Question about Sony NW-E002 MP3 Player
Failes to detect mp3player
When i am trying to connect my mp3player to system i was showing that a problem that usb was not detec ted
  • 3 more comments
  • Anonymous Nov 08, 2007
    ive downloaded the sonic stage and ive uploaded and removed tracks from my device before but now id like to take things off but the computer isnt recognizing my device. how can i fix this?
  • Anonymous Dec 09, 2007
    My mp3 not is detecting but not showing in explorer
  • roxzixox Dec 24, 2007
    computer is not locating the usb connection, but, the mp3 can still charge, so i know the usb is not stuffed... any soloutions?
  • wiqs43 Jan 01, 2008
    My Sony Walkman E003F is Having a problem.
    When i connect it to the USB port, my computer notifies me "USB NOT RECOGNIZED, one of the usb devices has malfunctioned..."
    Yet the playback from the device is perfect. i can recharge it through the USB port and listen to songs i have already stored in it.
    Help required
  • Anonymous Jul 31, 2008
    not detected why??
  • 57 Answers
If you are using Windows 95, the player is not supported. If you are using Windows 2000 or XP, it will show the player as MTP player. If the MTP is not shown on My Computer, install the player as removable disk (use Device Manger, find the device connected, right-click on the player icon, and click Update Driver).
Posted on Aug 06, 2008
It´s a HW problem. USB2 is nota worka. May purchase an USB PicMic card (round about 20 bucks) and wanna be hapy
King Boss
Posted on Jun 04, 2008
Ai got an old computer and it it work but it show me an error with American Megatrends
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your ((motherboard to your hard drive)) make sure they have a secure dust free connections and are not faulty or just replace them they could be faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty or just replace them they could be faulty ?
even something as small as an electrical extension or a faulty fan lead can cause this problem
a computer needs all of the data and electrical current to travel through every working device and to have an end to be able work properly
motherboard and a hard drive any leads between them will fail before your motherboard or your hard drive if its a flat ribbon 40 pin type IDE replace it this will be the first to fail check all electrical extensions make sure they are securely seated even the cd/dvd floppy drives need to have current go through make sure these drives are working
make sure the CPU central processing unit has thermal paste and dust free and is securely seated
make sure your computer ram modules are securely seated with no dust in sockets also Cmos battery has charge with no dust in the socket some motherboards cmos batteries are soldered in
hope this helps you
Jan 07, 2012 | Computers & Internet
My usb modem [lemon 3g] does not get detected. when i plug the modem it does not show anything i.e usb icon detected hardware etc. when i clikc on cmy computer also it does not show any connection why is...
First, check for the power source, there should be a light indicator on the panel of the modem, else, power is a problem, check your adapter/power cable. Next, is use USB cable/USB port, try to use other USB cable/USB port. Another option is to check your Control Panel - Device Manager, see if there is a USB Modem currently installed. Remove/delete the device from your Device Manager. Going back to Control Panel, select Add Hardware. If still fails to detect, your Modem is dead.
Good luck.
Sep 18, 2010 | Computers & Internet
Transcend hard disk issue
The problem is the usb ports in your pc. You know the drive works and is properlly deteced on the laptop so you can ignore that.
IF you can try other usb devices in your pc usb ports and see if they work.If they don't at all then you either have dead ports or drivers are missing. You should see them listed under control panel system hardware.
If they work then I would wonder if the usb drive you have requires a differant usb port than what you have. There is a type 1 and 2 and type 3 which has just come out so we can ignore that one. A type 1 is slower and cannot power devices usually. A type 2 is faster and can power some devices. I don't know how old your pc is so it could be hardware, either failure or drives. You should also makre sure you have the service packs installed for windows. Sp3 is the latest version. There were some changes to the way usb devices were deteced in Sp2 if I remember correctly.
Apr 13, 2010 | Transcend StoreJet 2.5 (TS120GSJ25T) 120...
PC not detecting mp3player and also not able chage
Hello dear
If u can open your mp4 player then open it. and after change the crystal
detecting problem will be slove.
Sep 08, 2008 | Philips SA5125/37 MP3 Player
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
May 27, 2008 | Audio Players & Recorders
Bad Firmware Upgread
when i connect it to computer ; computer detect it as STMP3500 ; i download STMP3500 Driver from internet and then install it to Computer but already Computer Don't detect my mp3player;
then i run MuVoS200_PCFW_A5_1_02_02.exe but at this time computer detect my mp3player as MuVo S200 Then i upgread my Firm ware.
Now it work very good.
Mar 12, 2008 | Creative Labs MuVo S200 MP3 Player
Couldn´t connect SanDisk Sansa e250 to Computer
I don't know what to tell you, but since nobody else is helping. Make sure that you've got the mp3 player plugged into a usb port.
Oh, and hopefully you're running XP or Vista. Sandisk requires it.
Dec 19, 2007 | SanDisk Sansa e250 MP3 Player
Mobile not deteced on PC
restart your pc or try to insert your USB on the back of your cpu.
Nov 13, 2007 | Motorola Mobility SLVR L7 Cellular Phone
Sony NW-E002 MP3 Player Logo
129 people viewed this question
Top Sony Audio Players & Recorders Experts
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
