Question about GE Spectra JBP84 Electric Kitchen Range
GE Range model JBP84ToK1wvo, oven cant hold temperature most of the time
    Top Expert:
  • GE Master
  • 9,472 Answers
Replace the temp. sensor and you will be good to go. Here is that part to order.
Posted on Oct 26, 2013
Testimonial: "Great help, THANKS!!!!"
4 Suggested Answers
  • 22 Answers
SOURCE: Claibrating the temperature of a GE gas oven
First of all, do not use the oven thermometers from a grocery store. they can be off by 20 degrees or more. These directions may help you for electronically controlled ovens. The older manually controlled ovens have a small screw head in the center of the oven temperature knob that can be adjusted in usually 10 degree increments.
To Adjust the Thermostat
Touch the Bake and Broil Hi/Lo pads
at the same time for 3 seconds until the
display shows SF.
Touch the Bake pad. A two digit number
shows in the display.
Touch Bake once to decrease (-)
the oven temperature, or twice to
increase (+).
The oven temperature can be adjusted
up as much as 35°F. or down as much
as 35°F. Touch the number pads the
same way you read them. For example,
to change the oven temperature 15°F,
touch 1 and 5.
When you have made the adjustment,
touch the Start pad to go back to the
time of day display. Use your oven as
you would normally.
NOTE: The thermostat adjustment for Baking
will also affect Convection Baking or Convection Roasting.
Posted on Dec 03, 2007
MNTECH
  • 1543 Answers
SOURCE: My broiler works - but the oven does not - GE Dual Fuel range
Thanks for providing the full model number, which allows us to look up part numbers and see exploded views of your product.
Most likely the bake ignitor is bad (even if it still glows, it may not draw enough amperage to allow the gas safety valve to open). One way you can test this on your model is to swap out the broil ignitor for the bake ignitor, as they are the same part number on your model. (part number WB13T10045) The broiler is normally used much less than the oven, so the part does not fail very often on the broiler. You will have to take the cover off the floor of the oven, then the flame spreader, to reach the burner area. The ignitor is the rectangular part at the back, on the side of the burner. (only two wires to deal with) (By the way, for future reference, your model number ends is SS, as in stainless steel, not a 55)
Posted on Jan 15, 2009
localwonder
  • 6784 Answers
SOURCE: My GE oven will not hold a temperature...it heats
HI, You will need to check the oven sensor wires that link the actual sensor to the main control board. Make sure that the contacts are connected properly, and not loose, or corroded. If all the wiring checks out, test the sensor for the correct resistance readings.(you will need a multimeter for this test)
The most common oven sensor should be approximately, 1100 ohms when at room temperature. The others may be close to as follows:
100°F - 1143 ohms
200°F - 1350 ohms
300°F - 1553 ohms
350°F - 1654 ohms
400°F - 1753 ohms
500°F - 1949 ohms
If the sensor test is adequate, and the wiring is Ok at the control, this will lead to a failed control board. replace the control in this case.
Sensor location
The sensor is, generally, located inside the oven, mounted on the back wall, on the top right, or left corner. There will be two screws holding the housing on the back of the oven wall. Once the screws are removed, the sensor will need to be extracted from the back side of the unit.
Posted on Dec 21, 2009
Ge stove oven get a f4 fault
Open or shorted oven temperature sensor (RTD)
Check sensor harness and harness connection between oven sensor and oven control. Replace oven temperature sensor (RTD) if wiring is ok.What is the model number?
Nov 08, 2012 | GE Stove/Range/Oven Oven Control -...
Model # JBP64BOH2H GE range has F2 warning when oven gets hot
Oven temp exceeds 590 w/ unlocked doorHigh resistance or interference in oven temperature sensor. Replace oven temperature sensor
Jun 16, 2011 | GE JBP64 CleanDesign Electric Kitchen...
I own a spectra range Model # JBP30B0B4WH The problem is that the oven temp, is off about 15 degrees how can I adjust it? Roy
This is from page 13 of your manual:
Put the Oven Temperature knob in
the OFF position.
Press and hold the HOUR +/– pads for
5 seconds until the display changes.
Before display changes back, press
the HOUR +/– pads to increase or
decrease the temperature in 5
degree increments.
The oven temperature can be adjusted as
much as 35°F. or down as much as 35°F.
If the oven adjustment is set cooler
than the factory setting a minus sign (–)
and the adjusted temperature will appear
in the display.
Wait several seconds for the control
to automatically set and return to its
previous setting.
Feb 10, 2010 | GE Spectra JBP78 Electric Kitchen Range
Flashing F2 warning
GE
Range/Stove/Oven Fault Codes Failure
Code
Condition Check/Repair F0 and F1 Failed Thermistor Control Replace Electronic Range Control (ERC) F2 Oven temp exceeds 590 w/ unlocked door High resistance or interference in oven temperature sensor. Replace oven temperature sensor F3 Open oven temperature sensor circuit Replace oven temperature sensor F4 Shorted wire (Oven temperature sensor) Locate and correct F7 A = Function pad button stuck or
B = Bad clock Unstick button or
Replace Electronic Range Control (ERC) F8 Component Failure Replace Electronic Range Control (ERC) F9 Program w/ door circuit Check wiring
Aug 18, 2009 | Ovens
After oven cleaning,
GE to8 (oven) control. Part replacement.
Mar 15, 2009 | GE Spectra JBP78 Electric Kitchen Range
OVEN TEMPERATURE TOO HOY
if its maxed you cant just turn it down accordinly to what they tempeture is to cook if its 350dgs use 300 dgs
Feb 22, 2009 | GE JGBS23 Gas Kitchen Range
GE temperature sensor came loose
really no difference how it hangs, so long as it doesnt touch the oven walls, and is up high enough so you dont hit it withthe pans/food you put in
Dec 11, 2008 | GE Profile JTP18 Electric Single Oven
GE Spectra Oven won't heat
i would def try to replace the bake ignitor. most common problem on any gas range. part problbly $75, $250 for someone to install one
Feb 28, 2008 | GE Spectra JGBP30 Gas Kitchen Range
F1 fault
Here are the fault code for GE:
GE
Code
Nov 07, 2007 | GE JSP26 Electric Kitchen Range
Open Questions:
See all GE Spectra JBP84 Electric Kitchen Range Questions
GE Spectra JBP84 Electric Kitchen Range Logo
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Craig Butler
Craig Butler
Are you a Kitchen Range Expert? Answer questions, earn points and help others
