Question about Konica Minolta Office Equipment & Supplies
KM Bizhub c360 slow fax transmission
I faxed 48-pages and it took nearly two hours to complete the fax transmission. Simple black and white pages with no pictures/color... Our copier guy has no idea how to solve the problem
  • 63 Answers
Turn error correction mode off - will lose some quality but will speed it up
Posted on Oct 22, 2013
SOURCE: Canon Pixma MP780 Fax Problem (horizontal line)
Solution is here: http://www.fixya.com/support/t136826-printer_problem
Posted on Aug 22, 2007
  • 82 Answers
SOURCE: Extremely slow copying
Cartridges may give a very slow printing if internally damaged, or :
When using colored paper in the all-in-one, printing or copying is slow.This issue is a result of the automatic paper type sensor misreading the colored paper as photo paper. The print out takes longer because the unit is printing in Best mode instead of Normal mode.
  1. Click Start , point to Settings , and then click Control Panel .
  2. Double-click Printers and Faxes .
  3. Right-click the appropriate all-in-one, and then click Printing Preferences .
  4. Click the Paper/Quality tab and under Type is: select Plain Paper . This sets the default paper type setting to Plain Paper.
Hope this helps.
Posted on Jan 05, 2008
Nitrotrike
  • 589 Answers
SOURCE: printing confirmation page after completed fax
If you have the operators manual (it may be in the back compartment of the machine), look in the index for "fax parameters", then "fax reports".
Posted on Jan 10, 2008
SOURCE: Hp K80 printer
I had the same problem, and it seems to have corrected itself. I too, installed a new "45" black cartridge and got the message to remove and check color cartridge. After I removed it and cleaned it the message stayed on the display for about 5 minutes and then asked me to "align cartriges." After I aligned them I had no problems.
Posted on Jan 25, 2008
SOURCE: BizHub 350 Network Fax - Prints instead of faxing
Set the Gateway TX to "Allow"
1. Press the Utility/Counter button.
2. Touch Admin Management
3. Enter Password (The default password is 12345678)
4. Touch Admin2
5. Touch Network Settings
6. Touch Network Settings1
7. Touch Scanner Settings
8. Touch Gateway TX
9. Set Gateway TX to Allow
Posted on Jan 16, 2009
Bizhub 350 cannot receive faxes
There are two clips on the fax PCB, make sure you are using the Line and not the handset. Also, do you have the fax card installed and did it ever receive faxes? It may be a issue with the phone line.... Good Luck
Nov 16, 2012 | Minolta bizhub 350 Black and White Copier
Help with Sharp Fax UXP100 . When sending a fax they are going very, very slow. What should I troubleshoot? Thx
Check your phone line by removing fax and plugging a normal handset into the line socket and then listen to line. If a line has noise on it, it will slow transmission down, it can also cause wiggly lines on transmitt and receive, if this is the case, it needs to be dealt with by your phone line provider, just report a noisy line
Having the machine set to fine in transmission settings can also cause slow faxs, and a dirty scanner glass can also cause receiver image to have marks on received image but it is normally marks down the page
hope my good deed free for the day helps.
cheers
Soulvisitor
Nov 22, 2011 | Sharp Office Equipment & Supplies
How to change email addfress for fax
Instructions for registering and editing the address book (fax, email, scanning destinations) can be found on page 5-21 of the advanced operations guide wich can be down loaded from the following link; http://usa.kyoceramita.com/americas/jsp/Kyocera/resource_details.jsp?pid=14173&rid=14774. THe KM-1820 and CS-1820 are the same machines and this link is for the KM-1820.
Jan 17, 2011 | Kyocera Copystar CS-1820 Black and White...
Bizhub 161f not always answering an incoming fax...2nd try works but not always? Using the avaya phone system.
Avaya is a DIGITAL phone system, all fax machines are ANALOG. You nes a regular phone line for your fax
Jan 08, 2010 | Minolta BIZHUB 161F Black and White Copier
How can I print a fax confirmation on a specific outgoing fax
Checking a report for the transmission result (?TX Report? function) A report containing the transmission results can be printed. The machine can be set to either print or not print the transmission report or to print it according to the machine setting or only when a transmission fails. To print the transmission report 1 Press the [Fax/Scan] key to display the Fax mode screen. 2 Touch [FAX Menu]. 3 Touch [TX Report] on the Set 1 tab. 4 Select how to output the report, and then touch [Enter]. ? Default: The transmission report is printed according to the previously specified method. For details, refer to ?Specifying report output settings (Report Settings)? on page 10-48. ? ON: The transmission report is printed with each transmission. ? If TX Fails: The transmission report is printed only if the fax could not be sent. ? OFF: The transmission report is not printed, regardless of the transmission result.
Aug 10, 2009 | Minolta bizhub 200 Copier
Does not scan pages until it makes connection
yes, the solution is that you are direct sending the faxes instead of scanning into memory which will start and complete the scan of all the pages as it begins dialing and transmitting. there should be a key on the control panel for memory or memory transmission, select it and your done.
mikey
Mar 14, 2008 | Brother IntelliFAX 4100 Laser Fax
200 page fax sent to me incorrectly
turn the machine off, hold down the stop button and turn it back on, this will clear the memory
Jan 29, 2008 | Brother FAX-2920 Plain Paper Laser
Printing problem
Are the problem prints all from the same source? If so the problem could be on the transmission end. Can you connect to your fax and print to it from a local workstation? If so print several images with dark solid patterns and see if it is actually the printhead. Try printing in cyan, magenta, yellow, and black colors to to rule out each individual printhead.
Jan 03, 2008 | Sharp UX B700 Plain Paper Inkjet Fax
76 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Ben
Ben
David Burkhart
David Burkhart
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
