Question about Juniper WLC800-U16 - Networks Wireless LAN Controller WLC800R - lic
Hp wireless network printer not connecting with juniper Access point
    Filmmaker:
    Uploaded 5 video answers.
  • 196 Answers
Simply follow hp wizard Guide , but make sure in setting
IP adress in same subnets
Posted on Nov 08, 2013
Check connections
The connection of the USB cable
Verify that the USB cable is connected between your Brother machine and your PC.
The connection of the LAN cable (if applicable)
Verify that the network cable is connected between your Brother machine and access point and the machine is powered on.
1.Access point/router
2.Wired Network machine (your machine)
3.Wireless capable computer connected to the access point/router
4.Wired computer connected to the access point/router
The connection of the Wireless network
2.Wireless Network machine (your machine)
Still having Problem Then follow Us For
Brother Printer Support
Feb 20, 2014 | Brother MFC 7840W Printer
Wifi light is orange
The colors of the WiFi indicator light show the network status of the printer.
  • Off means one of the following:
    • The printer is turned off or is powering up.
    • The printer is not connected to a wireless network and in power saver mode. In power saver mode, the power light pulses on and off.
    • The printer is connected to an ethernet network. Refer to the Quick Reference Guide to find out if your printer has ethernet capability.
  • Solid orange means one of the following:
    • The printer has not yet been configured for a wireless network.
    • The printer is configured for an ad hoc connection, but it is not currently communicating with another ad hoc device.
  • Blinking orange on the WiFi light means one of the following:
    • The printer is out of the range of the wireless access point (wireless router).
    • The printer is trying to communicate with the wireless access point but the wireless point is turned off or not working properly.
    • Either the configured printer of the wireless access point has been turned off and back on, or the printer is trying to establish communications with the network.
    • The wireless settings of the printer may no longer be valid.
  • Green means that the printer is connected to a wireless network and is ready for use.
Feb 02, 2012 | Lexmark Z Office Equipment & Supplies
How do I have the printer recognize the router so I can print from my laptop from another room please? I have a C27250
Make a wireless connection between an HP all-in-one with built-in wireless networking capability and a functional wireless network with an access point (router) that is SecureEZSetup enabled.
Connecting the unit to the computer
  1. Activate SecureEzSetup on the access point (router). Usually this is accomplished by pressing a button on the access point. Refer to the router or access point documentation for specific instructions.
  2. Press the Setup button on the all-in-one.
  3. Press the arrow buttons until Network displays and then press OK . The Network menu displays.
  4. Press the arrow buttons until Wireless Setup Wizard displays and then press OK .
  5. Follow the instructions in the Wireless Setup Wizard.
  6. After the all-in-one connects to the network, install the product software on the computer.
Regards,
Rizwan
Jan 19, 2010 | HP Photosmart C7250 All-In-One Thermal...
Can't scan
To test the hardware, use the product to copy a document.
1.open the scanner lid.
2.put a document face down on the glass.
3.close the scanner lid.
4.press the copy button.
make sure that the product connects to the network
ethernet connection
1.Disconnect the network cable from the back of the product, and then wait a few seconds.
2.Reconnect the network cable to the back of the product.
3.Make sure the other end of the network cable connects securely to the router or switch
4.Make sure that the lights on the router or switch are on.
5.Continue to "Step three: Print a network configuration page and find the IP address."
wireless network
  1. Make sure that the router or access point is on.
  2. Position the router or access point closer to the product.
  3. On the product, press the setup button , and then select the network option.
  4. Select the wireless setup wizard option. The product searches for the router or access point.
  5. Select the 'enter the new network name'(SSID) option.
  6. Type the service set identifier (SSID) or the name for the wireless network, and then select 'done' . The product searches for the network.
  7. Select the relevant authentication protocol, also called the security mode. Supported protocols include WEP (64 bit and 128 bit) and WPA-PSK (WPA1 or WPA2, AES or TKIP). Networks that do not use an access point or a router, known as ad hoc networks, support WEP encryption only.
  8. If the network uses media access control (MAC) address filtering, make sure that you have the router or access point set to allow the MAC address for the HP product.
  9. Follow the instructions to configure the product for your method of network security:
  10. WPE: Log on to the router or access point from the computer, and then find the wired equivalent policy (WEP) key set within the router or access point. If you specify the WEP by using 10 or 26 hexadecimal characters, make sure that the characters are 0-9 and A-F. Use the on-screen keyboard on the control panel display to type the WEP key on the product.
  11. WPA: Log on to the router or access point from the computer, and then find the Wi-Fi Protected Access (WPA) passphrase set within the router or access point. Use the on-screen keyboard on the control panel display to type the correct WPA passphrase.
make sure that the product is connecting to the network, print a network configuration page from the product and find the IP address on the page.
1.On the product control panel, press the Setup button
2.Select Network , select Network Settings , and then select either Print Network Settings or Print Network Configuration Page . The network configuration page prints
3.Make a note of the IP address for the wired or wireless connection. The IP address should resemble the example: http://192.168.1.1
4.If the computer connects to the Internet using a wired connection, the IP address displays in the Wired section.
5.If the computer connects to the Internet using a wireless connection, the IP address displays in the Wireless section
Jul 21, 2009 | HP Officejet 4315 All-in-One Printer
HP printer cannot find access point and I'm not sure what to do.
You must first connect your printer to the pc using usb cable, then run installation wizard that is on the CD that came with the printer.
Wizard will guide you through the setup orcess where you will provider your routers ssid (linksys) to your printer, and your printer will use that ssid to connect to your router.
After the Wizard setup is done, it will tell you to disconnect the usb cable and only then your printer will work on wireless.
Good luck,
Milan
Jun 01, 2009 | HP Office Equipment & Supplies
Hp Pavilion dv6929nr not connected with D-link DI-624
There are a number of factors that can cause the signal of your access point to deteriorate and the performance of your network to fall under par. Practically any appliance that operates on the same frequency level (2.4 GHz) as 802.11b or 802.11g can cause interference with your wireless network. Be sure to keep cordless phones, microwaves and other electrical equipment at least 1m away from the access point. Try changing channels on the access point and test it out on one of the clients. To change the radio channel on the access point login to the configuration (usually a web based interface) and go to the Wireless Settings (will vary depending on vendor) section, select a different channel and save settings. On the client, go to Device Manager, right click your wireless network adapter and go to Properties. In the advanced tab select the Channel Property and change the Value to the same number as the one you chose on the Access Point. Disable and then re-enable the wireless connection. Also you can try by select the speed manually 802.11b or 11Mbps on your laptop wireless properties.
PLZ GIVE RATING BY CLICK ON YES or NO.
Mar 21, 2009 | HP Computers & Internet
Can't connect 2 pc to 1 printer
Steps to fix your issue
  1. install printer driver on one computer
  2. Make sure both computers are connected in same network by ethernet cable or wireless connection.
  3. share the printer on 1st computer
  4. access the shared printer from 2nd computer through network
This way your can access one printer from 2 computers. This setup work only when the 1st computer is turned on because HP leaser jet don't have the capability to work as network printer as they cannot acquire IP address.
If u need further information on how to configure 2 computer please refer below link
http://www.ajcsoft.com/connect_computers_together.php
For information regarding how to share printer on windows XP refer below link
http://www.microsoft.com/windowsxp/using/networking/expert/honeycutt_july2.mspx
Dec 30, 2008 | D-Link AirPlus Xtreme G DWL-2000AP...
Routing between subnets on Juniper Netscreen 5gt Wireless
hi
you want to create security policy between the wired interface and wireless interface.
eg:
wired is trust interface
wireless is wireless interface.
create a rule between trust to wireless.
as well as rule between wireless to trust.
Reagrds,
Mani.S
Dec 16, 2008 | Juniper Networks NetScreen 5GT...
I have a sony vaio laptop running xp sp2 connected wirelessly to an HP C4385 printer. I can't get it to print in this wireless mode and I can't get a response from the printer when I put the printers IP...
I suggest you network the printer and access it through the wireless access point.
Also, I do not mean to insult your computer smarts, but if you do not have a driver installed, you will not be able to talk to the printer at all.
Aug 14, 2008 | Computers & Internet
I have a laptop run Vesta trying to set wireless connection to HP Potosmart C4385 print using ad hoc network setup. When selecting Ad Hoc connection in the printer setup it saids it can not find it or...
For this specific issue about installing the printer to a wireless connection. You need to install the software first as a usb connection. After the successful installation of the usb connection then you can add a device and it should work.
Step one: Gather the necessary hardware and information Follow the procedure below before obtaining your wireless network:
  1. Obtain your network SSID and WEP. To simplify this process, press the Wireless button on the all-in-one, and select Restore Network Defaults . This turns wireless off and sets the all-in-one's SSID to hpsetup .
  2. Press the Wireless button to turn wireless back on. Look for hpsetup when you select your network.
  3. Make sure that wireless is enabled on the all-in-one.
  4. Make sure that the computer that will be using the all-in-one has access to the router/access point.
You will need the following to set up the product on a wireless network:
  • A wireless 802.11 network that includes a wireless access point.
  • A desktop computer or laptop with wireless networking support or a network interface card (NIC).
  • Broadband Internet access is required for some features of the HP software to function. Cable Internet or DSL are examples of Broadband Internet access. NOTE: If you connect the unit on a wireless network that has Internet access, HP recommends that you use a wireless router (access point or base station) that uses Dynamic Host Configuration Protocol (DHCP).
  • The network name, or Service Set Identifier (SSID). NOTE: The SSID is obtained from the wireless router or access point using the embedded web server on the router. See the documentation provided with the access point for more information.
  • The Wired Equivalent Privacy (WEP) key or Wi-Fi Protected Access (WPA) passphrase, if needed. CAUTION: To prevent other users from accessing your wireless network, HP strongly recommends using a password or passphrase and a unique SSID to your access point. Your access point might have been shipped with a default SSID, which can be accessed by other users using the same default SSID. For more information on how to change the SSID, see the documentation that came with your access point. NOTE: The WEP key and WPA passphrase are obtained from the wireless router or access point using the embedded web server on the router. See the documentation provided with the access point for more information.Some access points provide more than one WEP key. Use the first WEP key (index 1) when setting up the wireless network.
  • If the network is set up with an Apple AirPort base station and you are using a password instead of WEP HEX or WEP ASCII to access this network, you need to get the equivalent WEP key. See the documentation that came with the Apple AirPort base station for more information.
  • If IP address filtering is set up, verify that the unit address is listed.
  • If MAC address filtering is set up, verify that the unit address is listed. NOTE: HP cannot set up or change the SSID, WEP key or WPA passphrase. This information is required before connecting the HP All-in-One to the wireless network.
Step two: Connect to an integrated wireless WLAN 802.11 network Follow the procedure to connect the unit to the wireless infrastructure network:
  1. Insert the software CD.
  2. Click Install .
  3. Click Next on the Please Allow All HP Install Wizard Processes screen.
  4. Select Easy Install on the Choose Easy Install or Advanced Install screen.
  5. Select Through the Network on the Connection Type screen. Figure 2: Connection Type screen c01160788.jpg
  6. When it doesn’t find your device, click Next . Figure 3: Using Network Setup c01164746.jpg
  7. Plug in your device via USB (it will tell you when to disconnect later). Figure 4: Making a connection to your all-in-one c01160790.jpg
  8. Select your network from the list, and click Next . Figure 5: Wireless Network Setup c01160791.jpg
  9. Enter your WEP key (if applicable). Figure 6: Specifying your network security settings c01160792.jpg
  10. Once it has completed connecting to the network, click Next . Figure 7: Network connecting completed c01160793.jpg
  11. Disconnect the USB cable from the computer and the All-in-One . Figure 8: Disconnecting the USB cable c01160794.jpg
  12. Click Finish to complete the software installation process. Figure 9: Software installation complete c01160795.jpg
Aug 04, 2008 | HP Office Equipment & Supplies
Juniper WLC800-U16 - Networks Wireless LAN Controller WLC800R - lic Logo
89 people viewed this question
Top Juniper Computers & Internet Experts
David Payne
David Payne
Are you a Juniper Computer and Internet Expert? Answer questions, earn points and help others
