What does Hp model grlyb0311 fit to? - Office Equipment & Supplies
    Novelist:
  • 140 Answers
It looks like the item you got needs to be used together with a normal scanner. From the description i found the item you have is a so called transparent media adapter and in being so just provides a backlight so that a scanner can scan negatives and slides. These are the models i found that support your item:
Scanjet 4600, 4670, 4600p, 4670v and 4670vp
Posted on Oct 23, 2013
Are the HP pen models DG937A and 441147 interchangeable with one another?
No. Models before the TC1100 used finepoint pens, while the TC1100 model started to use Wacom pens. Any wacom pen will work, but may not fit into the silo.
Mar 25, 2016 | HP Tablets & eReaders
HP 3390 control panel
a common fault on this and similar models, I presume the printer is still working ok?
the way to fix is to replace the entire controlpanel which comes as a single assembly- easy to fit, not overly costly to purchase, comes with good fitting instructions straight from HP, although I suggest if the printer is ok and you can still read the display- you should leave it as is.
Mar 18, 2014 | HP LaserJet 3390 All-in-One Multifunction...
How does a hp pavilion a1514n desk top sound card look like and instaled
your model of PC doesn't have a sound card; the sound hardware is built onto the motherboard and cannot be removed. You can add a sound card n one of the additional PCI slots however, for example see
http://www.pixmania.co.uk/sound-card/asus-xonar-dg-5-1-sound-card-pci/08184127-a.html#description
Lots of pictures on this page
http://www.ebay.com/sch/i.html?_odkw=hp+sound+cards&_osacat=0&_trksid=p2045573.m570.l1313.TR0.TRC0.H0.Xhp+sound+cards+pci&_nkw=hp+sound+cards+pci&_sacat=0&_from=R40
Ensure that any card is not too long or too high to fit in your particular PC
For instructions on fitting (physically) one of these cards see
http://h10032.www1.hp.com/ctg/Manual/c00311110.pdf
Look here
http://www.youtube.com/results?search_query=fitting+soundcard+to+desktop
for videos of the fitting procedure and even how to choose a card. Any of these will show the fitted sound card as well as how for a range of desktop PCs to do it.
12.April.2014
Dec 11, 2012 | HP Pavilion a1514n (EX269AAR) PC Desktop
How to do a quadratic regression?
I am sorry to say that natively the HP 49G+ does not perform quadratic regressions. The models that are vailable are Linear fit, logarithmic fit, exponential fit, power fit, and best fit.
These options are available under Right SHIFT (Orange) 5 (STAT)>3:Fit data.
Feb 25, 2012 | HP 49g+ Calculator
What engine other original will fit in mower?
Nearly any single or twin cylinder engine with the same configuration (ie. vertical shaft) will fit under the hood of a craftsman that used to run 20 HP.
Jul 26, 2011 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
JUST FITTED NEW COMPUTER AND HAVE LOST CD TO INSTALL hp 3310 all in one printer
hi, you can go to the HP website, and download your drivers from there.
go www.hp.com
then select support
then select the drivers options and put your model #
download the file for the appropriate operating system.
Feb 16, 2010 | HP Photosmart 3310 All-In-One InkJet...
Can this HP Pavilion DV9000 laptop adapter fit for Compaq Presario V3000 laptop? I doult that HP Pavilion DV9000 laptop adapter on website:http://www.laptopbatteryshop.ca/hp-pavilion-dv9000-ac-adapter.htm...
Have a look at the label on the bottom of the V3000 laptop and check the voltage and amps power rating of the laptop.
If the DV9000 adapter has the same voltage and current rating (amps) or higher amp rating then it is suitable for the V3000 laptop, provided the power plug fits the V3000 power socket.
Jan 15, 2010 | Dell Inspiron 1525 Laptop
Which HP printers use #56 & 57 cartridges ?
Fits Models: Deskjet 450cbi ... 1350 PSC ( 57 56 HP C6657AN Ph C6656AN 57 56 HP C6657AN Ph C6656AN 57 56 HP ....
Hope this helps. Bud
Jan 09, 2009 | HP DeskJet 5150 InkJet Printer
44 people viewed this question
k24674
jasbo
jasbo
