Question about Health & Beauty
Wahl battery operated trimmer model 5537w, need blade assembly diagram
4 Suggested Answers
SOURCE: re-assembling my Wahl Beard Trimmer Model # 9918C
Turn the trimmer off. Put your thumb under the teeth of the attachment. Push Up. The attachment should snap off. Replace the beard trimmer in the slot. Hope this helps.
Posted on Aug 26, 2009
SOURCE: Have Oster model 23-51f fast feed trimmer. Took
We also have these model clippers and have found out that the modelo number has been updated to 76023-510 type in Oster professional products for more info....hope this helps
Posted on Feb 01, 2011
SOURCE: How do I split the case of my Wahl 9916C beard
Bottom side (black on mine) has a finger grove section that comes off with a small flat blade screw driver used to pry up, 4 tabs, one on each corner (Exposes 2 screws). Need a sauder (spelling not my thing) gun to remove and batteries are 2 ea 1.2 v (looks between AA & AAA size). I'm just going to just buy another unit. Good luck!
Posted on Feb 12, 2011
Blade assembly: My WAHL Peanut trimmer hit the floor and fell apart.. How do I reassemble the blade which has also detached.
if it broke apart when it hit the floor then you will have more problems than just putting the blades back on. those are fairly well put together so coming apart means they hit pretty hard. you wont ever get them to cut right even if they go back together. your gunna have to just buy new ones.
Aug 01, 2014 | Wahl Tid-bit Mini peanut Trimmer Clipper...
Assembly diagram
I'm looking forma armature ( the inside Parts) of wahl ac trimmer
Oct 09, 2013 | Wahl AC Trimmer Hair Trimmer
How to open wahl super trimmer model 1591/1592
Push the blade teeth away from the trimmer body, it will just click off. Undo two screws behind blade, undo one screw at rear of trimmer from the bottom. That's it cases will now split apart.
Jan 19, 2013 | Wahl The Peanut Hair Trimmer
Switch accessories on the wahl 9876l
Cradle the trimmer in your hand, and use your thumb to push the blade assembly out / away from the trimmer. To install any of the attachments, hook the white nylon hook on the blade assembly into the notch on the bottom of the trimmer, and snap the blade into the trimmer.
Apr 07, 2012 | Wahl Health & Beauty
I have a 9877 model trimmer i cant figure out how to use the trimmer do i unscrew the head and flip it around to use???
I had the same problem at first. All you need to do is twist/turn/piviot/rotate the blades. Grab the metal blade assembly by the 2 non-cutting edges and turn/twist it like a bottle cap. It will sort of 'snap' into position when you have turned it 180 degrees.
Jun 13, 2011 | Wahl 9877-500 Beard Trimmer
The power seems to have dropped so the blades arent running on my shaver
how long have had this cordless trimmer, you may need to replace the rechargeable battery inside the trimmer. if so have Contact mannyssharpening@yahoo.com they are a Wahl Dealer they have all the parts for Wahl clippers.
Mar 29, 2010 | Wahl 9918-600 Beard Trimmer
Does the Wahl Model AC Trimmer have an adjustment for the blades? There is only a plastic insert between the blades
Wahl has two type of blades for this AC trimmer, some come with a fix blade no adjustment,the other type of blade has adjustable blade. Wahl dose market the blade as adjustable or non adjustable. But mannyssharpening.com has the adjustable blade type were they can adjust the blade for a close cut.
Feb 22, 2010 | Wahl AC Trimmer Hair Trimmer
I lost my instruction manual. How do you oil the Wahl beard and mustache trimmer model 99180? Thanks, DJ.
Oiling the trimmer is very simple. It is only necessary to apply oil to the blades. Simply apply one or two drops of oil directly to the blades while running. This should be done before each use.
You should have gotten a bottle of the blade oil with your clipper. If you have also lost this, you can buy a bottle of Wahl clipper oil from shaveroutlet.com. see link below
http://shaveroutlet.com/wahl-4oz-squeeze-bottle-clipper-oil-p-584.html
Jan 24, 2010 | Wahl 9916-800 Groomsman Beard Trimmer
Health & Beauty Logo
60 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
