Question about Eclipse Audio Players & Recorders
Turn on eclipse mp3 2.8V - Eclipse Audio Players & Recorders
Need to know location of turn signal flasher on 2001 mitsubishi eclipse gs
The flasher module is located in the fuse box that's located next to the steering wheel
Oct 01, 2012 | 2001 Mitsubishi Eclipse
Eclipse cld won't turn on
what i just did was made sure it recognized it on my computer and quickly unpluged it and put it in my xbox
Mar 12, 2012 | Eclipse CLD2 MP3 Player
My eclipse portable media player is frozen it turns off **** it stays on a blue screen dat says eclipse
I need detailed instruction on how to put a Eclipse V215 mp3 player back together. The warranty already expired so I'm fixing it on my own.
Jan 12, 2011 | Mach Speed Eclipse V215 (2 GB) MP3 Player
My Eclipse cd3414 is not responding, i dont know how it was blocked and now I cant turn it on, but it display a code: S(or 5)C801840. Ive already tried to insert my cd but it didnt work.
did you try calling eclipse?? there is usually a phone number for eclipse on the radio sticker. you can also probably try their website.
Aug 10, 2010 | Eclipse Cd3414G
Eclipse mp3 player says "no file"
I had the same problem. I think most files that itunes uses are in a .m4a format. The eclipse mp3 player will need all the music files in an .mp3 format. The eclipse actually has a "software" folder that includes the "replay converter" that will convert these files for you - or you can download any number of freeware that will convert the files as well. Once I converted those files, my eclipse played everything. Prior to that - even though I had synced everything with my Windows Media player, I was getting the "No Files" message. Good Luck!
Jul 07, 2010 | Eclipse CLD2 MP3 Player
HOW TO CHANGE THE TURNING SIGNAL SWITCH OF A MITSUBISHI ECLIPSE
Raise the tilt wheel to the upper position
Remove the lower philips screws securing the upper and lower clamshells on the column.
Release the top and bottom clamshells from one another by pressing together where they meet.
Unplug the electrical connector from the back of the turn signal stalk
Early 2000 eclipses:
Remove two philips screws bolting the signal stalk base to the column
Late 2000 eclipses:
Squeeze the top and bottom release levers to release the signal stalk base from the column
Pull the stalk and base straight outward to remove from the column.
Installation is the reverse.
Feb 26, 2010 | 2000 Mitsubishi Eclipse
The turn signals on my 04 eclipse spyder Stopped!
There is a relay for your turn signals at the fuse block in the engine compartment,the wipers are on another circuit, if all the other wiper positions work,you got a bad switch
Dec 15, 2009 | 1998 Mitsubishi Eclipse
2001 eclipse steering wheel wont turn
low power steering fluid/ bad power steering pump
Mar 29, 2009 | 2001 Mitsubishi Eclipse
59 people viewed this question
Top Eclipse Audio Players & Recorders Experts
juanmireles1
Joseph Hoffmann
Are you an Eclipse Audio Player and Recorder Expert? Answer questions, earn points and help others
