Question about Garden
Kohler k321 engine
Don't now how to set timing
  • Garden Master
  • 2,478 Answers
Go to repairclinic/kohler-small-engine-parts-fastener Then scrool down flywheel key. Then click on video. It show how.
Posted on Oct 23, 2013
  • Dennis Key
    Dennis Key Oct 24, 2013
    www.repairclinic.com/Kohler-Small-Engine-Fastener-Parts
John Deere 214 with Kohler K321
Check carby is not to rich,"mixture screw" check for fuel blockage on fuel tap.
Sep 27, 2016 | John Deere Garden
Won,t run because breaker points don,t open in Kohler engine
I am guessing you are working on a K model engine because I believe that was the last model to use points. Sometime they arc and weld together and the rod just bends them . This U Tube video is the best way to inform yourself for this repair. How to adjust and set Points Gap on Kohler Engine
May 21, 2016 | Garden
Set timing of crank and cam shafts on a Kohler K161 engine
Since there different versions with and without gears it is best to read and following the instruction in the service manual.
Kohler K91 141 161 181 241 301 321 341 Service Manual pdf Google Drive
Oct 25, 2014 | Toro 42 In Deck 19 Hp Kohler Courage Twin...
Kohler k321 cast iron line vibration how to fix
see if motor mounts come loose the engine dont have heavy vibration take to dealer look for crank bearing is bad or rod is loose let dealer check for this hopefully just loose motor if short block 400.00 to 600.00 dollares bad situation think about buying new motor think this over or maybe if old mower replace it
Sep 01, 2014 | Cub Cadet Garden
Kohler engine 241 as no spark
there is a piece next to the flywheel tha has a magnet and grabs resistence that may need replacing. I had this happen on mine. call your local repair shop and ask. I found the answer to mine on youtube and replaced it in about an hour,
Jun 29, 2012 | Kohler Garden
Need to find proper carb needle valve settings for case 444 Kohler
This is the Kohler K321 engine.
You can find the service manual here: (14.16 mb)
http://www.kohlerengines.com/onlinecatalog/pdf/tp_2379.pdf
The inital carb adjustment setting procedures start on page 29
Kohler carb low idle 2 1/2 turns from closed Walbro carb 1 1/2 turn from closed
Kohler carb high idle 3 1/4 turns from closed Walbro carb NA
Thanks for choosing FixYa,
Kelly
Jul 08, 2011 | Garden
Need wiring diagram for kohler 12.5 engine and
A FREE download of the entire Kohler Service Manual for your engine is available as of 1-29-2010 on the net in the form of a pdf. I don't know how long it will remain available but as of today you can still download it allowing you to reference the area of your concern using the address; www.asberry.net/files/TP-2339-D.pdf. This pdf contains the entire Service manual for your engine. However, it is 147 pages long and if you don’t start with at least a half full cartridge it may drain your black ink cartridge. I downloaded this Service Manual for my Kohler 12.5 engine to help me fix a charging problem and it was a bargain because the download was FREE except for the ink and 147 pages of paper.
Oct 10, 2009 | Garden
Electrical wiring for kohler engine
I have a Ford LGT with a 14 hp Kohler K321AS engine. Go to Kohler.com and download the service manual for the K321 engine. The manual covers all of the K type engines and gives diagrams and details of all the different types of ignition and electrical systems. It is free. JS
Jun 01, 2009 | Kohler CH25 PA-CH730-0040 Command Gasoline...
Kohler k321as engine- misfiring.
sometimes there is a adjustment screw that you can turn just like a car.CAREFUL NOT TO TURN TO MUCH.to burn lean or rich.also you might want to change the fuel and air filter's first,then try to adjust.
May 25, 2009 | Kohler CH25 PA-CH730-0040 Command Gasoline...
Garden Logo
57 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
