Tds600 error code 08006 - Office Equipment & Supplies
2 Suggested Answers
SOURCE: OCE TDS600 Error Codes
It might need a new fuse which is located where the hot wires are when the paper feeds through or it might need a circuit an Ormon G3NE-220 TL-US load 20A 240VAC 50/60hz input 24 VDC.
Posted on Aug 31, 2009
The code ER CO keeps coming on, on the display panel. The fridge and freezer still work but the code keeps coming up. Any info on that?
LG Bottom Freezer Refrigerator Error Codes Sears PartsDirect
Select
Use our model number finder
Choose your product type
Common model number plates
Close
LG Refrigerator Error Codes
These error code explanations can help you diagnose a problem with your LG bottom-freezer refrigerator. For repair how-to help, visit the PartsDirect repair help section, which includes repair help for washing machines, other major appliances, lawn and garden equipment, garage door openers, vacuum cleaners and more. You can also search for owner's manuals, get advice from an expert and find refrigerator replacement parts. Error Code
Er FS Error Code
Er rS Error Code
F dS Error Code
r dS Error Code
Er HS Error Code
Er IS Error Code
Er SS Error Code
Er rt Error Code
Er It Error Code
Er gF Error Code Error Code
r dH Error Code
Er IF Error Code
Er FF Error Code
Er CF Condition
Condenser fan motor is defective Check/Repair
Condenser fan motor, wiring or the control board Shop Parts
Condenser fan motor, Power control board, Wiring harness Error Code
Er CO Condition
Communication error Check/Repair
Communication error between main board and display board Shop Parts
Display control board, Power control board, Wiring harness
Jul 16, 2015 | LG LFX25974ST 24.7 cu. ft. French Door...
Oce tds600 error code in 05701
This is a "developer pollution" error. You probably are getting a message referring to a failure to optimize what you are trying to print.
That being the case, perhaps a change of the "ink" is in order or whatever you can do to clean the machine as something something is gumming up the developer..
This OCE is a Cannon company. If your manual has no cleaning instructions, you are at the mercy of techs familiar with doing the process for your machine. Or, you might get lucky with tech support of Cannon. Typically, manufacturers would be about the only ones able to identify what such codes means. Hope this helps.
Nov 09, 2014 | ErrorExpert Computers & Internet
TDS600 Error Code 08005
This has to do with one of the thermistors in the fuser section. I would recommend you call an authorized Oce/Canon service representative. The part is delicate and difficult to replace.
Apr 02, 2014 | OCE Office Equipment & Supplies
Tds600 error 22001
This is usually a bad CPU-I/O Board.
Sep 04, 2013 | OCE Office Equipment & Supplies
Have a tds600 that has just started printing everything with black lines or streaks of some sort down both sides of printed image. Any help??
Hi it could be an issue with the drum cleaning blade check to see if the drum is clean what you can do is do a few copies say 5 copies then check the drum to see if it is clean if it is not clean then replace the drum unit assemble or replace the drum blad
the other item to check is the fuser unit upper fuser roller is there any damage to the roller is the surface of the roller intact or are there several areas damaged if so replace roller
Feb 10, 2011 | OCE Office Equipment & Supplies
Jul 13, 2009 | OCE Office Equipment & Supplies
113 people viewed this question
jasbo
jasbo
