible with Skype. You should be able to check online on their website as to whether or not that particular set you have is compatible.
Dec 24, 2017 | Computers & Internet
No more sound from speaker
I had a similar issue on mine. The easy fix was to insert a headset jack and pull it out quickly. I think something got stuck that turns off the speaker after I put the headset in the jack once. If this is the problem, I think you should also see a headset icon when making calls, even though no headset is attached.
Jun 15, 2007 | Sprint Vision PPC-6700 Smartphone
Motorol HS820 Speaker issue
User "Nitol" seems to be having the same problem with this headset. I'd recommend calling motorola support, see what they think of it. If you're lucky, they'll recognise the apparently common probem and help you out.
Apr 06, 2007 | Motorola Mobility HS820 Consumer Headset
Turtle Beach Ear Force PX21 Gaming Headset Logo
13 people viewed this question
Top Turtle Beach Radio Communications Experts
eradiostore
eradiostore
Are you a Turtle Beach Radio Communication Expert? Answer questions, earn points and help others
