I forgot the combo for my Kryptonite bike lock US PAT 593412/6422051, can you please help? Thank you
Another way is to pull apart the ends till you have tension on the tumblers. As you place tension try to turn the tumblers. As you feel each loose or tight tumbler is how you can find your combination. I open this type of combination lock like this all the time. First look for the tightest tumbler, turn it until it feels looser and next look or feel for the next tight tumbler. All the tumblers do not block the release at once. You are looking for the first tumbler to adjust, the tightest one, then the next, continuing until you find you have released all the tumblers. This has worked for me with any brand of inline tumbler release system out there. Good luck, usually takes me about 10-15 minutes to find the code. This method can be used on regular locks with a changeable combination as well. It will just take a little time to get to know how much tension to use as you go through each tumbler. Similar as to how you pick a regular lock system. Good luck, definitely doable.
