Question about Whirlpool Washing Machines
I started the washer. It filled, then nothing. Outlet has power.not sure wher to look next.
    Sergeant:
    Champion:
  • 257 Answers
Need to know what unit is (top/front load)
If top load, the timer may bad. If front load, the pressure switch does not trigger, check it out.
Posted on Oct 22, 2013
  • 311 Answers
SOURCE: Washer fills with water - then nothing at all. Power in outlet
Check to see if lid switch is closing. Should at least hear a click from it when lid closes. Test it with a meter. I cannot see your repyl due to some tech issue w/ the site, so it may be a day or so before I can reply again. Please leave feedback for me if appropriate. Thanks
Posted on Nov 28, 2008
rpbuice
  • 161 Answers
SOURCE: Washer will fill up but after that nothing happens?
The lid switch is my first thing to check. There are two wires going to this switch, jump these together and this will tell you if it is working. The clicking noise won't tell you for sure.
Next, you need a volt meter to see if power is getting to the motor, if so, you have a bad motor.
Posted on Jan 23, 2009
sp4m771
  • 116 Answers
SOURCE: why did my LSE7806ACE WASHER STOP FILLING
Check out this: http://www.rd.com/advice-and-know-how/clothes-washer-filling-slowly-or-not-at-all-fix-it/article10811.html
Posted on Aug 14, 2009
  • 121 Answers
SOURCE: The washer filled up with water and stopped, I
you have something in your pump and is stopping the motor from running. you will need to remove the cabinet to repair this unit.
Posted on Oct 16, 2009
jsrock516
  • 5911 Answers
SOURCE: Washer filled with water..........then nothing.
If this a Whirlpool manufactured top loader, the most common cause of the problem you just described is a lid switch malfunction or lid strike (actuator) problem. Symptoms may include, filling and stopping on the intial fill cycle, stopping right after the wash cycle, not advancing to rinse or spin cycles, and a wash tub that will not drain.
The lid switch is usually mounted under the washer top casing, on the right hand side on most top load models. It is activated by a plastic piece on the lid (called a "Lid Strike" or "Actuator") through a small hole on the rim of the wash tub opening. In many cases the lid strike breaks off the lid, or the lid switch becomes loose and no longer makes contact. Inspect the lid to make sure the lid strike is still intact, and then inspect the mounting screws (adjacent to the small opening on the wash tub rim) and make sure they are snug. If you determine the switch to be defective, the following link explains how to replace one:
http://www.fixya.com/support/r3557193-replacing_a_lid_switch
On some models, the lid switch is located under the top casing by one of the lid hinges. You will know if you if you have this type of switch, because it does NOT have a lid strike (actuator) and the small hole on the right hand side of the wash tub will not be present. This type of switch is actuated (toggled) by a rod on the lid hinge. With this type of switch, if you locate it and it can be toggled by hand, you may only need to adjust the actuator rod by bending it slightly.
NOTE: You do not have to drain or bail the water from the washer tub to perform this repair. Once a defective lid switch is replaced, the washer should drain normally.
Replacement parts (if required) can be purchased at any of the following web sites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
The average price of a replacement lid switch is about $25 - $35 if you perform the repair yourself. Prices will vary between sites so shop and compare.
If you have questions, or need additional assistance, please post back and let me know. This is a very simple repair that you can easily perform without the assistance of a repairman.
If this advice does not help you enough, repairclinic.com has a Repair Manual you can order to assist you with all your repairs. The part number is 1170635 and is priced at about $20.
Searspartsdirect.com also has a repair manual for about the same price. Part number 4314044L. I hope this information is helpful to you.
Posted on Sep 23, 2010
Why wont my power washer start
First, make sure its plugged in and that the outlet has power to it, if still no luck open up the body of the power washer and check all of the internal connections to make sure nothing was compromised.
Aug 13, 2014 | Garden
I has a Crosley Washing Machine Top Loader. Fill light comes on lid locks then NOthing!
seethis causes and fix it. God bless you
User Control and Display Board If the washer won't start, the user control and display board may be defective. Check for power to the washer first.
Timer If the washer won't start the timer might be defective. This part is often misdiagnosed, check other components before replacing this time
Line Fuse If the washer won't start the line fuse might have blown.
Thermal Fuse If the washer won't start the thermal fuse may have blown. It can be tested for continuity. Watch our fuse testing video for more information.
Line Fuse and Holder If the washer won't start the line fuse might have blown, or the line fuse holder might be damaged and need to be replaced.
Main Control Board If the washer won't start the main control board might be defective. This is not common. Check other parts and causes first.
Door or Lid Latch Assembly If the washer won't start the lid switch assembly might be defective. This is a very common problem. The lid switch assembly can fail either mechanically or electrically. Test any electrical switches with an Ohm meter for continuity. The switches should have continuity according to their design.
Door Lock Motor and Switch Assembly If the washer won't start the door lock assembly should be checked. The door lock can fail either mechanically or electrically. Test any switches on the door lock with an Ohm meter. The switches should have continuity according to their design.
Incoming Power Problem If the washer won't start check to see if there is power at the electrical outlet which the washer is plugged into. Plug a lamp or radio into the outlet to check it. If the outlet is dead, check the circuit breakers or fuses for the hom
Power Cord If the washer won't start, check to be sure there is power to the electrical outlet for the home. If that is OK, the power cord itself might be defective. This is rare. You can check the power cord with an Ohm meter for continuity.
Oct 02, 2012 | Crosley CCW5294W Top Load Washer
I was going to wash a load of towels and the washer filled up but I realized it wasn't enough water in it so before I could set the dial for more water, it stopped filling up so I set the dial for more...
Look around at outlets that are close by and make sure you didn't trip one of your GFCI breakers or plug in something to the same outlet and make sure you have power at the outlet where the washer is plugged into.
May 30, 2017 | Maytag Legacy Series Top Load Washer
My washing machine won't star
Thanks for choosing FixYa and welcome. If you have a washer that won't start, here are some probable causes to your problem. First, make sure to check your breaker box for a tripped breaker. If nothing is tripped, you will want to make sure the washer is getting power first. You need to check the wall outlet and the power cord. You can properly test both of them with a voltage meter to make sure they are getting correct power. Wiggle the cord and see if you can get it started. You could have a break or loose wire in the cord causing your washer to not start. If it starts, you still need to change out the power cord. If the outlet is not getting power, you will need to conduct a test on that to determine the cause. You may have a bad wire or a loose wire. If you have power to the outlet and cord, make sure your fuse has not blown. You need to check your timer switch next. It may be bad or not working properly. Refer to your manual for the correct procedure. Try the washer on different cycles to see if it will start. It is possible that you have a bad lid switch. It can cause the washer to not start if it is bad. You could have a defective motor as well. If the motor has not been working correctly or making noises and other sounds, there is a good chance it has finally died out. Always make sure that the part is getting power before you change it. A voltage meter is an ideal tool to keep around the house. If a part is not getting power, even with a new part, it will not work. Make sure you test everything before making a decision. Always determine the cause by testing and not guessing.
Jul 10, 2011 | Kenmore 24032\24036 Top Load Washer
The machine will not start.Is there a resart button
Thanks for choosing FixYa and welcome. You can unplug the washer for a few minutes to reset the washer. Meanwhile, you can check the following. If you have a washer that won't start, here are some probable causes to your problem. First, make sure to check your breaker box for a tripped breaker. If nothing is tripped, you will want to make sure the washer is getting power first. You need to check the wall outlet and the power cord. You can properly test both of them with a voltage meter to make sure they are getting correct power. Wiggle the cord and see if you can get it started. You could have a break or loose wire in the cord causing your washer to not start. If it starts, you still need to change out the power cord. If the outlet is not getting power, you will need to conduct a test on that to determine the cause. You may have a bad wire or a loose wire. If you have power to the outlet and cord, make sure your fuse has not blown. You need to check your timer switch next. It may be bad or not working properly. Refer to your manual for the correct procedure. Try the washer on different cycles to see if it will start. It is possible that you have a bad lid switch. It can cause the washer to not start if it is bad. You could have a defective motor as well. If the motor has not been working correctly or making noises and other sounds, there is a good chance it has finally died out. Always make sure that the part is getting power before you change it. A voltage meter is an ideal tool to keep around the house. If a part is not getting power, even with a new part, it will not work. Make sure you test everything before making a decision. Always determine the cause by testing and not guessing. Thanks for choosing FixYa and best wishes.
May 16, 2011 | Hotpoint Ultima WF860 Front Load Washer
Washer overflowed while filling for wash cycle.
A quick test to split up your possible trouble makers:
Let the washing machine fill with water and when the washer is about 1/2 full of water unplug the washers power cord from the wall outlet. If the water keeps flowing into the washing machine with the power cord pulled the fill valve ( where the hot and cold hoses are attached to your washer ) has mechanically stuck open and will have to be replaced. If the water shuts off when you remove it's power cord from the wall outlet, try plugging the washer in and out a couple more times and if the water stops each time the fill valve indicates as being good = on to the next trouble makers.
The water level control is responsible for shutting off the power to the fill valve and redirects the power to the timer to start the washing machine running once the correct water level has occurred. The WLC itself could be bad. The WLC uses a hose that the water level pushes air into to tell the WLC what the water level is inside the washing machine...the hose could be pinched, fallen off of the tub spout, has a pin hole, clogged up with calcium or soap curd and the WLC cannot "sense" or "tell" what is happening inside the washer.
Nov 27, 2009 | GE Washing Machines
Jan 23, 2009 | Kenmore Washing Machines
Washer wont do anything after it fills
try your outlet,,plug something else there to see if you have current if so make sure breaker is 15 amps or better with washer on line alone..if good bad door switch..
Dec 25, 2008 | Indesit W 123 Front Load Washer
Maytag HAV2360AWW will not start
Check the back of the lid their is a litel plastic button to make sure the lid is closed see if not broken or stack
or see if drain pomp V belt is out of place or broken
this is the simple way
Dec 19, 2008 | Maytag HAV3460AWW Top Load Washer
Washing Machines Logo
22 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
