Hotpoint fault code f01 - Washing Machines
barkencoa
  • 3463 Answers
SOURCE: Hotpoint WMD washing machineFault Code F01 machine will not start
Fault code F01 indicates a problem with the motor triac.
Check all connections to and from the motor, the control module, and the motor plug
Posted on Jan 09, 2010
barkencoa
  • 3463 Answers
SOURCE: What does a fault F01 signify on a Hotpoint Ultima
Error code F01 indicates a short circuit motor triac.
Thoroughly check all connections on the motor, the motor plug, and the electronic module board..
Look for a broken wire, or a bad connection.
Please rate my solution.
Thankyou.
Posted on Jan 22, 2010
barkencoa
  • 3463 Answers
SOURCE: have a hotpoint WF865 washing machine with the
It usually means that you need to replace the control module.
Posted on Aug 20, 2010
  • 6277 Answers
SOURCE: Hotpoint Aquarius WF640 - What
My list for nearly all of the Indesit (Hotpoint, Ariston) washers suggests there is a fault with the motor triac, the bit that controls the motor speed, sorry ;-0(
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
Posted on Sep 10, 2011
Daniel S
  • 4323 Answers
SOURCE: Bosch Washing machine WFP 3300 Fault
Hi
F01 is a low water pressure error and is caused when the washer won't fill water, check the water inlet valve if that is fine and there is no clogs in the inlet hose then the water level switch/pressure switch should be replaced. Hope this helps...please post back for further assistance.
Daniel
Posted on Sep 12, 2011
Aqualtis washing machine has error code F01 what does this mean?
F01 Electronic circuit board fault
Issue: Washing machine is not operating - some or all functions are not selectable.
Advice: We recommend you disconnect (unplug) the appliance from the mains supply for a minimum of 2 minutes. Reconnect supply and wait 30 seconds and try starting the machine again.
Jan 14, 2016 | Hotpoint Aqualtis AQXXL129PM Washer Front...
Hotpoint Aquarius WF640 - What is Fault code F01 please?
John C
Sep 10, 2011 | Hotpoint Aquarius WD640 Front Load...
Showing F01 error code on readout? what does that mean?
Hi.
It depends on the model. On Whirlpool built machines F01 is EEPROM error, pump drive error, or main relays error.
With Hotpoint F01 means defective triac or defective motor.
Aug 18, 2011 | Washing Machines
Code f-01
Hi.
F01 is pointing at a fault of the motor triac. The motor triac is part of the control assembly and controls the motor.
Try disconnecting power cord. If the fault code comes back, then motor, motor brushes, wiring or control module may need replacement.
Aug 06, 2011 | Hotpoint Ultima WF860 Front Load Washer
Wf860 washer dryer - dryer has no heat and displays f01
Hi, Fault code F01 indicates a problem with the motor triac.Check all connections to and from the motor, the control module, and the motor plug
Apr 08, 2010 | Hotpoint Ultima WF860 Front Load Washer
What does a fault F01 signify on a Hotpoint Ultima 7kg washing machine?
Thankyou.
Jan 22, 2010 | Hotpoint Ultima WF860 Front Load Washer
Jan 09, 2010 | Washing Machines
Have a fault code show on washing machine f-01 hotpoint wd640 Thanks Paul
F01 - motor triac on main pcb. check motor connections/brushes etc if not will need new pcb.
Oct 21, 2009 | Hotpoint Aquarius WD640 Front Load...
I have a Hotpoint ultima wt960 with f01 error can I fit the part
Hi
f01 means motor fault. remove motor and check the brushes. if ok then fault could either be motor or pcb which is faulty.
regards
Mar 21, 2009 | Hotpoint Ultima WF860 Front Load Washer
Washing Machines Logo
13 people viewed this question
Top Washing Machines Experts
