Question about Electrical Supplies
How do you operate the control panel - Electrical Supplies
  • 3 Answers
I found the proper length of the starter rope.
Posted on Oct 22, 2013
My ricoh aficio MP3351 machine has a error problem SC672, plz kindly tell me what i can do???
SC672 occured when controller-to-operation panel communication error at startup After powering on the machine, the communication circuit between the controller and the operation panel is not opened, or communication with controller is interrupted after a normal startup.
.Controller stalled
.Controller board installed
incorrectly
.Controller board defective
.Operation panel connector
loose or defective
Make sure that the MBU is seated correctly. If not, SC672 occurs look at the picture to see what im talking about.
Sep 29, 2017 | Ricoh Office Equipment & Supplies
Ricoh MPC3003SP SC672-11. what are the possible solutions to this error. i have already replaced the controller board
No. Type Details (Symptom, Possible Cause, Troubleshooting Procedures)
672 D
Controller start up error
? After the machine is powered on, the communication between the
controller and the operation panel is not established, or
? After startup reset of the operation panel, the attention code (FDH)
or the attention acknowledge code (FEH) is not sent from the
controller within 30 seconds.
? After the controller issues a command to check the communication
line with the controller at 30-second intervals, the controller fails to
respond twice.
1. Controller stalled
2. Controller board installed incorrectly
3. Controller board defective
4. Operation panel connector loose or defective
5. The controller is not completely shut down when the main switch is
turned off.
? Check the setting of SP5-875-001. If the setting is set to "1 (OFF)",
change it to "0 (ON)"
Feb 13, 2017 | Ricoh Office Equipment & Supplies
Ricoh aficio 3035/3045 error sc 672 not able to proceed to service mode also, kindly help me pls.
possible a bad operation panel replace or 672 B
startup.
Controller stall
defective
690 A GAVD block I2C bus error
An error is detected in the GAVD
communication I2C control register of
the GABIC2.
I2C bus on BICU defective
691 A GAVD FCI block I2C bus error
An error is detected in the FCI
the GABIC2.
692 A CDIC GAVD block I2C bus error
An error is detected in the CDIC
the GABIC2.
700 B ARDF original pick-up malfunction
After the
Sep 21, 2012 | Ricoh Aficio 3045, 3035 Kit
Removal of operator control panel on lexmark c935
You will need to remove the top cover and a couple of screws to remove the operator panel. However, we do not suggest that you do this yourself. There are a lot of wires involved in removing the operator panel. I suggest you call our Technical Support Hotline on 1-800-539-6275 to request assistance.
Aug 13, 2012 | Lexmark C935dn Laser Printer
Have a hp cam trying to install it on an ibm pc
I suggest try to check what type of Operating System you have. After you verify your Operating System, Download the driver from the manufacturer website.
Here's how you can check your Operating System:
Windows 7
Start->Control Panel->System and Security->System (in Category View)
Start->Control Panel->System (in Large or Small Icon View)
Vista
Start->Control Panel->System and Maintenance->System (Default View)
Start->Control Panel->System (Classic View)
Apr 16, 2011 | Computers & Internet
Kenmore Dryer light comes on but control panel not operating
Your thermal-fuse is located on the back side of the bulkhead upper right hand cornerb68bc9a.jpg
Electrolux family of dryers newer models Dryer Service manual
I have repair photos and more HERE
Jun 15, 2010 | Dryers
My duet washing machine is saying control panel lock out and nothing will come on. Any suggestions
Press any of the buttons on the control panel to see if the buttons are operational or check to see if the "Control Locked" indicator light is lit. If the control panel is operational, you may mistakenly lock the door.
Press and hold the "End of Cycle Signal" button for approximately three seconds until the "Control Locked" indicator light shuts off.
May 21, 2010 | Whirlpool Duet GHW9150P Front Load Washer
I have Jandy RS4 system with 4-button poolside controls for additional spa control. Inside house control panel stays totally lit up saying ''Rev 6700'', and cannot communicate or control pool operations. ...
Pull the cover off the control panel. You will probably find a button which would be accessible from outside the panel with a paper clip or pencil but is unlabeled. On the board itself by the button, in small letters it should say "reset". Push the button and see what happens.
Oct 07, 2009 | Jandy Aqualink - Rs24 One Touch Pool / Spa...
Savin 2545 throwing error code SC672.
Open the operation panel the cable which connects the controller and the operation cable might be not good attached or something like that.
The operation panel you might open by unscrewing the two screws on the front of the control panel and then pull the panel towards you.
Inside you will see some cables see if they are good connected or just disconnect them and connect them again.
If that not fix the problem than you have problem with the controller.
You might do the same procedure like with the panel.
Just remember to turn off the machine before you
pull out the controller.
The controller can be pulled out by unscrewing two screws on the left back side of the machine where you connect the machine with computer you cannot miss that part because the hole machine is with white plastic and that part of the machine is metal part.
Jul 14, 2009 | Ricoh Aficio 450 Copier
Electrical Supplies Logo
19 people viewed this question
Top Electrical Supplies Experts
ken skalski
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
