Question about AO Smith QC1102 1HP Pool Pump Motor 48Y Frame Square Flange - Energy Efficient
Replaced old motor with exact AO Smith QC1102. New impeller and go-kit installed. Re-attached power wires and ground, along with 8 g. bonding wires. Now...nothing, no power, no click, nothing....ideas?
    Scholar:
  • 94 Answers
Check the breaker and fuses. does it have a control pack? could be a bad relay on the board. what was the problem that made you replace the pump?
Posted on Nov 05, 2013
erpaalai
  • 999 Answers
SOURCE: wiring a 220v single phase motor and capacitor
Black and white are usually power. an ohmmeter will confirm. Brown are for capacitors. There is almost always a diagram on the motor someplace. Eric
Posted on Jun 17, 2009
john224
  • 1378 Answers
SOURCE: I HAVE AO SMITH MOTOR BL6414 HOW DO I WIRER IT UP
The BL6414 motor is shaded pole and does not require a capacitor.
Posted on Jul 12, 2009
john224
  • 1378 Answers
SOURCE: I have a AO Smith Century Centurin Swimming Pool
A.O.Smith USQ1152.
Posted on Jan 18, 2010
  • 198 Answers
SOURCE: 1 HP electric motor hums but not turning.
check for a re-set button somewhere on the motor housing.
Posted on May 04, 2010
macdirk
  • 116 Answers
SOURCE: Need to replace pump Impeller on A.O. Smith
To get to the Impeller you need to remove a series of bolts, or a large clamp, that holds the two halves of the pump together. Once you do that, if their is a diffuser (housing that goes over the impeller), remove it. To remove the impeller, you need to lock the motor shaft. You can do this a couple different ways depending on the motor. There will either be a small cap that grants access to the motor shaft on the back of the motor, or you remove a larger housing that grants access to the wiring and other components in the back of the motor. If it's the small cap, then you can hold the shaft with a wrench. If it's the larger housing, then you can slip a wrench (probably 7/16") under the thermal overload switch and onto the shaft to lock it in place. Now you can unscrew the impeller. Check to see if the impeller has a screw in the center. If so remove this first. It will be reverse thread. The impeller should spin off counter clockwise. If the impeller is very tight, be careful not to damage it. If you don't have an impeller wrench, I strap wrench, or very large locking pliers with a rag around the impeller works well. Hope this helps. If you need further assistance post a reply in the comments, and don't hesitate to leave a good thumb rating if you found this helpful. Thanks, and good Luck!
Posted on Oct 12, 2010
New pool pump motor governor keeps tripping under load
READ ALL .. sounds like your power is 120 v, check with meter on L1-L2 . if it says 230-240v the switch might be lose or there is just way too much back pressure OR the impeller is too big for the motor OR the shaft seal is installed wrong, when spinning the impeller by hand "snap of the wrist " it should almost make a full turn.
remember to vote or reply... Jay the pool pump repair guy in longwood Fl
Apr 17, 2014 | AO Smith Pool Pump Motor Hayward Swimming...
New ao smith pool pump motor keeps tripping out under load
check the breaker might be weak possibly from previous pump motor also if it was hooked up incorrectly at first might have done damage to motor windings
Switched to new AO Smith B230SE motor for pool pump. Old motor had left-hand screw that held impeller to shaft. New motor does not have an opening for screw. Will impeller be fine without screw?
Did you try the Century A.O. Smith B230SE motor without the center screw? I'm having the same problem and I'm asking the reseller for advice. It would be great to know if I need the center screw is required? The impeller screws on the shaft, but is the center screw required?
Sep 17, 2013 | A.O. Smith SQ1102 Pool Pump Motor
Replace ao smith century centurion b852
take apart normally impeller screw backwards thread but impeller unscrews normally
Oct 20, 2012 | AO Smith A O Smith Motors A O Smith 3/4hp...
I'm wiring a 220v Gould Century 1081 pool motor does the pool motor need to be bonded in order to get a proper ground
bonding required for safety 1st hot to L1 2nd hot to L2 green to ground or case and bonding wire to lug on case
May 25, 2012 | AO Smith A O Smith Motors Century 1hp 115v...
A.O smith pool pump tripping breaker
It you either have an impeller problem or capacitor problem on the motor. I would take the capacitor off and take it to a electronic or lexical shop to have them check it. It's only about 15 to 20 dollar pics if it's just your capacitor.
A thumbs up would be greatly appreciated if answer is helpful for your question. THANK you and GOD BLESS YOU.
Apr 08, 2012 | AO Smith 1 hp 3450rpm 56Y Frame 115230...
How to remove impeller
i think they screw on and the screw only locks it in place
Mar 22, 2012 | AO Smith SQ1152 Pool Pump Motor
My pool originally had a 2 speed AO Smith pump motor. Several years back it was replaced with an AO Smith single speed motor. I am replacing that motor with a new AO Smith single speed Centurion Switchless...
Is it going to run on 230V then? If so you would normally use red and black. The white wire should be a neutral and the ground wire is obviously ground.
Do you have a meter you can use to confirm the voltage between the wires? If you do you'll want to start with red and white since you seem to think black was not being used before. If the voltage reads 230 and the motor is set up for 230 then attach one wire to L1 and the other to L2...it will not matter which is connected where as long as one is on each terminal. Insulate the black and ground the ground lead to the motor ground screw.
If the voltage is not 230 between those two check between red and black. If that is the 230 then insulate white and put red and black to L1 and L2.
John
May 23, 2011 | AO Smith 2 hp 3450rpm 56C Frame 230 Volts...
Where I can buy the A.O Smith 3/4 HP pool pump impeller?
You'll need information from the pump that the AOSmith electric motor is attached to in order to get an impeller or any other pump parts. If there is no nameplate for the pump are there numbers on the impeller you need?
John
Mar 03, 2011 | AO Smith A O Smith Motors A O Smith 3/4hp...
How to connect the 3 phase power supply to a 3 phase synchronous motor with control panel
I assume you have 3 phase power where this is going? The panel has 3 legs, 2 are 110 volt and one is 208 volt, you will need a tester to find out which is which if it is not marked, the motor should have a map on it for the wires to attach to, they go the same way, two, 110 and one, 208, I hope this helps, There will be one wire for a ground or a solid wire separate from the unit.
Feb 13, 2010 | AO Smith Three Phase Swimming Pool Pump...
AO Smith QC1102 1HP Pool Pump Motor 48Y Frame Square Flange - Energy Efficient Logo
94 people viewed this question
Top AO Smith Pool & Spa Experts
Jay Finke
Jay Finke
Steve
Larry Maranto
Are you an AO Smith Pool and Spa Expert? Answer questions, earn points and help others
