Question about Xerox Office Equipment & Supplies
Xerox workcentre 5230a error 027-529 Data read failure from smb server
  • joe schmoe
    joe schmoe Oct 24, 2013
    It was working fine until I did the upgrade from windows 8 to 8.1. On the xerox machine I can navigate to the proper shared folder. But when I scan it gives that error. I have the firewall turned off and all the firewall rules disabled. On the shared folder permissions are set for everyone access to read/write to the folder.
  • JayT
    JayT Nov 06, 2013
    I have the exact problem! Windows 8 worked fine, windows 8.1 error 027 529. Is there a fix?
3 Suggested Answers
SOURCE: Xerox WorkCentre 5230A email print problem.
I changed my default printer to a machine which works properly
Posted on Oct 08, 2009
nadirsalim
  • 185 Answers
SOURCE: i have Xerox WorkCentre 5230A when i am scanning
According to the manual, 018-591 means:
"The number of suffixes attached to folder or file names exceeded the limit.
Change the names of existing folders or files, or move the folders or files into
another folder."
good luck
Posted on Nov 29, 2010
Fuji xerox DC-II 3005 have 027-516 error, how to solve?
[Cause] During the transfer using SMB of the scan to PC
feature, the SMB server could not be found.
[Remedy] Take one of the following actions, and try again:
Check the following to see if the destination SMB server
and the machine are set up properly for network
communications:
- Check the network cables are plugged in securely.
- Check the TCP/IP settings.
- Check communications of port 137 (UDP), port 138
(UDP), port 139 (TCP).
Check the following to see if the computer correctly
works as an SMB server.
- Check if the file sharing service for Microsoft
Network is activated.
- Check if [NetBIOS over TCP/IP] for TCP/IP
is activated.
- Check if the file sharing service (using
communication through port 137 (UDP), port 138
(UDP), and port 139 (TCP)) are authorized for the
Firewall settings.
For communications which exceed the subnet, check the
WINS server settings, and check if the server address
can be resolved correctly.
For Windows NT 4.0 Server/Workstation, use the
following steps to see if the NetBIOS interface device is
activated on the destination SMB server:
1. Select [Start] > [Settings] > [Control Panel].
2. Display [Services], then select [Messenger] service.
3. Select [Startup] > [Auto] > [OK], then select [Close].
4. Select [Devices] in the [Control Panel], then select
[NetBIOS Interface].
5. Select [Startup] > [Auto] or [Manual] > [OK], then select
[Close].
6. Reboot the
Oct 11, 2016 | Xerox Office Equipment & Supplies
What is error 027-502?
Appears to be error message related to networking.
26171215-uilodj0wn3aoics0ffhdkown-5-0.png see page 412 of 454 in the attached manual Xerox WorkCentre 5230A System Administration Manual Page 412
Apr 21, 2016 | Xerox WorkCentre 5325 5330 5335 Black...
Everything depends on how you have it set up through the web interface of the Xerox. If you're using the SMB protocol for network scanning be sure that the folder you are trying to scan to is shared and that the user that you have set the xerox machine to use has LOCAL read and write access to that folder. Occasionally i've seen a firewall issue, but it's rare. All of this assuming that the OS on the PC your scanning to is running XP,Vista, or Server 2003. If you're running Windows 7 or Server 08, forget about it and switch to a FTP protocol and install Filezilla or add IIS through the add windows components and set up an FTP site. With either SMB or FTP, be certain that the username has read/write/delete access to the folder you are trying to write to (domain username will not do with this model). I hope this helps.
Nov 17, 2011 | Xerox WorkCentre Pro 123 Copier
Completed with an error (027-529):data read failure from SMB server
It's a connection issue try connecting from another computer
It could also be being blocked by a switch or router on thee network
Aug 01, 2011 | Computers & Internet
I have Xerox WorkCentre 5230A when i am scanning it is give me this error code 018-591
another folder."
good luck
Nov 29, 2010 | Xerox WorkCentre M118 Black and White...
Xerox cannot scan to home folder.....error 027-516 smb
home directories mustbe on the same server as ads is, meaning if you setup xerox ldap lookups on server SERVER1 with ip of 192.168.1.50 then the home dirs have to be on the same or an additional domain controller, Xerox software is stupid to this matter and does not like cross server home directories.
Apr 08, 2010 | Xerox WorkCentre C2424DN All-In-One Laser...
Oct 07, 2009 | Xerox Office Equipment & Supplies
RE : Xerox WorkCentre M128 016-782
Setting up a scanning template using CentreWare Internet Services (CWIS) will fail if the user login name is a domain user, for example, ADSdomain\testadmin.
  1. Open an Internet web browser.
  2. Enter the IP Address of the machine in the Address field, and then press [Enter] on the keyboard. The CWIS home page will be displayed.
  3. Click on the [Services] tab.
  4. Click on the [Job Templates] link.
  5. Click on the [Display Job Templates Screen] button. The Device Template window will be displayed.
  6. Click on the [File Repository Setup] radio button. The File Repository Setup window will be displayed.
  7. Select the required File Repository from the File Repository Setup pull-down menu.
  8. Enter a username that only exists on the SMB server in the Login Name field.
  9. Click on the [Apply] button. A 'Settings have been updated' message will be displayed.
  10. Click on the [Back] button. The File Repository Setup window will be displayed.
  11. Click on the [Template] radio button. The Device Template window will be displayed.
  12. Click on the [Create New] button, and then setup the template again.
  13. Click on the [X] in the upper, right corner to close the Internet browser window and return to the desktop.
May 19, 2008 | Xerox WorkCentre M128 Copier
2,731 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Xeroxrep
Level 1 Expert
Philip Hughes
CheckitRight
CheckitRight
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
