Question about Homelite RIDGID 3000 PSI 26 GPM CAT Pump Pressure Washer RD80903
Subaru Rigid 3000 PSI pressure cleaner will start and run for a few minutes in choke position only. then must sit for an hour before it will start again. I drained gas it appears not to be getting gas as if the feed line is blocked. With the bowl off and float down no gas comes out. Is it possible that the gas in the fuel line jelled, the pressure cleaner was not run for about 6 months?
  • 32 Answers
It is more likely that the crappy 10% ethanol gas ate the fuel line up and turned it to mush.
Posted on Apr 02, 2014
How do i drain the gas from my Rigid 3000 psi pressure washer with Subaru engine?
Then the next easiest step is to use a turkey baster and suck it out through the fill hole.
Jul 13, 2015 | Psi Garden
How do I fix an idle issue with my Ridgid 3000 psi pressure washer?
Run some carburetor cleaner through it first. Go to autozone, etc, and pick up some fuel system cleaner you can put directly in the tank and run it through.
Jun 21, 2014 | Ridgid Garden
What causes funny idle with a rigid 3000 psi pressure washer
Get some fuel system cleaner you can put directly into gas tank from autozone, etc, parts store and run it through before you do anything else.
Motor will start on choke setting and then it immediately dies when moving the choke lever to the run position. Cleaned carb, new plug new air cleaner and checked all linkages. the motor has new oil and...
You say you cleaned the carb. If you did that by spraying cleaner in through the choke, that's good, but it doesn't get to the root of the problem. The problem is getting the gas into the carb. Try this. drain the gas. Put a small amount of carb cleaner and gas in the tank (about 1:1) Start it up, but don't run it dry. Let it sit for an hour. Then start it up and run the tank dry. Then try just a little gas to see if that fixed it. If not, repeat. Good luck Al K
Dec 23, 2010 | Honda Garden
190 honda engine only runs on choke?
pour a large amount of carburator cleaner into the gas tank
run the engine for five minutes then shut it off and let it sit for a couple of days.
then start it and see if it runs any better
the longer you let it sit with the carb cleaner in it, the better it should run
Aug 08, 2010 | Honda 50 W Ar Pump 2500 Psi 25 Gpm...
My honda presure washer keep flooding, if i try to restart it after use it want start. i have to let it sit for few hours?
Make sure that the choke link is intact, so when you push in the choke it actually does it. I hope this helps. Good Luck and have a great day.
Apr 03, 2010 | Honda Pressure Washer PSI 3000
Im having a problem keeping the motor running. it cuts off and will re-start easily and run in the choke mode? won't run in the normal mode until i cut it off and re-start. then it will run for about 5...
Hello. Your carburator is gummed up. Get a can of seafoam fuel additive at the auto parts store and put the recommended amount into the gas. This will clear up the problem in just a few minutes. Joe
Mar 16, 2010 | Northstar Pressure Washer 3000 PSI
Homelite RIDGID 3000 PSI 26 GPM CAT Pump Pressure Washer RD80903 Logo
87 people viewed this question
Top Homelite Plumbing Experts
richie46
Gil Shultz
Robert Dean
Robert Dean
Level 1 Expert
Are you a Homelite Plumbing Expert? Answer questions, earn points and help others
