Canon error codes
I have an out-of-warranty Canon IPF6300 that's giving the following error code on startup: E161-403F Will not go past this screen. Any advice?
    Problem Solver:
  • 8 Answers
The error code indicates high temperature issue of the printhead
first of all please turn off the unit....unplug the power cable
now remove the cartridge...manually slide the carriage assembly\ printhead back and forth
clean the golden contacts of the cartridges and the printhead with a cotton swab dipped in little alcohol
once done just turn on and check the status
let me know if you still recieve the error or not
in case after performing the above steps the issue still persists, then the unit may require service..maybe a printhead replacement
Posted on Oct 23, 2013
  • Mark Campbell
    Mark Campbell Oct 23, 2013
    Thank you for answering! Unfortunately, I believe there may be another cause. I get this message even after the printer has been off and unplugged for weeks. It followed a series of other error messages like ink out, maintenance cartridge replacement, etc. - all of which were incorrect. Now the print head assembly is locked on the right and will not move so I can't perform the steps you've mentioned, but I will try again. Thanks!
spinal
  • 287 Answers
SOURCE: CANON IR C6800
Hello Jc.Let me start by saying that despite the fact that you have properly been specific with the error code you have submitted, Canon is "fairly" specific in regards to the amount on detail in provides. I say fairly in really loose terms. The error 602 means that for any number of reasons when the copier went to boot" (begin to start up and read its directions as to what it is, who it is, and what it is capable of, it failed to get the instruction set (or failed to recognize the instructions) and therefore said "what"?!) as the copier sought to retrieve this info from the hard drive.That can mean that the partition of the hard drive that is was looking at contained corrupt information, or there was a communication interruption, or that the hard drive is going or gone bad. I know this sounds like a bunch of technical goblidy gook but you don't want to know what the 0101 means after the 602. It may not be too bad but brace yourself for the worst. That is that the hard drive may have went wheels up, or at a minimum all stored custom information is gone. The latter may be the best you can hope for. I am afraid that a "hail Mary" might be to power the copier of by way of the rear switch (or unplug if you are not familliar) and wait a few minutes.Restart and hope for he best. Otherwise you WILL need a technician to replace the hard drive and then they will have to reload the system software. I was reluctant to respond to your request for help as I cannot "fixya" and I will get a bad grade from the guys that run this site since I left ya hangin. But I could not resist trying to help you and to at least make sure you did not get raped by some "hungry for money" company. Please at least give a decent rating and I will keep my fingers crossed for you..................SPINAL
Posted on Jan 25, 2008
SOURCE: ERROR CODE CANNON MP150/MP160
hello i dont speak fluently the english but my canon mp150 dont print only say e 27 what to do azdzminx@yahoo.es
Posted on Feb 17, 2008
  • 67 Answers
SOURCE: Canon Image runner C 3200 printer gives error code E000677-0080
your quickbooks file is in the wrong format example tiff or pdf let your it know they can change it to the correct file format
Posted on Aug 19, 2008
SOURCE: about error code
cannon ir 5000 copier give me error e 0061 & e0069 what the problem and the solution
Posted on Oct 15, 2008
SOURCE: Canon IR 3100 error code (E000020-0081)
error code E00020-0081 my canon printer IRC3170i.what is the problem?Anybody can help?
Posted on May 20, 2009
Error 03130031-2618 in canon ipf 750
Error code 03130031-2618 is a voltage error. It could happens on these printers models: IPF6350, IPF6300, IPF6000, IPF8000, IPF8300, etc...
Solution 1:
  • Power off the printer.
  • Disconnect the power cable
  • Wait for 30 minutes.
  • Connect the power cable
  • Power on
Solution 2:
  • Check the power supply
Solution 3: The voltage of the print head is abnormal.
  • Replace the Printhead
Solution 4: Check for the cable continuity between the carriage relay PCB and the main controller PCB
  • Replace the cable.
    Replace the carriage relay PCB.
  • Replace the main controller PCB
Oct 26, 2017 | Canon Office Equipment & Supplies
Clearing error e000067 canon irc2880i
Error Code Canon IR C2880i E-067-102 - CopyTechNet.com
www.copytechnet.com > ... > Copier Technical Discussion > Canon
Feb 6, 2013 - 10 posts - ‎5 authors
I have a Canon C2880i that has been giving strange messages. It started with the ... Had to clear dc-con for the drum lifes to regulate. Problem I ...
Canon ImageRunner Error Code Reset - Question Defense
https://www.question-defense.com/.../canon-imagerunner-error-code-res...
Nov 10, 2008 - These are the steps to resetting error codes on the iR5570/iR6570 and other ImageRunner printers. This also refers to eCopy, so follow the ...
How to give code for Normal ERROR in canon IR 3300 ...
? 2:28
https://www.youtube.com/watch?v=WyVgSjP_xms
May 19, 2014 - Uploaded by Prince tv
How to give code for Normal ERROR in canon IR 3300 ... thank you sir my canon ir2870 err no E000002-0000 ...
Jan 18, 2016 | Canon Office Equipment & Supplies
How to clear error code e000002-0000
Hi
I have found a list of error codes for your machine here:
Error Codes Canon iR2270 Code E002 0000
and it looks as if your error is described as follows: Description The rise in temperature of the fixing assembly is faulty
While startup control is under way, the reading of the main thermistor is less than 115 deg C continuously for 400 msec 1.3 sec after it has indicated 100 deg C. While startup control is under way, the reading of the main thermistor is less than 150 deg C continuously for 400 msec 1.3 sec after it has indicated 140 deg C. Remedy Reset the condition in service mode: COPIER>FUNCTION>CLEAR> ERR. Replace the main thermistor. Replace the DC controller PCB. You can check all error codes on this page by choosing the relevant code from the drop down menu at the top right of the page.
Hope this is helpful, if so would you please register that with Fixya
Cheers
Nov 24, 2014 | Canon IR 2270 Digital Copier RECONDITIONED
Printing blank pages ipf6300
Hello, can you give me more details? The ink cartridges have ink, if not replace with new ones? Is the print head expired, replace it. Take note: if you hwant to replace the printhead your cartridges need to be al 90% full.
Feb 11, 2014 | Canon imagePROGRAF iPF6300 Large Format...
Reset ink counter ipf6300
first you must follow the step:
1. open cover ink
2. then follow the massage from the display panel
3. untill the information select displayed on the display panel
4. select oke if you want to change original ink to refiill
then on display shown the non ink chek status.
Apr 06, 2013 | Canon imagePROGRAF iPF6300 Large Format...
I have a canon IPF6300 large format printer and it is coming up with error code 03130031-2618
This code indicates a print head failure. First try replacing the Print Head, if however the problem persists things get substantially more complicated. Unless you are very techie it would be best to call a technician as further steps involve re-seating all the cabling to the Relay PCB and the Carriage Unit PCB. See more here.
Sep 17, 2012 | Canon imagePROGRAF iPF6300 Large Format...
6A00 error code
Unfortunitly this isnt an easy fix. IF you still have it under warranty you can contact Canon and the ywill fix it. If its not under warranty they can refer you to the nearest Canon repair center.
The 6A00 error is an internal error which can be caused by one of the following things.
- Sheet feed unit
- Logic board
- Purge unit
Best of luck..
Nov 22, 2010 | Canon PIXMA MP530 All-In-One InkJet...
Canon printer will not print. keeps on giving a code 6C10. where do I go to get help
Thats a service type error code and you can call Canon at 1-800-828-4040 and find the nearest shop, Canon has a one year warranty on all their printers.
Dec 19, 2009 | Canon PIXMA MP620 All-In-One InkJet...
116 people viewed this question
jasbo
jasbo
