Question about Dryers
My washer and dryer are acting like magnets, attracting and sticking metal objects to them. Also the dryer is not drying well. What is causing this?
    Champion:
  • 320 Answers
The dryer may have an electrical short in it and causing the two to act like an electromagnet. I strongly suggest calling in a qualified technician for this as shorts are extremely dangerous and life threatening.
Posted on Oct 31, 2013
Why do I have no spark at the coil
A few things can cause lack of spark at the ignition coil. This assumes pointless ignition system.
  • The stop terminal is intentional grounded IE stop switch on.
  • The stop circuit is shorted to ground.
Remove the plug wire from the plug so engine can not start. Remove the stop wire from the coil and try starting the engine while testing spark. If spark is now present then check the stop circuit.
  • The coil pack itself is bad.
  • Flywheel magnets are demagnetized.
These can check by seeing they attract heavy metal object strongly.
Dec 24, 2014 | Coleman Powermate Powermate 5000W...
How does a sattelite fall if there is no gravity in space
Gravity is a force that causes a mass/object to be attracted to another mass/object similar to magnetism. Gravity is not an object itself located in any particular place like earth or space.
The satellites stay in orbit around the earth because the force propelling the satellites forward away from the earth is balanced by the gravity pulling them back to earth.
The satellites move too slow and they fall back to earth. If they move too fast, they fly out further into space and out of orbit.
I hope this answers your question.
Sep 26, 2011 | Computers & Internet
With the lint screen removed, a metal object was dropped down the opening.How do I get it out?
An expandable Magnetic pick up grabber:
http://www.amazon.com/Telescopic-Magnetic-Pick-Grabber-Black/dp/B000RB3XA6
If not, you may need to remove the panel to get it out
Jun 09, 2011 | Kenmore Dryers
Dryer making a grinding noise when turned on. How do you get the top off to check the barrel motor?
Clanging Sound
1. If the noise coming from your dryer can be described as a clanging sound, the solution is probably well within your grasp. This common sound is typically the result of loose debris accidentally put in with the load of laundry. Change may be left in pockets of pants or other objects may be dropped in the laundry basket by children --- perhaps a toy car. The objects may not be noticed when put into the wash, and the water in the washer may have dampened the sound. Simply remove these items, and restart the dryer to resolve the issue.
Sometimes the clanging is from snaps or buttons that are actually part of the clothing. If you are drying a jacket with metal snaps or another garment with metal attached, you should expect this clanging sound as they tumble and strike the inside of the dryer tub.
Humming or Whistling
2. Many Roper dryer models are equipped with a safety feature known as a lint signal, which is usually a light that often accompanies a warning signal, telling the machine owner that the lint trap has become clogged. When the dryer cannot pull adequate air through the lint filter, it can overheat and become a fire hazard. The warning alarm may sound like a hum or whistle to get your attention. Look at the lint signal light, clean out the trap and the noise should stop.
Thumping or Grinding
3. If the noise you are hearing can be described as a thumping sound or a metal grinding sound, the device that turns the dryer drum, known as the drum rollers or glides, can be worn out. As the drum turns, there may be a constant and rhythmic thump each time the drum rotates. A severely worn or broken roller could cause the metal of the drum to rub against the metal housing of the machine, causing a louder grinding noise. The rollers will need to be replaced to remedy the problem.
Squeaking or Squealing
4. Most dryers work by using belts to turn the rollers, which in turn make the drum rotate and tumble the clothes dry. When these belts get loose, a worn belt or a malfunctioning tensioner spring may keep the belt tight. In either case, belt slippage may occur and will produce a squeaking or squealing sound that is easily recognized. The problem is likely to be the tension on the belt since most belts will break before wearing out to this degree.
Feb 24, 2011 | Whirlpool Dryers
The DVD drawer will not open unless a disc is in the drive. When the drawer would not open I took the cover off the player. The DRC8295N is a VCR-DVD/R RW player recorder. The DVD drive will record on...
The problem isn't with the motor being too weak, but the belt which the motor drives. I had the EXACT problem just as you described. What I did was I took off the belt and cleaned it with rubbing alcohol because apparently the belt picked up some of the grease from the gears and wouldn't rotate when the motor spinned. This belt actually pulls down the mechanism, on which the CD sits, from the magnet. So, just clean the belt and you should be good to go. If the belt is very loose, you might need to replace it.
Feb 14, 2011 | RCA DRC8295N DVD Recorder/VCR
Something fell in side the lent catcher on my kenmore 70 series dryer and now its making a very loud noise how can i take it out
Was it metal? Attach a small magnet on a thin stick or string and pull the thing out. Not metal? Something else to attach an object: sticky tape, wire hook.
No luck? Call Sears and ask their repair department for instructions.
Or call Kenmore customer service for advice.
Jan 23, 2011 | Dryers
My dryer makes a thump thump sound
  1. Thoroughly check the inside of the dryer for any foreign objects with hard surfaces. Sometimes items that fall out of pockets become stuck inside a dryer and make thumping noises.
  2. Check for level
  3. Make sure the dryer is level. A dryer that is out of level may not rotate properly. Banging or thumping noises from unleveled dryers are common, particularly if the dryer is resting against another metal object such as a washer.
  4. Check rollers
  5. If the thumping noises are present only for the first few minutes of the drying cycle the likely culprit is rollers. If the rollers are warped they will need to be replaced and a professional should be called in to help
Dec 17, 2010 | Frigidaire Electric Dryer
Dryer works, but makes noise.
There are a lot of moving part that can cause noises or vibration when get worn out.
  • Make sure dryer is level, and on a secure floor, and that nothing is leaning against the dryer.
  • Check all exposed screws, and make sure they are tight. Loose cabinet screws may cause a squeak.
  • Check for foreign objects below the lint filter:-Remove lint filter, and look down opening. If you need to stick your hand down the opening to remove an object, be careful because the edges could be sharp. It would be advisable for you to wear a pair of work gloves.
  • Foreign objects in the drum front seal and worn or loose drum slides can cause a metal scraping noise as the drum rotates.
  • Check for foreign objects in the drum. (Coins, buttons and zippers will make a rattling sound as they roll around in the drum)
  • A frayed or damaged belt will make a thumping sound.
It is normal to hear the sound of the drum as it turns. If your dryer is making unusual noises and the above suggestions do not resolve the situation, discontinue use of the dryer until it has been checked by a qualified servicer. Continued use may cause wear of other parts making the repair more costly.
Thanks..!!
Sep 19, 2010 | Kenmore Elite HE4 Electric Dryer
My Roper Washer RTW43405Q0 won't spin.
For the washer to operate the lid must be fully closed, the timer must be pulled out, and the water must be drained.
The main causes for not spinning are:
  • Lid partially or completely open
  • Lid or other object has hit the timer knob and turned the washer off
  • Lid not locked (by the way, not on all washers) and may be not draining.
    Make sure the lid is completely closed. Make sure that no clothing is in the lid area.
    Make sure the Timer knob is pulled out.
    The lid must be closed and locked for the washer to operate. Once the lid is closed, make sure the desired cycle is still selected and then press the Start button and listen for the lid to lock.
    Make sure there are no loose metal objects such as coins and paper clips in the lid opening area. Metal objects can prevent magnetic switches from reacting correctly when the lid is closed.
    If the washer has not drained, it will not go into spin.
    Hope this works.....
    May 01, 2010 | Roper RTW4300SQ Top Load Washer
    I DROPPED A METAL HOOK IN THE DRYER LINT AREA, CAN I REMOVE IT MYSELF?
    Yes you can. If you can see it, try using a magnet taped to a stick, or adhesive tape rolled sticky side out on a stick. If you cannot see it, get a dryer brush (~$10 @ Lowe's/similar). Bend the brush to approximate the curvature ofyour lint caxity and sweep it back towards you. Once you can see it, try the tape or magnet trick to remove it. Don't go any further into the dryer without unplugging the dryer.
    Best regards, and happy fishing!
    --W/D--
    Jul 19, 2009 | Kenmore Elite Oasis ST 6806 Electric Dryer
    Dryers Logo
    Top Dryers Experts
    Dan Webster
    Dan Webster
