Question about Acer Computers & Internet
15 sec intervel beeping coming from PC tower, #1 green light occaisionally lights up on key board, screen not opening up
    New Friend:
  • 3 Answers
There's a high probability that it is caused by a loose cable. Certain graphics cards require extra power, so there's a power cable connected to it. If that cable is disconnected and the computer started, the card makes a loud beeping noise to alert you to fix it. Consequently insufficiently powered graphics card is unable to display any image.
How to investigate this?
1. Open up the computer (assuming you have the skills and courage to do so)
2. Try to find the graphics card (it could look something like this: http://img.tomshardware.com/us/2007/05/08/system_builder_marathon/low_end_inside_02.jpg)
3. Look for the corner of the card. The cable should go somewhere here. Here's an example image: http://www.nvidia.co.uk/content/slizone/how-to/install_second_gpu/SLI_Install58.jpg
4. Look for a compatible cable somewhere inside the computer. BTW the cable might already be at the right place, but just not tight enough, so if it's already where it's supposed to, give it a little push to see if it goes just a bit deeper.
Posted on Oct 22, 2013
  • 1 more comment
  • Carol Saltzman
    Carol Saltzman Oct 23, 2013
    the screen just says 'acer explore beyond limits'. every 20 sec a command on bottum left corner says Press BIOS Set up. the key board no longer flashes green but i am not able to open the computer regardless of how courageous i am!!
  • Fulgurite Fractal
    Fulgurite Fractal Oct 23, 2013
    Thanks for the extra info.
  • Fulgurite Fractal
    Since there's some text about BIOS, it's good sign, since apprently the screen is cooperating with the rest of the hardware. In any case, I suppose I should have been more precise regarding the "opening" part. What I meant was that you should physically open the metal box with a screwdriver (if necesary) and take a look at the cable spaghetti mess inside it.
rey jr
  • 149 Answers
SOURCE: My PC stop working , beep and not load anything ,
hi there, check up for some loose connection. a memory card, a vide card and some power supply connectors. ty
Posted on Dec 29, 2007
SOURCE: HP Media Center Power Up Problem
replace the power supply-from a computer store, should be no more than 30 dollars
Posted on Mar 15, 2009
  • 145 Answers
SOURCE: Dimension 8400 will not boot and more.......
I would recommend testing the power supply as Dell PS's are not known to be "forever". A power supply tester can be purchased online at Tigerdirect.com for around $20 and they are fairly easy to use (you can also get a new PS there if necessary). If that is not it, I recommend going to a local small computer shop and picking up a used Hard Drive (be sure to get SATA), and switch it for your main HDD,, if the PC starts up and goes to an "Error no OS found" or the ilk, the culprit is your hard drive. I am in CT and fix PC's for a living, I am A+ certified and have passed all the dell Factory Cert tests. If you need help and are in the area or work well over the phone,, let me know I CAN solve this problem.
Jim
Posted on Aug 04, 2009
carrese04
  • 92 Answers
SOURCE: 4 long beeps, then 2 - 2 yellow lights, 2 green...
try replacing the keyboard,
Posted on Jan 11, 2010
  • 4234 Answers
SOURCE: GREEN LIGHT IN BACK OF TOWER
The power supply generates 3 different voltages for the system. The most common cause of the symptom you are describing is a loss of the 5V supply line. This is an internal failure of the power supply that sometimes can be easily fixed, but the cost of repair is likelt to be higher than a replacement supply. A typical power supply will cost around $40. If you have another system around, swap the power supplies between the two. If the system now appears to work, you have confirmed the problem.
Dan
Posted on May 10, 2010
Baughmanno yellow light on computer and a beeping sound and black screen and no power to key board
Beeping sound is mostly caused by loose or bad RAM (memory module). What you can do is to open the tower and look for the memory modules. Just remove it and clean its teeth using an eraser.. just mildly clean it and re-seat it. Try to boot the computer.. it will work..! :)
Note: Unplug the computer to power and press the power button to clear any electricity on the capacitor before re-seating the memory modules.
~jash
Aug 29, 2011 | HP Pavilion a705w PC Desktop
My computer is beeping and the green light is staying on but the red light is not on and it just beeps i changed the battery and still beeps and no signal
If you are receiving continuous beeps, it means that computer is not recognising the RAM (memory). In this you have to open the Computer and follow the below steps:
1. Turn OFF the computer
2. Open the flap of the Tower (Remove the screws from the back of Tower)
3. Now, On the Motherboard you will be able to see the RAM see the picture nanjia.jpeg
4. There should be two pins to unlock and remove it
5. Once removed, clean the terminal and replug it.
6. Turn ON the computer, it should take care of the issue
Thanks and regards,
Jitha
Nov 22, 2010 | Computers & Internet
Dear sir display is not coming little beep is coming from motherboard i have checked rams, power supply also try only single motherboard for display but vain
plz try by removing the mother board and put a paper below it and try to boot ( connect all the cables). if the problem is there then your motherboard is having problem.
Aug 10, 2010 | Dell Dimension 5150 (DIM515MIN) PC Desktop
When my computer is turned on green light is not display and the screen does not display anything than what should i do ??
If the green light is not glowing in the tower check the status of the light on the back of the tower where the power cable goes.
If there is no light in the back of the tower than it might be an issue with the wall jack or surge protector so try connecting the power cable to a different jack and see what happens. if it remains the same than try with a different power cable and check.
If the light is glowing on the back of the tower but there is no light in the front than it may happen the power supply of the pc might have failed. try to open the tower reseat the RAM cards, reseat the Harddrive cables as wells as try to reseat the cables of the power supply. if the light on the back flickers and goes away than it might be a faulty motherboard. So do a Motherboard test by turning on the pc without the RAM cards, if the motherboard is fine you will hear beeping noise if not than motherboard is faulty.
Aug 02, 2010 | Smart Modular SV3170A
Got the green light in back but no power to the system tried the hold power button for 5 sec thing does not work?
The green light at the back indicates that the computer is getting power and it also indicates that the Power Box which is known as the SMPS that supplies power is working fine .As there is no light on the front panel it can be that the motherboard has gone bad .To check that u need to open up the computer tower and then remove the memory cards(RAM) there can be one or more than one so with the card removed turn the computer on .In normal circumstances the computer should impart long beeping noise which indicates that the motherboard is fine and if there is no beeping noise then it means the the board has gone bad and needas to be replaced or serviced.
all the best
May 10, 2010 | HP Hewlett Packard Pavilion Slimline...
I have a dell optiplex sx280 computer and monitor that has lapsed into ''power save mode'' and I have been unable to ''awaken'' it (I'm not sure which is ''asleep'': the monitor or computer!) from sleep. I...
How's the status light of your computer monitor? is it blinking amber? and the status light of your computer tower's power button? blinking amber as well or solid green or no light at all?
1. Disconnect all the connection at the back of your computer tower
2. Press the power button of the computer tower for 15 seconds
3. Reconnect the power button and the monitor cable at the back of your computer tower and turn on the computer (if it turned on that means that one of the device plugged at the back of your computer tower is faulty)
4. If still the same problem, open up your computer tower.
5. Reseat the video card, Reseat Hard drive, Reseat Memory, Reseat CPU, Reseat power cord coming from the CPU to your computer (doing all things one-by-one to pin-point the root cause of the issue)
If none of the troubleshooting steps fixed the problem, possible that the power supply is faulty and if the power supply is faulty sometimes it goes with the motherboard.
Jan 08, 2010 | Dell OptiPlex SX280 PC Desktop
Desktop screen is blank even when the cpu and monitor indicator a
It looks like issue with either mother board or processor.
open the box and remove all memey and power it on. if it makes a beep sound, there is no issue with processor, else we suscpect processor. If it make beep sound, it might be mother board issue. And for checking monitor working condition, remove monitor data cable and see no cable connected messages comes in monitor or not
Oct 13, 2009 | Dell Computers & Internet
My motherboard Problems
First open cpu cabinet then pull RAM memory and pull cmos cell from motherbord for 10 minutes then when you press power button press F8 key then enter in enable vga mode .
Then go to dispaly property then change screen resolution to 1024*768 then apply and then check.
Aug 21, 2009 | ASUS P5VDC-MX Motherboard
Emachine W1135
when ur starting the tower and it light are on and ur fan there is no problem with the power supply, i think that u rily need a new motherboard because ur board will not boot on start up..
Oct 17, 2007 | AMD eMachines Desktop System w/ 17'' CRT...
Computers & Internet Logo
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
