Question about Nakamichi SoundSpace 5 Shelf System
Need replacement woofers four soundspace5. Any ideas where? I can't find the VEC 4001000290 part anywhere. Thanks!
Do I find a 12 volt recharger for the VEC 137CO
Radio Shack sells AC/DC replacement chargers that will work with the VEC 137CO. Or Sears do exactly what you need, see Link
Dec 16, 2014 | Camping, Backpacking & Hiking
No work is done by gravity on a bowling ball that is rolled along a bowling alley because why?
If the bowling alley is perfectly horizontal, the center of gravity of the ball will remain at the same height measured in a fixed system of reference. As you know the gravity force is directed vertically downward. To calculate the elementary work of that force you evaluate the inner product dW= vec(g).differential of vec(5). However since the displacement vector vec(r) remains in a horizontal plane ( Prependicular to the direction of vec(g), and the ball does not bounce and leave the horizontal plane) the angle between vec(g) and vec(r) is equal to 90 degrees. the inner (scalar product is =0).
A simpler way to remember it is that the work is equal to g*(difference in height)
Jan 07, 2012 | iPhone Apps
I own jamo speakers CL 30. One of the woofers is broken. Can i find anywhere one woofer to replace it?
Best to have it reconed ! The speakers need to be matched pair.
If you are using these for music instrument(s) make sure they are intended for that use. Home stereo speakers won;t take the power that music instrument speakers are designed for by a factor of say four.
If these are mis-applied, don't waste money repairing, but buy instrument grade cabinets.
Dec 26, 2009 | Music
JVC KD-PDR30 overheating
think the sub woofer my be drawing to much power try disconnecting the sub for a few days and see how it goes
May 21, 2009 | JVC KD-PDR30 CD Player
Technics Receiver SA-DX940 subwoofer
Make sure subwoofer button is pressed and registers that sub is set on, the check dB level adustment for sub channel with remote.
Mar 16, 2009 | Technics SA-DX940
Need woofer for B2030A
Check the watts and size on your old woofer and go to radio shack and get a repacement woofer with the same wattage and size.
Radio shack make great replacement speakers and woofers.
Feb 14, 2009 | Audio Players & Recorders
I need to find replacement ground (thumb screw) for vector 024
ground it off on the case...any grounding method should work. Unless you are talking about the main connection terminals... then just replace the missing thumb screw with a short screw and an eyelette type connecter.
Nov 18, 2008 | Vector VEC 024 400-Watt Power Inverter...
Nakamichi SoundSpace 5 Shelf System Logo
64 people viewed this question
Top Nakamichi Audio Players & Recorders Experts
Jerry Greenberg
Jerry Greenberg
ELECTRICLAW
Level 1 Expert
da surgen
Are you a Nakamichi Audio Player and Recorder Expert? Answer questions, earn points and help others
