Question about Vizio E422VL 42 in. LCD HDTV
Hello, My name is Jeff, I am a Tv repairman. I have a Vizio E422VLE LCD. The problem is it will not stay on, it will just shut itself down completely, even the VIZIO amber light goes out too. have to wait a Day before it will come on again. Runs for about 10 seconds. Please Help, Any suggestions? Thank you
  • Jeff Nelson Oct 22, 2013
    Loose Solder Connection Just above the main microprocessor on the main board. That's the Fix. Thank You.
  • 221 Answers
Sounds like either the switch relay or the inboard circuit breaker has gone bad.
Posted on Oct 23, 2013
SOURCE: no picture or sound, light comes on in the front and have to unplug tv to turn it off.
I had this exact problem on my Vizio 47" HDTV. I removed the speakers and all the screws on the back cover. Took the cover off and located the fuses on the largest circuit board. The are in the upper right hand corner of the board. There are 3 of them in a row labeled LF 1.5, LF 3.0 and LF 3.0. The are white in color with copper ends. I took a volt meter and measured continuity across all fuses individually and found the LF 1.5 to be blown. The guy at the electronics store sold me a barrel 1.5A fuse and told me to soldier it across the top of the blown fuse. It took an extra set of hands but the TV works perfectly.
Posted on Jun 23, 2009
SOURCE: Volume n my tv keeps going down
same
Posted on Apr 15, 2008
SOURCE: vizio p42
had the same problem had the main powerboard replaced they were out of stock and had to send mine in and vizio referbed it I was told it was a common problem with this unit
Posted on Jul 28, 2008
jerryg50
  • 1667 Answers
SOURCE: Vizio shuts itself off
There may be some components failing in the power supply or one of the circuit boards that are causing too high a current pull.
I realize that this answer is very vague. Without doing proper diagnostics, it is impossible to guess at something like this.
Out of warranty repairs on these sets can be very expensive. I would suggest that if the set is going to be expensive to service, it would be best to replace it with a known brand name that offers an extended warranty with local service. You will pay more, but you will have dependability and better quality.
Jerry G.
Posted on Jan 02, 2009
  • 92 Answers
SOURCE: vizio 47" lcd no picture no sound has power
this could be one of two problem. first, check if you have back light. If you do then the problem is with the M/B. Second, if you don't have back light then the inverter is bad and needs to be replace.
Posted on May 20, 2009
I have a e422vle Vizio TV. The power board went bad, I ordered a new one and the Tv now is working but the remote doesn't work. Is the remote sensor on the power board?
Check the remote control for its infra-red emission. Check it with fresh batteries. Check by pressing all the buttons on it; and see whether all of it generates infrared signal while pressing. If it is found OK, check and replace the infrared sensor inside the TV. If you wish to get some details; check the site linked here. It has details about how to check a remote control; by one among the post. Pull up older posts. If the remote control is found OK; check and replace the infra-red sensor inside the TV.
http://electro-medical.blogspot.com/
Jan 05, 2017 | Vizio E422VLE 42 in. LCD HDTV
Vizio e601i-a3 won't stay powered on
sounds like it needs to see a repairman .they give repair estimates usually then you can decide repair or replace .
Nov 17, 2015 | Vizio Televison & Video
Vizio E422VLE--heard a loud pop,then shuts off. Won't turn back on unless I power cycle, but does same thing when I turn it on again. Already took the back off the tv. All the capacitors look fine. Any...
You will need a voltmeter to actually check the capcitors. More than likely it is a blown capacitor as that is one of the only components that is going to make an actual noise if it fails. Good luck.
Jan 07, 2015 | Vizio Televison & Video
Where is the serial # located on the vizio hd smart tv
It can be noted at the back cover of the TV; or at its chassis inside.
Electro help
Nov 24, 2014 | Videosecu TV Ceiling Mount for Vizio 23 24...
Why does my vizio tv only stay on for a few seconds before the picture goes fuzzy and the tv makes a very loud screeching noise and shuts itself off
Sounds like the power supply board has gone out. It can probably be replaced, but only by someone qualified to do so.
Oct 21, 2014 | Vizio L32 32 in. LCD HDTV
Picture problems when I turn the tv on
Back-light inverter board fault. Contact any service technician. If you wish to get some details, check the site linked here. Surf the site in "MOSAIC" view. It will make surf easy. Surf the site with patience.
Jan 29, 2014 | Vizio E422VLE 42 in. LCD HDTV
Vizio lcd flatpanel tv with dark background
If half screen is affected it will be either a board (LCD and Plasma have different names) but in those one board drives each side of the screen unit--worst case is the display panel itself which is fatal from a cost point of view.
May 25, 2012 | Vizio VT Televison & Video
I have a vizio e320va that when turned on the backlight flickers repeatedly with picture in and out then starts blinking with vertical lines then the screen goes black and the power stays on, This is all...
The tv is having a problems with the board called T-Con board it is dying and the problems.That why the tv is not sustancening the tv pictures for those coded pictures pixels by the T-Con board to stay on to the tv LCD screen panel.This tv problems only causes by the tv T-Con board it is dying only if the tv problems came on to the tv by itself only.If these problems causes by u or an object by outer forces by hitting to the tv LCD screen panel itself.Now the tv LCD screen panel itself it is dying and the causes.Than the tv it is not repairable,tv now only can it to do a replacement of the tv whole LCD screen panel itself only.Not practical because the tv LCD screen panel are 90% important to the tv and the cost of the tv.If u replacing the tv LCD screen panel itself will cost the same as a new tv.The tv is under a year old,why don't u just call Vizio corp. and take ur tv warrenty repair.
Sep 26, 2011 | Vizio E320VA 32 in. LCD HDTV
My vizio 42 in lcd turns off when i press the rgb button on the remote. i am trying to hook up my laptop to the tv
Make sure you have the correct colours matching; R to R, B to B and G to G. I think the blue carries the sync signal. If the tv doesn't get the sync signal from the laptop (the laptop is off or thye cabling is mixed up) it will shut itself off.
I can't be sure if this is the cure but I have 50" vizio plasma which won't stay on if you select and unconnected input.
Aug 19, 2009 | Vizio SV420XV 42 in. LCD TV
It Seems the Input is stuck on RGB. It stays stuck bececausee I can't get by the blue screen to change the input to HDMI 1 before it ( the TV) shuts itself OFF ! arg!
This never was a problem. I must have posted this thinking I was posting it for a Vizio VX37L which I did finally post and pay for your 9.95 service.You can take this along with projection stuff out of my nproducts listing. As yet I have no solutins for the 37L. I've got to call the TV repairman soon as I have Direct TV coming out to install on monday and they cant install to a non working TV. Thanks anyway
Jun 05, 2009 | Vizio L32 32 in. LCD HDTV
Vizio E422VL 42 in. LCD HDTV Logo
152 people viewed this question
Top Vizio Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
