Need instructions on how to do this myself
Get ready for some work.you need to remove the master cylinder nuts that hold master cylinder to brake booster.once you remove nuts you have 2 choices remove master cylinder to remove booster. to keep from bending brake lines.or you can leave master cylinder in pull it toward you easily careful dont bend lines .disconnect vacuum line at booster .go inside vechicle to floor on driver side loosen four nuts on floor to booster .disconnect power brake push rod from brake pedal .dont force pushrod to the sides when disconnecting it.remove four booster nuts then remove booster.when in stalling the new booster loosely install four nuts then connect the push rod to the brake pedal .install new clip tighten the booster unit .if you decide to remove master cylinder use inline wrenches on master cylinder to remove lines.also plug the master cylinder brake line holes to keep from losing all brake fluid.
