Amana pth153 how to remove old fan blade unit (broken blades) and install replacement fan blade unit
RepairUSA
  • 50 Answers
SOURCE: Condenser fan mounting
Most condenser fan turn ccw looking down into the unit and should be mounted about 1" from motor. A good check is that the air is moving up and out and drawing through the condenser. Thanks
Posted on Aug 10, 2007
SOURCE: replacement fan blade for fan
I have one of these pieces of junk. The motor swarmed, so the rest of the fan is perfect. I'll sell it for $10.00 plus shipping.
Skip marinaman@aristotle.net
Posted on Jul 17, 2008
mindhunterxp
  • 5 Answers
SOURCE: GE Zoneline az22e12d3bm1: Broken fan blade.
V O T E 4 O B A M A
Posted on Oct 29, 2008
pierre1811
  • 144 Answers
SOURCE: heat pump outside unit not running
It sounds like your defrost board failed. You will need a tech to replace it. With that model it may have a parts warranty but you pay labor(?)
Posted on Jan 18, 2009
c17hydro
  • 2984 Answers
SOURCE: How to remove and replace the wiper blades on a 2006 BMW 325i.
My suggestion....go to Schuck's/Kragen?Chief's?Auto Zone....they will install them for FREE.
Posted on Mar 11, 2009
I have a new ptac that won't cool, why?
The condeser fan blade is broken. I work at a place where 75% of these units have cond. fan broken in same place.
Mar 22, 2012 | Amana PTH123B25AJ Heat Pump Air...
I have a 1400 btu portable air conditioner ( AMANA ) and the fan is broken, how to replace it.
Obviously, you will have to disassemble part of the cabinet to access the fan blade. Removig the blade should not be difficult. If it's the fan motor, than that may be a challenge. However, since you did not furnish the Model Number of your AC Unit, there's not much more I can tell you, other than where to find the part(s) you'll need. Try Factory Appliance Parts http://www.appliancefactoryparts.com/airconditioners/amana/amana-motors-and-blades.html You'll definitely need the correct Model Number of your unit, to search for the part(s) you'll need.
Hope this helped you.
Jun 27, 2011 | Amana Portable Air Conditioner
Rheem condensing unit fan motor failure?................3rd motor was replaced by contractor on 3 year old unit. Unit starts vibrating very badly and will also start vibrating when blocking airflow. All...
Could be the fan blade is the issue for vibration. Perhaps the blade was bent or somewhat damaged during failures or during the fan motor replacement process.
Might try replacing the blade. Be sure to install the correct blade. Pitch, number of blades as was on the original unit. If blade was replaced previously, the new blade may be pitched or sized incorrectly.
Sep 02, 2010 | Heating & Cooling
Amana Prestige Central A/C,inside fan on out side fan not running,breaker in house good out side switch on,is there a breaker in the out side box ? it is not seen.Out side fan feels reel warm but not...
Hi!!
Replace motor fan and capacitor of the outside unit. it is a very simple task. Turn breaker OFF. Then all you have to do is remove about four screws from the top grill, about four more that fasten the motor fan assembly, unplugg electrical connectors and label them and install the new one and switch fan blades.
No special knowledge is required to perform this job. Cost: about $140 +-.
On the other hand, you call a HVAC technician, they supply the motor and capacitor, otherwise they won't give you warranty. Cost $300. Look on the Yellow Pages for one in your neighborhood.
Good Luck!! Rate this post!!
Aug 13, 2010 | Amana ABC2037SS Air Conditioner
We have a amana BX21VW bottom freezer refridgerator. The fan behind the back plate in the freezer section makes a very loud vibrating noise. If we put pressure on it it is quite. How can we fix it?
Good day,
There is no repair possible. You could try changing the blade only, but the best repair is replacing the motor and blade as a unit.
However, it is your choice on the blade only approach.
Feb 25, 2010 | Amana Refrigerators
Dehumidifier runs but doesn't produce water
Your dehumidifier has a circulating fan that draws the room air over the coils. If there's no air movement out the front or back of the unit, the fan motor may be burned out or stuck, or the fan blade may be broken. If so, you need to replace the fan motor or the fan blade.
Sep 04, 2009 | Kenmore 5230 Dehumidifier
Broken fan blade on the 697400 humidifier
Hay Richard -- Little suckers spin to fast for gluing. Take the fan blade off , mark one side before you remove it ex: put an x on the side that is facing the wall. Take blade to a Johnstone supply house. Should be one near you somewhere, they are national. The guys there are usually very good at matching up fan blades. Make sure you keep the one you have with the mark on it. When you get home install the new blade the with the side out that was on the old blade. Hope that helps
Mar 05, 2009 | Bemis 697 400 Humidifier
Broken mount attic exhaust fan
buy new blade or keep soaking shaft.collar with rust penetrant,
Jul 25, 2008 | Ventamatic Gable Mount Power Attic...
How to remove and install fan in freezer compartment of GE side by side
Most of these fans have a small dowell pin that goes through the fan blade sleeve and through the shaft look for a pin on the side of the fan blade sleeve then you will need a pin punch to push this pin through. After you do this save the pin or dowell because you will need it to attach the new fan.
Jun 03, 2008 | Refrigerators
Heating & Cooling Logo
15 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
