Question about Motic EcoLine D-EL2 Digital Screen Microscope
Motic d-el2 oil immersion objective? Anyone know
Motic d-el2 oil immersion objective? Anyone know if this is available, or if there is anything that can fit? Thanks!
How will you focus ab object using an oil immersion object?
Use manual focus .. First thing is to determine how deep/height/thickness the oil in the oil container is .. you need to know this to determine the exact location of the object in the oil... this can get quite tedious..When you determine the thickness of the oil you can determine the location (height) of the object.. Now, once you know the location, you can make a "substitute object" the same height (NOT IN OIL) so you can then focus on the "substitute object" , DO NOT move the focus.. carefully put the oil suspended piece under the lens and take a few pics.
I hope this makes sense... you are simply making a stand-in piece for focus purposes only..
Jun 19, 2017 | Cameras
Need Windows 7 64bit driver for National DC2-155 Digital Microscope
The software for National Optical DC2 is provide by Motic. According to motic's website "images plus" is not yet available for Window 7 based operating systems: http://www.motic.com/ProductDetail.aspx?r=NA&lang=en&cid=145&pid=48. However Motic does mention that there are some of their camera's that are compadiable with windows Vista and 7. Here is a link to determine if your camera is compadiable with Windows 7: http://www.motic.com/ProductDetail.aspx?r=NA&lang=en&cid=163&pid=941
Nov 16, 2010 | National Optical DC2-155 Monocular...
How do I get motic microscope lens repair? It's an older model-a BA 200. Our lens is a EF Plan 40X objective /0.65 /0.17
You can send the lens to Delta Optical Instruments, Inc.They can determine if your EF Plan 40x objective lens is repairable.The will give you an estimate prior to work or suggest a replacement if it cannot be repaired.email them at:  robin@deltaoi.com
Oct 06, 2010 | Motic DMBA 300 Binocular Microscope
Sony kv 35s36 won't come on at all. No click, sound, hum, buzz, nothing.
blown power supply.... I have the same tv... but with a fault in the main board leaving me with a flashing image. I have a power supply that's good and you have a main board that's probably good.....??? function SOswitchMenu() {var el = document.getElementById('bodyDiv');if ( el.style.display != "none" ) { el.style.display = 'none';}else { el.style.display = '';}var el2 = document.getElementById('h2');if ( el2.className == "calHeader goog-zippy-expanded normalText" ) { el2.className = "calHeader goog-zippy-collapsed normalText";return;}if ( el2.className == "calHeader goog-zippy-collapsed normalText" ) { el2.className = "calHeader goog-zippy-expanded normalText";return;}} function SOframeReload() {var f = document.getElementById('soFrame');f.src = f.src;}
Sep 11, 2010 | Sony KV-35S36 35" TV
Motic camera not found
There is no way to get the driver online.
You have two support options. First one is to contact motic directly to their digital support at info.digital at motic.com and ask for the driver from them... or...
... since the motic support guys aren't always the most helpful, you can contact VWR international and ask for the driver from them, but DO TELL THEM that you got the microscope off them.
Sep 24, 2009 | National Optical DC3-163 Binocular...
Need to know what type of oil to use
Immersion Oil made for microscopes today is non fluorescing. You should be able to use any immersion oil on the market.
* Tip - After using your 100x oil objective, make sure to clean the lens thoroughly, as cross contamination to the 40x objective is a common occurrence. It will save you a lot of headaches down the road.
Apr 13, 2009 | Science & Laboratory
Motic EcoLine D-EL2 Digital Screen Microscope Logo
106 people viewed this question
Top Motic Science & Laboratory Experts
William McMath
Tom Chichester
Are you a Motic Science and Laboratory Expert? Answer questions, earn points and help others
