Rachelraymag com myaccount
Renew sub on line...how?
How do I check my balance for time and days remaining
From your phone:
  • Dial #WEB# (#932#) to check used and remaining high-speed data for your current billing cycle.
  • Dial 611 at any time to connect to our automated telephone system. When you're prompted, say "data usage" to check your line.
  • We've even got an app! Download and use MyAccount to check usage for your line and other lines on your account.
From your tablet or computer: Log in to your My T-Mobile account. After you log in, click USAGE to see the per-line usage under the DATAcolumn. You can even check usage history. It's that simple!
Jun 02, 2015 | Samsung Cell Phones
I need to change my card number on my pay pal
Log into your pay pal account
You will see several tabs across the top of the page including....MyAccount, Send Money ...etc
Under the My account Tab there are several options including Profile
Hover your mouse over Profile and you will see a sub menu of options including Add or Edit Credit Card
Click that option and you will be presented with a screen where you can remove an existing card or add an additional card
Follow the relevant instructions provided by PayPal to update and save your details
Sep 20, 2014 | Computers & Internet
Dap 1160 Problem access web admin page
connect device directly to your computer using Ethernet cord. try to release and renew IP from the command prompt
IPCONFIG /RELEASE
IPCONFIG /RENEW
IPCONFIG /FLUSHDNS
then perform ipconfig. From there you will be able to get the IP address of the access point that you will need when accessing web admin page
Dec 22, 2012 | D-Link DAP-1160/B ACCESS POINT, WLESS G,...
My password is not working.
if this is a password you used on rachelraymag.com then you'll
have to contact them about the password
Dec 10, 2012 | rachaelraymag.com
Replaceing internal fuse to mackie active sub woofer swa 1501
Hi There, you need to check the 3 fuses that clip onto the main amp board. You can access them by undoing the two screws that are on the top and the bottom of the sub. They have flat large heads and you will need a hex key to unscrew them. If it is one of the fuses that has gone it will either be discoloured as in burnt or you will see the metal inside has split. Simply replace these by pulling out the burnt out fuse and replace with a new fuse and hey presto you should be back up and running. If you need any parts for the sub or fuses then www.LondonSpeakerShop.com will be able to supply them (that is if you're in the UK). Also the offer a service of swapping them over for you if you really don't want to do it yourself. Hope this helps. Grant (from www.LondonSpeakerHire.com)
Oct 07, 2008 | Mackie SWA1501 Subwoofer
My songs won't synchronize
That's true - that's the problem with music sub svcs that give you wma's - after the sub expires, your songs are not playable until you renew the service. If you don't care about the legality, you can get a drm stripper. Otherwise, just go with mp3 format songs from here on out.
Sep 08, 2008 | Philips GOGEAR SA6045 MP3 Player
Computers & Internet Logo
102 people viewed this question
David Payne
David Payne
