Question about Garden
Subaru Rigid 3000 PSI pressure washer has not been run for 6 months fuel was stabilized. Starts and runs for a few minutes and quits. must sit for ah about an hour and it will run again for a few minutes in full choke position only. I changed the gas, checked the plug and checked the float bowl. there isn't any gas getting to the float bowl. there was a little water in it. Is it possible that the gas in fuel line jelled and restricting the flow of fuel?
4 Suggested Answers
  • 2692 Answers
SOURCE: karcher 2600 psi pressure washer wont stay running
Remove and clean the carburator. Sound line a stuck needle on the float.
Posted on Apr 22, 2009
  • 583 Answers
SOURCE: excell vr2500 pressure washer ,no pressure
check the water filter ---high pressurehose must have bbackpressure to develop pressure so disconecting it wont acheive ,much ,if you have agood water supply ,oil in the pump--- adjust pressure by srewing the brass fitting that the pressure hose attachesto, down that is clock wise a couple of turns or so and see if that makes a difference if not seals in the pumpmay be gone tha t should show by water in the oil
Posted on Jul 30, 2009
SOURCE: Pressure washer stalls off choke
Check if the carb i is properly seated and screws are not loose , it could be sucking air
Posted on Sep 26, 2012
How do i drain the gas from my Rigid 3000 psi pressure washer with Subaru engine?
Then the next easiest step is to use a turkey baster and suck it out through the fill hole.
Jul 13, 2015 | Psi Garden
How do I fix an idle issue with my Ridgid 3000 psi pressure washer?
Run some carburetor cleaner through it first. Go to autozone, etc, and pick up some fuel system cleaner you can put directly in the tank and run it through.
Jun 21, 2014 | Ridgid Garden
What causes funny idle with a rigid 3000 psi pressure washer
Get some fuel system cleaner you can put directly into gas tank from autozone, etc, parts store and run it through before you do anything else.
Car starts then stalls after 5 seconds
sounds like you need to replace your fuel pressure regulator.
Apr 26, 2013 | 1996 Subaru Impreza
Dewalt DPD3800 pressure washer starts and runs fine. After 5-10 minutes of washing the engine quits. It will not start until it cools. The engine will start after a 10 minute cool down. It will run and...
I have the exact same pressure washer and have had the same issues with it. The cure for me was to simply run the washer with the gas cap loose. For some reason the fuel gets vacuume locked and stops flowing into the carb. The fuller the tank is it seems the shorter the time is between the time it starts and the time it shuts off. Or you might find a way to vent the cap. Hope this helps.
Jun 06, 2011 | Dewalt 3800 PSI Pressure Washer
Im having a problem keeping the motor running. it cuts off and will re-start easily and run in the choke mode? won't run in the normal mode until i cut it off and re-start. then it will run for about 5...
Hello. Your carburator is gummed up. Get a can of seafoam fuel additive at the auto parts store and put the recommended amount into the gas. This will clear up the problem in just a few minutes. Joe
Mar 16, 2010 | Northstar Pressure Washer 3000 PSI
1999 Buick Regal GSX won't stay running......
It's probably the mass airflow sensor and/or oxygen sensors.
Jun 18, 2009 | 1999 Buick Regal
Gx160 Pressure Washer runs fine for 20 seconds Then shuts off
It could be several things...oil level, make sure its sitting on level ground...if not did you use StaBil when you laid her up for the season? If not, go to Advance Auto and buy "SeaFoam" and following directions run it for as long as it will run...make sure you have water running through the pump during tests!
Good Luck
Jun 14, 2009 | Honda Pressure Washer PSI 3000
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
john h
