Question about Garden
Back pressure is too much for the starter to rotate the engine
  • 351 Answers
Check decompressor valve
Posted on Oct 23, 2013
MY 1998 CHRYSLER CONCORDE WANT START, WHEN TRYING TO CRANK IT UP, IT MAKES CLICKING NOISES, IVE BROUGHT A STARTER AND NEW BATTERY, BUT ITS STILL DOING THE SAME THING..PLEASE HELP ME
Assuming that the new starter and battery are not defective (one easily could be), the next thing to check for would be to verify that the engine is not seized up. Get a breaker bar wrench and fix it to a socket that is the size of the crankshaft pulley nut. Place the socket over the nut, and, facing the engine, attempt to rotate the crankshaft in a clock wise direction. If it turns, then the engine is not seized. If it won't turn at all, then next, remove all spark plugs and try to rotate the engine again. If it still won't rotate, you have serious internal engine issues. If it does rotate after removing the plugs, you may have had hydrolock, where gasoline fills the cylinders and won't allow the engine to rotate. If it rotates, then try to use the starter again briefly with the plug removed. Obviously it won't start, but if it rotates, you can put the plugs back in and try again, hopefully with success. If the engine is seized, unless the car itself is in mint condition, you're better off getting a new car than trying to repair this one just based on age.
Nov 14, 2016 | Chrysler Cars & Trucks
I have a 1997 mitsubishi spyder gs 2.4 and it trys to start then quits trying if you turn the key off and back on it will try again and then quit trying again.The fuel pump is working I checked it .Can you...
you have to give it a pause of 10 - 15 seconds whenever you release the starter otherwise it may result in improper functioning and idle rotation of the starter.
Mar 19, 2015 | Mitsubishi Cars & Trucks
Car has to be cranked more then once,than a scraping noise and then car starts.i'm scared whats the problem
the gear on the flywheel has worn. the engine stops in one of four spots in the rotation 'cause the cylinder pressure is building. That means the starter has not got the whole flywheel, but only a few teeth in four spots that is starts on every single time. these teeth wear out, then the starter motor cog cant turn the flywheel and you get the screech like you tried to change a stick shift without the clutch!
if you do have a stick shift, then you can park on a slight hill, and roll just a bit with the clutch half out, which will rotate the engine and give the starter motor fresh teeth to work on.
in short, yes, you need a mechanic.....
Oct 18, 2013 | 2001 Buick Century
2002 expedition wont start but all electronics come on
give me more detail do the engine turn over not start or do the engine not rotate.make sure battery has 12.5 volts and battery cables clean not corroded,if you have 12.5 volts need to remove test starter and starter solenoid.if engine turn over.check for fuel pressure and spark at spark plugs.have vechicle code scan before buying new parts.
Oct 26, 2012 | 2002 Ford Expedition
Is there a starter fuse on a 86 buick park ave
May be a starter fuse - but if blown, starter will not rotate engine. More likely a fuel starvation problem. Replace fuel filter in gas line - first choice. Next, have fuel pump pressure checked. If it has failed, you will get 4 -5 seconds of engine run before stopping.
Jan 06, 2012 | 1989 Buick Park Avenue
Where is the starter located on 2002 intrepid
Underneath the car. somewhere near where the engine and transmission hook up.
Removal & Installation
2.7L Engine
1. Remove or disconnect the following:
Negative battery cable from the remote ground post
Battery feed and posi-lock connectors
Nuts from the catalyst support bracket and mount
Starter heat shield
3 starter-to-engine/transaxle bolts
Starter by rotating it toward the engine and sliding it rearward between the catalyst and the engine mount
To install:
1. Install or connect the following:
Starter by sliding it forward between the catalyst and the engine mount and rotating it away from the engine
Starter and torque the 3 starter-to-engine/transaxle bolts to 40 ft. lbs. (54 Nm)
Starter heat shield
Nuts to the catalyst support bracket and mount
Positive battery cable and torque the nut to 89 inch lbs. (10 Nm)
Posi-lock connectors
Negative battery cable to the remote ground post
3.2L & 3.5L Engines
Starter-to-engine/transaxle nut and bolts
Positive battery feed wire from the starter
Starter and position it to gain access to the posi-lock connector
2. Place a support under the engine and slightly relieve the pressure from the left engine mount.
3. Remove the 3 left engine mount-to-engine bolts.
4. Slightly, raise the engine to provide more room.
5. Remove the starter by sliding it rearward between the catalyst and the engine mount.
6. Remove the posi-lock connector.
Click image to see an enlarged view
Fig. Removal and installation of the starter motor
To install:
Posi-lock connector
2. Slightly, lower the engine.
Positive battery feed wire to the starter and torque the nut to 89 inch lbs. (10 Nm)
Starter and torque the starter-to-engine/transaxle bolts to 40 ft. lbs. (54 Nm)
Hope this help (remember rated and comment this).
Mar 27, 2010 | 2002 Dodge Intrepid
How do I get to the starter on a 98 concorde
2.7L Engine
    Negative battery cable from the remote ground post Battery feed and posi-lock connectors Nuts from the catalyst support bracket and mount Starter heat shield 3 starter-to-engine/transaxle bolts Starter by rotating it toward the engine and sliding it rearward between the catalyst and the engine mount
To install:
    Starter by sliding it forward between the catalyst and the engine mount and rotating it away from the engine Starter and torque the 3 starter-to-engine/transaxle bolts to 40 ft. lbs. (54 Nm) Starter heat shield Nuts to the catalyst support bracket and mount Positive battery cable and torque the nut to 89 inch lbs. (10 Nm) Posi-lock connectors Negative battery cable to the remote ground post
3.2L & 3.5L Engines
    Negative battery cable from the remote ground post Starter-to-engine/transaxle nut and bolts Positive battery feed wire from the starter Starter and position it to gain access to the posi-lock connector
    0996b43f80204958.jpg enlarge_icon.gifenlarge_tooltip.gif Fig. Removal and installation of the starter motor
To install:
    Posi-lock connector Starter by sliding it forward between the catalyst and the engine mount
    3 left engine mount-to-engine bolts Positive battery feed wire to the starter and torque the nut to 89 inch lbs. (10 Nm) Starter and torque the starter-to-engine/transaxle bolts to 40 ft. lbs. (54 Nm) Negative battery cable to the remote ground post
Mar 23, 2010 | 1998 Chrysler Concorde
How do I remove the starter on a 1999 Dodge Intrepid
2.7L Engine
To install:
3.2L & 3.5L Engines
To install:
Hope this help (remember rated and comment).
Mar 22, 2010 | 1999 Dodge Intrepid
2001 Dodge 4x4 diesel 6-speed. Replaced clutch and pressure plate, now the starter won't turn the engine over.. Tried turning it over with the harmonic balancer, and the output shaft on the x-fer case. No...
One problem pops into head when I think about your description of the problem. The bolts that hold the pressure plate to the flywheel may be too long, causing the engine block to interfere with the rotation of the flywheel.
Nov 17, 2009 | 2001 Dodge Ram 2500 Truck
Lawn Tractor Engine-Start Problems
Ed, I think that when all is said and done you will find that you have a defective STARTER MOTOR. If the BATTERY is at full Charge, and it takes a Battery Charger added to the Battery in order to get enough current to turn over and Start the Motor. I suspect the Starter Motor is defective.
I also have Sears Tractors with Briggs, three of them.
Also clean your Spark Plug when you service the Engine.
Good Luck!
Feb 03, 2008 | Karcher 2500 PSI Pressure Washer
Garden Logo
14 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
