Question about Casio FX9750GII Graphic Calculator
Scientific notation my calculator automatically translates all decimals smaller than .001 into scientific notation and I need to see the decimals not the notation. how do I change the answers to come in in standard notation?
  • Casio Master
  • 8,073 Answers
All calculator use scientific notation if the result is too small or too large. Some, like the Casio FX9750G II, offer you two Normal displays, Norm1 and Norm2 that have different limits when numbers are converted to scientific notations.
Here is how to set one or the other.
In Run>Mat press SHIFT MODE (Setup). Scroll down or up to reach the display line. Press F3 to select Norm1 or Norm2.
Posted on Oct 22, 2013
4 Suggested Answers
  • 146 Answers
SOURCE: After working a simple problem adding numbers in
For converting answer in to scientific notation do the following steps.
1.click shift key after that press mode key next to on button.
2.From the menu that is displayed in the screen press 7 for displaying answer in scientific notation.
Thank you.
Posted on Jun 10, 2010
Testimonial: "Very quick and helpful response. Thanks much"
  • 102366 Answers
SOURCE: Casio FX-115ES Scientific Calculator How can I get
Change the display mode. Press SHIFT MODE 6 then the number of desired digits after the decimal point. Alternatively, press SHIFT MODE 8 and select one of the "Norm" modes.
This is all in the "Specifying the Number of Display Digits" section on page E-8 of the manual.
Posted on Sep 28, 2011
  • 2386 Answers
SOURCE: how to turn scientific notation into standard
Hello
Press SHIFT then MODE then press either 6 to specify a fixed decimal notation or 8 to specify floating decimal notation.
Hope this helps
Posted on Oct 04, 2011
WHAT IS THE E CODE
Does the E code look like 10.8372487489E12?
If so, the calculator is either set to scientific notation mode OR the result was an answer that was too big to display on the calculator, so it converted it to scientific notation. To convert from scientific notation back to regular notation, move the decimal to the right by the number of times after the E. In this case, the number after the E is 12, so we have to move the decimal to the right 12 times. In this case, I get the final answer as 10 837 248 748 900.
Good luck.
Any questions, let me know.
Paul
Jan 27, 2014 | Casio DR-250HD Calculator
Remove scientific notation exponent
Press MODE then select "NORMAL" on the first line. Optionally, you can select the desired number of digits after the decimal point on the second line.
Be aware that if the magnitude of the result is too large or too small then the calculator will automatically switch to scientific notation no matter what settings you have.
Jul 25, 2013 | Texas Instruments TI-83 Plus Calculator
How to I stop my sharp EL-531X calculator from rounding when converting from decimal to scientific notation?
You need to select the number of decimal places you would like, or if you would like the calculator to behave as normal. Press SET UP and select FSE (press 1) . You now have 5 options.
0: FIX means you can choose a fixed number of decimal places for every calculation.
1: SCI means scientific notation and choose the number of significant values you would like to deal with.
2: ENG means engineering and the power goes up in multiples of 3.
3: NORM1 and 4: NORM2 are the usual or normal settings on the calculator. Most school calculations will use NORM1 mode.
Aug 28, 2012 | Sharp El-531x Scientific Calculator Green...
Turn Scientific notation off
Sep 16, 2011 | Casio FX-115ES Scientific Calculator
I cannot get the answer in decimal format. I have tried everything in the manual, and also online suggestions. Here's an example: Evaluate: (.2) with exponent of 4... the answer should be .0016,...
In the default NORM1 display mode, values whose magnitude are less than 0.01 are automatically displayed in scientific notation.
Press SHIFT MODE 8 2 to select the NORM2 display mode. In this mode, the calculator does not switch to scientific notation until the magnitude drops below 0.000000001 .
This is all described in the "Calculation Modes and Calculator Setup" section of the manual, beginning on page E-7.
Sep 07, 2011 | Casio FX-115ES Scientific Calculator
When I introduce a 10^-4 I get 1E-4, how do I change it to decimals, no "E". -thanks
You can't. If the magnitude of the number is less than .001, the calculator automatically switches to scientific notation. That's just the way the calculator works.
Nov 24, 2010 | Texas Instruments TI-84 Plus Silver...
Anytime I try to multiply .001X.001, any decimal beginning with a zero, I get an error. For example, .001X.001=1 E-6...My mode is set in normal, and I reset it to default, what am I missing?
This is not an error. .001 multiplied by .001 is 1E-6.
If the absolute value of a number is less than .001, the calculator will always display it in scientific notation. 1E-6 is interpreted as 1 times 10 to the minus sixth power.
Oct 11, 2010 | Texas Instruments TI-84 Plus Calculator
After working a simple problem adding numbers in scientific notation, I want to convert the answer, a decimal, to scientific notation
Thank you.
Jun 10, 2010 | Casio FX-115ES Scientific Calculator
HOW DO I CHANGE MY MODE TO REGULAR MATH EQUATIONS FROM SCIENTIFIC NOTATIONS AND EGINEER NOTATIONS ,WHAT HAPPEN WAS IM A STUDENT IN COLLEGE ,AND MY TUTOR WAS DOING SOME EXAMPLES ON SCIENTIFIC NOTATION AND...
Press [SHIFT][MODE][6:Fix] and press a numbetr between (0--9). The number you select will be the number of decimal places your results have.
However if a result is smaller than 0.001 it will be in scientific notation.
Hope it helps.
Oct 09, 2009 | Casio fx-300ES Calculator
I have an HP 12C calculator and I cannot find the user manual and I cannot remember how to change the no. of decimal places?
Check this HP FAQ:
Setting a Fixed Decimal Place You can download the manual and user guides for your calculator from here:
http://h10025.www1.hp.com/ewfrf/wc/manualCategory?lc=en&dlc=en&cc=us&product=81575&lang=en&
For more information, Faqs & how-Tosgo the HP support homepage for your calculator:
http://h10025.www1.hp.com/ewfrf/wc/product?lc=en&dlc=en&cc=us&lang=en&product=81575&
Introduction This document describes how to set the desired number of decimal places on the HP 12c calculator in standard format. It also covers how to enter a number in scientific notation. Instructions for standard format
  1. Press and release c01774993.jpg .
  2. Press the number key for the desired number of decimal places to be displayed to the right of the decimal point (0 through 9). The calculator displays a maximum of 10 digits.
The display will show the specified number of decimal places. The answer will be rounded to the number of digits selected. Example (standard format) If the number in the display is 14.87456320, the display will be changed as follows: Keystroke Display c01774994.jpg 14.8746 c01774995.jpg 14.9 c01774996.jpg 15 c01774997.jpg 14.87456320 Instructions for scientific notation Use scientific notation for very large or very small numbers. Type in the mantissa. After pressing, c01774998.jpg the next numbers keyed in are exponents of 10. Press c01774569.jpg . If during an operation a result has more than 10 digits, the calculator automatically displays the number in scientific notation
Aug 24, 2009 | HP 12c Calculator
Casio FX9750GII Graphic Calculator Logo
795 people viewed this question
Top Casio Office Equipment & Supplies Experts
k24674
jasbo
jasbo
Are you a Casio Office Equipment and Supply Expert? Answer questions, earn points and help others
