Question about Dryers
Maytag med9700 dryer cabinet
Dryer won't start, no error codes, appears to work on the control panel but no heat or spin. Checked thermistor and heat fuses and door switch and power voltage at the block and replaced the motor - still won't start.
    Problem Solver:
  • 8 Answers
That's why I hate "computerized" appliances-- cheap for them, and expensive for us. Almost sounds like a business plan!
Posted on Oct 23, 2013
ginko
  • 19396 Answers
SOURCE: DRYER ONLY WORKS BY HOLDING DOWN THE TIMER BUTTON
You need to replace or repair the timer control, this is not a faulty motor control unit.
You find parts by entering model number here.
Posted on Dec 15, 2008
  • 300 Answers
SOURCE: Maytag MDG5500 - heat goes off after several minutes
Q - My gas dryer will not heat, what could stop my dryer from heating?
A - Things that could stop a gas dryer from heating:
- glow bar igniter, thermal fuse ( not all models ), coils on the gas valve, gas valve, thermostats,motor heat switch, timer, selector switch, sensor.
A page for checking gas dryers is here.
Posted on Mar 07, 2009
Greg20
  • 149 Answers
SOURCE: I replaced the thermistor on maytag neptune gas
did you forget to plug the door switch back in? or anything else? oh..it didn't start before...ok. you probably should have replaced the thermal fuse..it's white with 2 wires on it.
Posted on Jun 12, 2009
  • 66 Answers
SOURCE: I have a Whirlpool LGR7646JQ0 Gas Dryer. No heat .
If you checked all those other things you probably have a busted glowplug. Its similar to an igniter on a stove just a small element that gets super hot to ignite the gas. You'll need to replace it yourself or get a repairman to come do it. If you do decide to do it yourself make absolutely sure that you do not touch the element itself with your bare hands as the oil from your skin will cause the element to break when it heats up and you will be back to square one. The glow plug is usually located in the bottom left hand corner of the dryer and if you pull the front cover off the machine and remove the air duct in front of it you should see it pretty clearly. Obviously have the gas and electricity disconnected before you work on any gas machine.
Posted on Dec 13, 2009
Testimonial: "Thanks In checking this out I found That it was broken . I have replaced it but still dryer no heat Do u have something elese"
  • 949 Answers
SOURCE: Dryer won't start, checked thermal fuses and start switch.
It sounds like you have been through most of the areas too look.
One thing to make sure of is that you have a full 240 volts. An electric dryer can measure 120 volts. from L1 to common and 120 volts from L2 to common but you also need to make sure you have 240 volts from L1 to L2 on the meter, one leg of the breaker or one of the two fuses could be blown.
If this is alright you only have a couple components left. The timer contacts and the drive motor. Either of these could be causing the issue.
To check the motor with the power disconnected check for continuity between switch terminal 5 and the Green(black) wire on the motor. If you have no continuity the motor is bad. Check for continuity between the terminal 6 and the yellow wire on the motor, if you have no continuity there the motor is bad. Check for continuity between terminal 1 and 2 on the motor if you you do not have continuity the motor is bad.
The timer should have continuity between the Yellow and Grey wire terminals for the motor to start.
I hope this helps
Posted on Apr 23, 2010
Testimonial: "Great advice, thank you for your help."
The dryer will not start. it seems the thermal fuse is good. (2.5 ohms on Ohms meter)
Hello Rusty,
Try holding the Start Button for more than 3 seconds.
  • Check that the door is closed properly. Check the door Catch & Switch with an ohmmeter for continuity when close.
  • Make sure the High Limit Thermostat is good
  • The Thermistor can be open.
  • Check the Heating element for continuity.
  • Idler pulley might be bad.
  • The Control Board my be defective.
  • The Moisture Sensor can also be bad.
  • Last but not least the dryer Motor might also be defective.
Here is a link to Sears Parts. Most of the parts you may need are in the Bulkhead Diagram.
Best of Luck,
JP
MAYTAG RESIDENTIAL DRYER Parts Model MED9700SB0 Sears PartsDirect
Jul 19, 2015 | Maytag MED9700S Electric Dryer
Maytag Bravos XL Dryer not heating- blowing thermal fuse
The thermostat is controlling the temperature, however the Heating Coil may be defective. Check the COIL.
Feb 27, 2014 | Maytag MEDB950YW Electric Dryers
Dryer runs but does not heat and dry.
Could be a thermistor problem. You getting any failure codes? This fancy machine is just a plain ordinary 4 wheel drive model from Whirlpool. On the element is 2 limits which do not control the heat. One of em could be out if the dryer has an air restriction which could cause overheating. the element itself could be bad. Have you checked any of that? Your dryer is similar to a Duet sport dryer in build.
That last link includes the service manual.
Jul 30, 2011 | Maytag MED9700S Electric Dryer
I've located the thermal fuse on the blower housing and there is no continuity. Next to it is the drier thermister and I have no continuity there either. If I replace the fuse where do I go from there?...
The thermal fuse is blown open due to the thermistor being open (no continuity). The thermistor is a negative temperature coefficient resistor in which the resistance varies inversely with the temperature. Since the thermistor is open (infinite resistance), the electronic control board "thinks" the dryer temperature is too low. It then activates the heater relay continuously which makes the dryer overheat and blow the thermal fuse open to stop the motor which eventually turns off the heating element. Replace both the thermal fuse and the thermistor and it should your problem. They are manufacturer part numbers 3392519 and 8577274, respectively. The part numbers AP3132867 and AP3919451 are used only by www.partselect.com.
Apr 01, 2011 | Maytag MED9700S Electric Dryer
Clothes seem to take longer to dry and I keep getting an E1 error code on my Whirlpool duet dryer. Model #GGW9209LW0. Dryer is about 8 years old. Lint is not an issue.
The error code E1 indicates the control senses an open thermistor either due to a loose connection or a failed thermistor. Check the thermistor connection to the control and replace the thermistor (part number 8577274) if the connections are good and snug fit.
Remove the two screws securing the toe panel to the cabinet then pull the panel down and out. Remove the hex-head screw from the lint duct bracket and remove the bracket. Remove the two hex-head screws from the lint duct and remove the lint duct.
Facing the rear of the dryer, the thermistor, usually black, is located on the blower housing to the right of the thermal fuse. Remove the two screws securing it to the blower housing and secure the new thermistor in place.
Connect the wires then reinstall the lint duct and the lint duct bracket. Slide the toe panel up into position to the cabinet and secure it.
Apr 27, 2010 | Whirlpool GGW9200L Gas Dryer
It starts working for a minute and it stop working
It is an indication of a shorted thermistor. Disconnect power to the dryer and check the resistance of the thermistor.
The thermistor (part #8577274) is located on the blower housing with red/white stripe and black wires and can be accessed by removing the lower front access panel. Remove the two hex-head screws attaching the bottom of the lower front access panel to the cabinet and pull the bottom out then down and move the panel away from the cabinet.
Disconnect one wire from the thermistor and use an ohmmeter, set to X1, to measure the resistance. Touch the ohmmeter test leads to the thermistor terminals and measure the resistance. The resistance reading at room temperature of a good thermistor is between 8.5 and 13.5 ohms; otherwise, replace the thermistor.
Remove the two screws mounting the thermistor to the blower housing then mount and secure the new thermistor in place. Connect the thermistor wires then slide the lower front access panel up back into position to the cabinet and secure its bottom with the two securing screws.
In case the measured thermistor resistance falls within the allowed range, measure the resistance between the disconnected thermistor wire and the other one. Replace the dryer control electronics (part #8546219).
Remove the screws attaching the top panel to the rear of the dryer then slide the panel rearward and lift it off.
Facing the front of the dryer, the dryer control board is located on the left mounted behind the bracket. Remove the three screws holding the bracket in place then rotate assembly up and set it on the side panel.
Disconnect the wiring harnesses from the control board one at a time then connect it to the new control board.
Remove the control board mounting screw near the transformer then press the side ends one at a time to release the mounting tabs and lift the end away from the bracket.
Secure the new control board to the bracket and reassemble the rest in reverse of the steps given above.
Apr 02, 2010 | Whirlpool GEW9250 Electric Dryer
Maytag MDE6700AYW Electric Dryer Error Code "he"
Could be the thermistor, or the element, or the control board. You have to use a multimeter to troubleshoot the problem. You unplug the dryer, disconnect the element and use an ohmmeter to test the element for continuity.
If you don't have a multimeter, you could replace parts randomly to see if you can find the problem
Jun 29, 2009 | Maytag PYE2300AY Electric Dryer
Dryers Logo
65 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
