Question about Hunter 23852 Classic Original Ceiling Fan
Need a replacement fan switch for model 22272 where to purchase part
Where can I purchase a replacement fan switch knob
What is the make/model of fan? What's a switch knob. Do you have a picture? fanman9952@aol.com
Aug 27, 2014 | Dryers
Hunter 22272-001
If the oil is OK then check to see if it has a capacitor that might be going bad.
Dec 27, 2013 | Hunter 23852 Classic Original Ceiling Fan
Hunter original old thyme model 22272 wiring diagram
the (white) wire is likely the neutral, red - low speed, blue - high speed.they would typically be connected thru a selector switch. however, best guess is that white would hook to incoming white neutral, and blue (or red, but not both at the same time) would hook to incoming black (hot) wire.
Jan 26, 2013 | Heating & Cooling
I need to replace the pull chain that controls the blade speed for my Hampton Bay ceiling fan. I do not know the model number, but it is a 52" five-blade fan.
If the chain is broken off at the switch, you will need to replace the entire switch. It is not difficult to do and you can purchase a new switch from either Lowe's or Home Depot. You''ll find the switch in the ceiling fan department.
All you need to do, to remove the switch is remove the bottom cover of the fan housing, where the switch is located (if you have a light kit, you will need to remove it). This will give you access to the wiring and the switch. The switch is held in place by a threaded retainer ring on the outside of the fan housing. Unscrew it and push the switch back into the housing, Disconnect the wire nuts and totally remove the switch. Take it with you, when you go to purchase a new one.
If the chain is still visible by at least 1" all you need to do is purchase a new chain (usually comes with connector) and connect the two together.
As always, be sure the electricity is turned off to the fan, before attempting any repairs.
Hope this helps solve your problem.
Mar 02, 2011 | Hampton Bay Heating & Cooling
My Hampton Bay Windward II
I need a fan chain pull switch for my Hampton Bay 5 Blade Model 552 od--
SKU # 409-952----
MFG # 5A00007
SER # 720275940415653B
The switch controls High,Medium,Low Speed and Off.
4 Wires--Black,Brown Purple and Gray are connected to awitch, they come from a Block Capacitor (4.5mf,6mf and 5mf)
This fan was purchased around 1995 and is in good condition but needs this replacement switch---
Where can I get the replacement for this model?
Apr 19, 2009 | Hampton Bay 24002 Ceiling Fan
Aloha Breeze Ceiling fan M# 29081, Fan Switch Problem
call 1-800-295-4448
you need a switch from them the internal mechanism is different. its free of charge
Nov 14, 2008 | Aloha Housewares (93645) Ceiling Fan
Fan switch broken, wires out when opened
I googled Hampton Bay Manufacturing and this is what I found:
Hampton Bay fans are manufactured by "King of Fans Manufacturing, FL". The contact number for them is 800-330-3267. ...
Maybe they can supply you with a wiring diagram.
Jun 08, 2008 | Dryers
Hunter 23852 Classic Original Ceiling Fan Logo
24 people viewed this question
Top Hunter Dryers Experts
Paul Bade
Thomas Perkins
Thomas Perkins
Are you a Hunter Dryer Expert? Answer questions, earn points and help others
